Shadolance
Hello everyone, my name is Shadolance (new to the forums here, this is my first post!), it's a pleasure to meet you! I was reading through a bunch of topics on here and it seems a lot of people have been getting great help starting projects, and I was wondering if I could get some help with my latest idea as well.
Simply put, the title is correct: I want to build a gyrocopter. The basic idea is to have a pendulum-style body, bottom-weighted where the hardware will almost entirely reside. Power supply, microcontroller, motor controller, etc. This "bulb" will be connected to two counter-rotating blades at the top, creating a gyro. Think of an umbrella shape almost, where the blades act as the cover and the "handle" is where all of the hardware is located. The end goal is to make a mock-aircraft model where in theory a person could ride inside the "shaft" part of the umbrella. As for scale size, preferably no taller than a foot and a half, and the blade can extend as far as they need to to provide appropriate lift.
Now, for what I need help on is primarily choosing parts, but not so much because of not knowing which parts are appropriate to do the job. The biggest issue for me is determining weight and the amount of power necessary to lift the device off the ground. More powerful motors are larger and heavier, as are batteries to power them. However, this needs to scale to the amount of force provided by lift. This scaling is hard for me to get my head around.
As for my current plans, I intend to use a Teensy 3.1 unless given strong reason otherwise. I am very familiar with all of the necessary code that will go into it, that is the least of my concern. I need help picking out appropriate devices for the following feature I intend to include:
- Auto-stabilization
- obstacle avoidance (sonar sensor preferably, 3 foot range minimum)
- Remote control (I've only ever built autonomous robotics in the past, this is new to me. Bluetooth perhaps?)
- Full lateral movement (meaning the blade will have to be able to angle themselves appropriately)
Thank you all for reading this if you made it this far, I greatly appreciate the time! Like I mentioned before, I'm new to this forum so if I did something taboo, I apologize and will fix what is necessary. I'm a fairly experienced electrical engineering student at university, and I'm confident my coding ability will be enough to get the majority of this project done (should I need help I look forward to asking for a hand in the future!)
Above all, this is a learning experience for me. I'm super stoked to build this thing!
Cheers,
~Shadolance
PS - Assume for the sake of the project that there are no financial constraints.
Cheers,
~Shadolance
