I want to use the FTM1 timer module on my Teensy 3.1.
It looks like it is being initialized by the function _init_Teensyduino_internal_(void) in pins_teensy.c
It appears this initialization is only needed if I do AnalogWrite to pins 3,4 or 25.
If I do not do AnalogWrite to these pins, will there be any issue if I use FTM1? Will I cause any problems if I remove the initialization code in _init_Teensyduino_internal_(void)?
Actually, I am not doing AnalogWrite at all if that makes any difference.
Thanks,
TLB
Thanks,
TLB
