https://github.com/PaulStoffregen/Audio/blob/master/examples/Effects/Granular/Granular.ino
granular example has been add to Audio library. By Use , i felt it is not helpful for playback speed .And Somewhere else not more info .
if you see code of above example,
also use of files loaded in PSRAM.. it may be great advantage to sampler user.
....................... THANK YOU .................................
knobA is related to speed. But it is making pitch up/down with bad guality effect. i request you please add exmple for speed slower/faster for given "XXXX.wav" or XXXX.raw files.also use of files loaded in PSRAM.. it may be great advantage to sampler user.
