mortonkopf
@Paul, as discussed, here is a working example sketch for using Glediator with OctoWS2811 library, and some guidance on setting up.
To get Glediator running, you need to install two files that allow java applications to communicate via the computers ports. The two files you need are:
librxtxSerial.jnilib and RXTXcomm.jar
you can download these files from the RXTX site, and also find further help on installing, although I did not find the help so helpful.
http://rxtx.qbang.org/wiki/index.php/Main_Page
The download page is here: http://rxtx.qbang.org/wiki/index.php/Download
The two files need to go into a folder called Library. For some reason, i did not have a folder, so had to create one.
If you don’t have it already, create folders in the library folder and call it /Java/Extensions.
in my mac file structure this is put under /Users/Home/Library
Into this folder put the two files
and
RXTXcomm.jar
for linux there is info on this link http://rxtx.qbang.org/wiki/index.php/Installation_on_Linux
but unfortunately I don’t use it, so I have this example running on MacBook Pro.
Upload the sketch below to your Teensy.
Gladiator is a pain, in that it seems to hang and crash on my Mac if you do things in the wrong order. First you need to set the matrix size, and then set the output parameters. Also, when setting the output parameters, you can’t go back and change settings after opening the serial port, so do this last.
when restarting Glediator, in the setup menu, you should now see the list of ports. Select the tty port usbmodemxxxx or some such. and then click apply.
Ensure that you have selected the output type as Glediator protocol.
and
RXTXcomm.jar
#include <OctoWS2811.h>
const int ledsPerStrip = 34;
const int NUM_LEDS =272;
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
leds.begin();
leds.show();
int serialGlediator() {
while (!Serial.available()) {}
return Serial.read();
byte r,g,b;
int i;
while (serialGlediator() != 1) {}
for (i=0; i < NUM_LEDS; i++) {
b = serialGlediator();
r = serialGlediator();
g = serialGlediator();
leds.setPixel(i, Color(r,g,b));
leds.show();
/* Helper functions */
// Create a 24 bit color value from R,G,B
unsigned int Color(byte r, byte g, byte b)
//Take the lowest 8 bits of each value and append them end to end
return( ((unsigned int)b & 0xFF )<<16 | ((unsigned int)r & 0xFF)<<8 | (unsigned int)g & 0xFF);}
