I built a basic "Hello world" example to try the CAN functionality using 2 teensy3.1s and 2 MCP2551 CAN drivers:
Transmitter teensy (USB connected to PC): On the click of the button, a 1 byte message is sent to the bus.
Receiver teensy (USB connected to power adapter): Blink the LED when any message is detected.
It is not working:
On the 1st button click the CANbus.write returns 1(success), on all subsequent clicks it returns 0(fail) and also the led blinks for the length of the timeout.
For me this means it can't transmit the content of the transmit buffer (only one buffer is used when timeout>0, and the number of successes is 8 if I use 0 timeout)
One thing I ask is the usual question: Anybody any idea what could be wrong?
Another thing I ask is ideas to debug the thing:
- Can I retreive an error code that tells me what the exact problem was? (e.g. the message could not be started, or didn't receive ack, ...)
- Is there a way (other than buying an oscilloscope) to check parts of the system (e.g. I could check the transmitter side alone, if it didn't expect an ack from the receiver)
(using arduino+teensyduino+FlexCAN library on Win XP)
Thanks
Andras
It is not working:
//#define receive_CAN 0
#define transmit_CAN 0
#ifdef transmit_CAN//-------------TRANSMITTER -------------------
#include <FlexCAN.h>
#include <kinetis_flexcan.h>
#define BUTTON 0
FlexCAN CANbus(50000);
CAN_message_t msg;
int x;
CANbus.begin();
pinMode(BUTTON,INPUT_PULLUP); // Button to GND
pinMode(LED_BUILTIN,OUTPUT); // LED
while(digitalRead(BUTTON)); //Wait falling edge
digitalWrite(LED_BUILTIN,HIGH); //blink while transmitting
msg.buf[0]= 1;
msg.len = 1;
msg.timeout=100;
msg.id = 1;
x=CANbus.write(msg);
Serial.write(x+48); //1:success, 0:fail
digitalWrite(LED_BUILTIN,LOW);
delay(50); // Button debounce
while(!digitalRead(BUTTON));
#ifdef receive_CAN//-------------RECEIVER -------------------
FlexCAN CANbus(500000);
CAN_message_t rxmsg;
CANbus.begin();
if (CANbus.read(rxmsg)){
digitalWrite(LED_BUILTIN,HIGH); //blink LED
delay(10);
delay(10);
Thanks
Andras
