Getting high speed DAQ data off a Teensy 4.1
Dr_Nic
Hi I'm new to the Teensy eco-system FTR
I have a Teensy 4.1 interfaced with an EVAL-AD7606SDZ DAQ board.
I'm using Joshua Austill's AD7606 library and will be targeting a sampling rate of 100KHz.
So 16 bits x 8 channels x 100,000 = 1,600,000
I need to run for a minimum of 12 seconds so obviously memory is now an issue.
What is the best way to get this data out, either as its coming in or buffered in someway?
16 bytes x 8 channels x 100,000 = 1,600,000
Eh?
16 bytes x 8 channels x 100,000Hz = 12.8Mbytes/s. For 12s that’s 153.6Mbytes.
Your best bet is a fast SD card with a pre-allocated file - there are many threads here about this. SD on the built-in SDIO socket can reach about 20Mbytes/s; you may well be able to run for considerably longer than 12s.
Eh?
Typo will fix meant to be 16 bits not bytes
OP likely meant 16 bits, not bytes... A 128 bit ADC would be pretty damn impressive.
Indeed it would!
Ah, different question then. 1.6Mbytes/s or 25.6Mbits/s. 12s duration gives 19.2Mbytes.
So … SD storage is pretty much trivial, apart from the high memory prices at the moment … Streaming over USB is doable, as long as you use a robust protocol like COBS to preserve data integrity … Or installing two of the newish 16Mbyte PSRAM chips would give you space for 20s of data.
Which of those is your best choice rather depends on a bunch of stuff you haven’t disclosed, like whether a USB tether is possible, how robust the system needs to be (you probably wouldn’t use SD in a rocket…), how many runs you envisage doing, how many systems you plan to make, etc.
