Happy little incident #11
Mcu32
Two numerical issues in control_sgtl5000.cpp
1. autoVolumeControl() uses uint8_t for values that are calculated much larger​
thresh, att and dec are declared as uint8_t.
The calculations immediately produce values larger than 255, so assigning the result to uint8_t truncates the value to its lowest 8 bits before it is passed to write().
A calculated value such as:
0x39BC
becomes:
0xBC
when stored in uint8_t.
The exact final width can then be limited when writing to the codec registers, rather than accidentally losing the upper bits during the calculation.
Register width: 16 bit.
There's even an old issue on GitHub about this already.
2. calcBiquad() does not round negative coefficients correctly​
At the end of calcBiquad() the coefficients are converted using:
*coef++ = (int)(b0 + 0.499);
*coef++ = (int)(b1 + 0.499);
*coef++ = (int)(b2 + 0.499);
*coef++ = (int)(a1 + 0.499);
*coef++ = (int)(a2 + 0.499);
This works approximately as intended for positive values, but it is not symmetric for negative values because conversion from floating point to int truncates toward zero.
Which AI are you using? I've been using Claude so far, and I've been impressed by its ability to analyze code and find bugs.
Various. I think Claude is the best, but ChatGPT does a good job, too. Gemini is good sometimes, but on other days it hallucinates too much.
I’m currently porting the audio library to the ESP32. The AIs are a huge help there and really take a lot of the tedious work off my hands.
We’ll see how it goes when I start optimizing for the S3’s DSP. I don’t expect much-the ESP can’t hold a candle to ARM when it comes to 16-bit calculations-but I think 90% of normal audio tasks will work just fine there too. There are some positives, too. Since the 16-bit limitation often makes it better for me to just use 32-bit right away, I take advantage of that “on the side” to improve the audio quality vs Teensy.
Without AI, I would never have started this.
Okay, it's working so far.
On an old ESP32 A1S1(not an S3):
Core 0 (rtos, Wi-Fi, MP3, AAC) is currently using 59% of the CPU, and Core 1 (user code + audio library, connections, statistics, I2S + DMA handling, etc.) is using 7%.
- for an MP3 radio stream at 128k+ VBR - not bad; I think I can work with that.
(and not a single “disable interrupt”)
unfixed since 2017:
bool AudioControlSGTL5000::lineInLevel(uint8_t left, uint8_t right)
left and right are swapped.
(edit: down to core 0: 29%, core 1: 5.5% with 192kb/s aac stream)
void AudioEffectGranular::beginFreeze_int(int grain_samples)
__disable_irq(); //arghhhhh
grain_mode = 1;
if (grain_samples < max_sample_len) {
freeze_len = grain_samples;
sample_loaded = false;
write_en = false;
sample_req = true;
__enable_irq();
Also: It doesn't check whether the IRQ was disabled beforehand … okay, I know you don't want to hear that … that pattern is everywhere.
