khoih-prog
FTPClient_Generic Library
How To Install Using Arduino Library Manager
Features
This FTPClient_Generic Library is a simple yet complete FTP Client library for AVR, mega-AVR, Portenta_H7, Teensy, SAM DUE, Arduino SAMD21, Adafruit SAMD21/SAMD51, Adafruit nRF52, ESP32/ESP8266, STM32, RP2040-based, etc. boards using either WiFi or Ethernet.
Library is based on and modified from:
1. Leonardo Bispo's ESP32_FTPClient
Changelog
Releases v1.0.0
1. Initial porting and coding to support many more boards, using WiFi or Ethernet
Debug Terminal Output Samples
1. FTPClient_DownloadFile on TEENSY 4.0 with W5x00 using Ethernet_Generic Library on SPI0/SPI
The following is debug terminal output when running example FTPClient_DownloadFile on TEENSY 4.0 with W5x00 using Ethernet_Generic Library on SPI0/SPI.
The FTP Server is Teensy 4.1 using QNEthernet and FTP_Server_Teensy41 library
Features
Changelog
Releases v1.0.0
Starting FTPClient_DownloadFile on TEENSY 4.0 with W5x00 using Ethernet_Generic Library on SPI0/SPI
FTPCLIENT_GENERIC v1.0.0
[EWS] =========== USE_ETHERNET_GENERIC ===========
[EWS] Default SPI pinout:
[EWS] MOSI: 11
[EWS] MISO: 12
[EWS] SCK: 13
[EWS] SS: 10
[EWS] =========================
[EWS] Board : TEENSY 4.0 , setCsPin: 10
[ETG] W5100 init, using SS_PIN_DEFAULT = 10 , new ss_pin = 10 , W5100Class::ss_pin = 10
[ETG] Chip is W5100S
[ETG] W5100::init: W5100S, SSIZE = 4096
[EWS] Currently Used SPI pinout:
[EWS] MOSI: 11
[EWS] MISO: 12
[EWS] SCK: 13
[EWS] SS: 10
Using mac index = 14
Connected! IP address: 192.168.2.99
[FTP] Connecting to: 192.168.2.241
[FTP] Command connected
[FTP] Send USER = teensy4x
[FTP] Send PASSWORD = ftp_test
[FTP] Send CWD
Creating new file helloworld.txt
[FTP] Send TYPE Type A
[FTP] Send PASV
[FTP] outBuf = 227 Entering Passive Mode (4043483328, port 55600)
[FTP] _dataAddress: 192.168.2.241 , Data port: 55600
[FTP] Data connection established
[FTP] Send STOR
[FTP] Write File
[FTP] Close File
[FTP] Send PASV
[FTP] Send RETR
[FTP] Result start
[FTP] Result: 150-Connected to port 55600
150 18 bytes to download
226-File successfully transferred
226 1 ms, 18 kbytes/s
[FTP] Result end
timedRead timeout = 1000
The file content is: Hi, I'm a new file
[FTP] Send PASV
[FTP] Send MLSD
[FTP] Result start
[FTP] Result: 150 Accepted data connection to port 55600
226-options: -a -l
226 18 matches total
[FTP] Result end
type=file;modify=20220429231446;size=3810; index1.htm
type=file;modify=19800101000000;size=13; foo.txt
type=file;modify=20190101003904;size=3714; index2.htm
type=file;modify=20220429225004;size=3810; index.htm
type=file;modify=20220409222458;size=10; mydatalog.txt
type=file;modify=20220313201514;size=4116; edit.htm.gz
type=file;modify=20190101003834;size=1150; favicon.ico
type=file;modify=20220313201514;size=1971; graphs.js.gz
type=file;modify=20220429225138;size=1547; esp_at_wm_lite.txt
type=file;modify=20190101002054;size=18; helloworld.txt
type=dir;modify=20190101000020;size=0; mynewdir
type=dir;modify=20190101001150;size=0; my_new_dir
type=file;modify=20190101001414;size=11; hello_world.txt
File size is: 18
[FTP] Send TYPE Type I
[FTP] Send PASV
[FTP] Send RETR
[FTP] Result start
226 File successfully transferred
[FTP] Result end
[FTP] Send PASV
[FTP] Send MKD
[FTP] FTP error: 521 "myNewDir" directory already exists
[FTP] Send CWD
[FTP] Send STOR
[FTP] Writing
[FTP] Close File
CloseConnection
[FTP] Connection closed
