Having some trouble compiling AgOpenGPS PANDA
JMky
I am currently attempting to compile a file that others seem to have no problem with and I would like a little push.
I am getting the following errors, specifically the error: 'class HardwareSerial' has no member named 'addMemoryForWrite'
I have installed Arduino 1.8.19 with Teensyduino. I have had the same error in different versions. Hardware is Teensy 4.1, BNO085 IMU , and ZED-F9P rtk gps.
If in wrong area, please advise.
thanks in advance,
Arduino: 1.8.19 (Windows 10), TD: 1.59, Board: "Teensy 4.1, Serial, 450 MHz, Faster, US English"
C:\Users\jmc\Downloads\PandaTPU-main\PandaTPU-main\Teensy4-0_v56_PandaTPU\Teensy4-0_v56_PandaTPU.ino: In function 'void setup()':
C:\Users\jmc\Downloads\PandaTPU-main\PandaTPU-main\Teensy4-0_v56_PandaTPU\Teensy4-0_v56_PandaTPU.ino:202:20: error: 'class HardwareSerial' has no member named 'addMemoryForRead'
202 | SerialGPS->addMemoryForRead(GPSrxbuffer, serial_buffer_size);
C:\Users\jmc\Downloads\PandaTPU-main\PandaTPU-main\Teensy4-0_v56_PandaTPU\Teensy4-0_v56_PandaTPU.ino:203:20: error: 'class HardwareSerial' has no member named 'addMemoryForWrite'
203 | SerialGPS->addMemoryForWrite(GPStxbuffer, serial_buffer_size);
C:\Users\jmc\Downloads\PandaTPU-main\PandaTPU-main\Teensy4-0_v56_PandaTPU\Teensy4-0_v56_PandaTPU.ino:211:21: error: 'class HardwareSerial' has no member named 'addMemoryForRead'
211 | SerialGPS2->addMemoryForRead(GPS2rxbuffer, serial_buffer_size);
C:\Users\jmc\Downloads\PandaTPU-main\PandaTPU-main\Teensy4-0_v56_PandaTPU\Teensy4-0_v56_PandaTPU.ino:212:21: error: 'class HardwareSerial' has no member named 'addMemoryForWrite'
212 | SerialGPS2->addMemoryForWrite(GPS2txbuffer, serial_buffer_size);
Error compiling for board Teensy 4.1.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
quick fix: change occurences of "HardwareSerial" to "HardwareSerialIMXRT".
Proper fix: contact the author of the project and tell them to update their code to match Teensyduino updates.
(Note that there is a comment at the top of the source code saying to use Teensyduino 1.57, because 1.58 doesn't work and future versions are unknown...)
Thanks,
That solved the compile errors, still no PANDA sentences.
I see the PANDA 5 setup may not be final and I may have to go with the AIO board if I want AgOpenGPS with IMU.
I really appreciate the quick response. I hope to be able to add to the community farther down the road.
