local_dani_21
Hi guys
I'm frustrated because I just fried my third teensy 3.1 and still don't know, what happened (at least I have an idea). Every time one broke it took me a while to realize that the teensy was fried (when powered it get's very hot, isn't registered by the system anymore and it can't be talked to using the Arduino IDE). Therefore I don't know the exact moment when it stopped working; however I think it could be around the time when I added an external power supply while talking to the teensy 3.1 over USB using the Arduino IDE serial monitor.
Here is what I did, maybe you have an idea.
I'm working on a project that in the end will need a lot of power, so there is a power plug in parallel to the rest of the curcuit to connect a 5V / 3A switched and well regulated power supply. Shortly before the last breakdown, I added one of the power consuming parts (a raspberry pi 2 that is connected to a an ethernet shield that is connected to the teensy) and connected the external power supply. The system kept working (as far as I can remember) for a few minutes (I talked to the teensy using USB-Serial in Arduino IDE serial monitor) and then the teensy got hot and stopped working.
Do you know if USB power and an external power supply can conflict and eventually destroy a teensy 3.1?
Thank you very much!
Dani
Dani
