nithyaajayan
The project I'm working on involves integrating 3 sensors: GPS, BME, MQ135 to teensy 4.1 and running them simultaneously. I've tested each of these sensors seperately and they work just fine. But on integrating, BME and MQ135 works perfectly, while GPS gives all null values. I'm using GNSS L89 for my GPS. The connections shouldn't be a problem, given they've worked well when run individually on the same pins I've used for integration.
What could be the problem and how do I resolve it?
C:
#include "Adafruit_BME680.h"
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
#define SEALEVELPRESSURE_HPA (1013.25)
#define rxGPS 0
#define txGPS 1
Adafruit_BME680 bme;
const int mq2Pin = A0; // MQ-2 for smoke and flammable gases
const int mq7Pin = A1; // MQ-7 for carbon monoxide
const int mq135Pin = A2; // MQ-135 for air quality (various gases)
long lat, lon;
SoftwareSerial gpsSerial(rxGPS, txGPS);
TinyGPSPlus gps;
gpsSerial.begin(9600); // connect gps sensor
while (!Serial);
Serial.println(F("BME680 test"));
if (!bme.begin()) {
Serial.println("Could not find a valid BME680 sensor, check wiring!");
while (1);
// Set up oversampling and filter initialization
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
if (!bme.performReading()) {
Serial.println("Failed to perform reading :(");
return;
float temperature = bme.temperature;
float pressure = bme.pressure / 100.0;
float altitude = bme.readAltitude(SEALEVELPRESSURE_HPA);
int mq2Value = analogRead(mq2Pin); // Read MQ-2 sensor value
int mq7Value = analogRead(mq7Pin); // Read MQ-7 sensor value
int mq135Value = analogRead(mq135Pin); // Read MQ-135 sensor value
while (gpsSerial.available()) // check for gps data
if (gps.encode(gpsSerial.read())) // encode gps data
Serial.print("Number of satellites: ");
Serial.println(gps.satellites.value());
Serial.print("Latitude: ");
Serial.println(gps.location.lat(), 6);
Serial.print("Longitude: ");
Serial.println(gps.location.lng(), 6);
Serial.print("Altitude: ");
Serial.println(gps.altitude.meters());
Serial.print("Speed: ");
Serial.println(gps.speed.mps());
Serial.print("Date: ");
Serial.print(gps.date.day()); Serial.print("/");
Serial.print(gps.date.month()); Serial.print("/");
Serial.println(gps.date.year());
Serial.print("Hour: ");
Serial.print(gps.time.hour()); Serial.print(":");
Serial.print(gps.time.minute()); Serial.print(":");
Serial.println(gps.time.second());
Serial.print("Temperature: ");
Serial.print(temperature);
Serial.println(" *C");
Serial.print("Pressure: ");
Serial.print(pressure);
Serial.println(" hPa");
Serial.print(altitude);
Serial.println(" m");
Serial.print("Smoke: ");
Serial.print(mq2Value);
Serial.println(" ppm");
Serial.print("Carbon Monoxide: ");
Serial.print(mq7Value);
Serial.print("Air Quality: ");
Serial.print(mq135Value);
delay(2000);
