Mcu32
A pretty minor bug, but still a bug and very easy to fix, zero costs:
Fix: The initial if (width < 0) in the NaN and Inf blocks must be changed to if (width > 0).
void incident_9()
char buffer[20];
float normalNumber = 12.34;
float nanNumber = NAN; // Generates a "Not a Number"
Serial.println("--- width = 10 (Should be right-aligned: spaces IN FRONT) ---");
// 1. Normal number (Works correctly)
dtostrf(normalNumber, 10, 2, buffer);
Serial.print("Normal: '");
Serial.print(buffer);
Serial.println("'");
// Output: ' 12.34' (Correctly right-aligned)
// 2. NaN with the bug (Behaves incorrectly)
dtostrf(nanNumber, 10, 2, buffer);
Serial.print("NaN : '");
// Incorrect output in the old code: 'NAN ' (Wrong, it's left-aligned!)
Serial.println("\n\n--- width = -10 (Should be left-aligned: spaces BEHIND) ---");
// 3. Normal number (Works correctly)
dtostrf(normalNumber, -10, 2, buffer);
// Output: '12.34 ' (Correctly left-aligned)
// 4. NaN with the bug (Behaves incorrectly)
dtostrf(nanNumber, -10, 2, buffer);
// Incorrect output in the old code: ' NAN' (Wrong, it's right-aligned!)
