Help implementing full USB Audio Class 2.0 (UAC2) async on Teensy 4.1 (32-bit / 786 kHz)
krilix
Hi all,
I’m working with Teensy 4.1 (i.MX RT1062) and I’d like to attempt a custom, true USB Audio Class 2.0 implementation.
I understand the current Teensy USB audio support is closer to UAC1 / adaptive, and that full async UAC2 is not officially supported. I’m intentionally looking beyond the stock implementation and am prepared to maintain a custom core if needed.
My target goals:
  • Full UAC2 descriptors
  • Asynchronous mode (device-driven clock with feedback endpoint)
  • USB → I2S output to an external DAC
  • 32-bit audio
  • Sample rates up to 768 kHz / 786 kHz (experimentally, even if not all hosts support it)
What I’m hoping to get guidance on:
  • Which core files are best to modify (usb_desc.c, usb_audio.c, others?)
  • Any known limitations of the RT1062 USB device controller for async UAC2
  • Handling feedback endpoints correctly on Teensy
  • Strategies to decouple USB SOF timing from audio processing
  • Practical bandwidth and buffering limits at very high sample rates
I know these rates are extreme and not guaranteed across all hosts. This is partly experimental and partly to understand the true limits of the platform.
If anyone has attempted partial UAC2 support, async feedback, or high-bit rate USB audio on Teensy, I’d really appreciate any pointers or warnings before I go too far.
ps: i found this repo on github "https://github.com/laiudm/laiudm-Teensy4-192k-USB-Audio/tree/main" which changes core and desc files im hoping that we can get fiels for full uac 2 and hopefully that works
I'm curious which DAC chip you would use?
But to answer about whether it's possible, the first big issue I see is the I2S maximum BCLK frequency. The maximum is 25 MBit/sec. A 64 bit frame size (32 bits for each left and right) at 768 kHz would require 49.152 Mbit/sec.
Thanks Paul, for the clarification.
Given the I2S BCLK limit, I agree that 32-bit stereo at 768 kHz is not feasible. Reworking the numbers, 32-bit stereo at 384 kHz would require:
  • 64-bit frame (32 L + 32 R)
  • 384 kHz × 64 = 24.576 Mbit/s
Which appears to be right at the upper edge of the SAI/I2S capability on RT1062.
If staying at or below ~24–25 Mbit/s BCLK, would 32-bit / 384 kHz stereo I2S be considered realistic on Teensy 4.1, assuming careful clocking and minimal overhead?
For DACs, I’m considering parts that accept standard 32-bit I2S at 384 kHz "ESS" prolly ess9038q2m or ess9039q2m, so no unusual framing beyond classic stereo I2S.
Thanks again for pointing out the hard limit, it helped narrow the design space considerably.
You may want to take a look at this thread. I’ve had USB running at 96k/8 channels/16 bit, so it’s on the way. Barring hardware constraints for your codec, of course.
Yes, I believe it should be feasible. You'll need to dive into the USB and I2S code, but the existing code should give you a pretty good starting point.
Isochronous protocol on every microframe should be packet size of 384 bytes, which is well under the 1024 byte limit.
I can't think of any hardware or other hard limits you'll face. This data rate isn't terribly fast. Especially if you're just having the USB hardware dump raw data into buffers, even if you memory to memory copy all the data a couple times into the buffers the I2S hardware reads with DMA, you'll need only a small fraction of Teensy 4.x CPU power.
However, one part of what you've said doesn't make sense to me:
You're saying you want async mode, but the description is of adaptive mode.
Thanks Paul, that’s helpful and I see where my wording caused confusion.
What I’m ultimately aiming for is true asynchronous USB audio, where the audio sample clock is generated locally on the device (from an audio PLL / external oscillator), and the USB host is kept in sync via a feedback endpoint, as defined in UAC2.
In my previous description I mixed that up with adaptive behavior. To clarify:
  • Adaptive mode: device clock tracks USB SOF rate
  • Asynchronous mode: device runs its own clock and reports rate back to host via feedback endpoint
My intent is the second case.
For the initial implementation, I agree that starting from the existing Teensy USB audio code makes sense, especially since the data rate for 32-bit / 384 kHz stereo is modest and well within USB HS isochronous limits, as you pointed out.
The main work I expect is:
  • Modifying descriptors to expose async endpoints
  • Implementing feedback endpoint handling
  • Decoupling I2S clocking from USB SOF timing
Thanks for confirming there aren’t obvious hardware limits at this rate, that gives me confidence the remaining challenges are mostly architectural and software-side.
That's what we already implement.
Indeed.
And I’ll reiterate, a huge amount of work has been done on improving the existing Teensyduino implementation, which you can find discussed and linked to in this thread.
UAC2 is already done, up to 96k/8 channel/16bits has been tested and works, which is much closer to your desired rate than stock 44/2/16, and slot sizes of 16 or 24 bits are catered for. I’ve not tested 24-bit data, but I think someone did. I do know that the feedback implementation is measurably better.
I think you’ll be able to save quite a lot of this effort if you take a closer look at existing code, and try it out to see where extensions are needed for your purposes. @alex6679 has done most of the heavy lifting on this, and while he doesn’t have a lot of spare bandwidth right now, he is pretty responsive if you have a specific demonstrable issue. My contribution has been mostly to generate the issues :devilish: … though I do have a few PRs to my credit, too.
Thanks, that’s very useful context.
I hadn’t fully appreciated how far the existing work had progressed beyond stock Teensyduino. Knowing that UAC2 async with feedback is already working and tested up to 96 kHz / 8 channels / 16-bit, with improved feedback stability, definitely changes the starting point.
Given that, my plan is less about re-architecting and more about extending what’s already there, specifically toward:
  • Higher sample rates (targeting 384 kHz stereo)
  • Wider slot sizes (32-bit containers)
  • Verifying where the practical limits appear (USB side vs SAI/I2S side)
I’ll take a closer look at the code and the linked thread, and try to get it running first before attempting any extensions. Once I can reproduce the existing behavior, I should have a much clearer idea of what actually needs changing versus what’s already solved.
If and when I hit a concrete limitation or regression at higher rates, I’ll try to narrow it down to a specific, demonstrable issue before reaching out.
Thanks again for pointing this out, it likely saves a lot of duplicated effort.
For context, part of my motivation here is that I’ve already implemented a full UAC2 asynchronous device on STM32H723, including:
  • Async isochronous endpoints with feedback
  • Device-driven audio clock
  • High sample rates
  • USB → SAI with DMA
So I’m reasonably familiar with the UAC2 model and the feedback side of things, but I’m still very new to the Teensy codebase and RT1062 specifics. My hope is that, by building on the existing Teensy UAC2 work, I can focus mainly on understanding where the architectural limits are rather than redoing solved problems.
I’m not suggesting this as a drop-in solution for Teensy, but rather as a working reference for UAC2 async behavior, especially around descriptor layout and feedback handling. I’m sharing it in case any parts are useful for comparison while I get familiar with the RT1062 USB and audio code.
My intention is to first bring up the existing Teensy UAC2 implementation as-is, then see where extensions are actually needed for higher rates on this platform.
Happy to clarify or answer questions about the STM32 side if that helps.
Thanks again, this is really helpful.
Moderator edit: file "uac_2 stm32h723.zip" deleted at author's request
Sorry, let me clarify that wording.
I’ve been using Teensy boards for ~6 years, including Teensy 3.x and 4.x, and I currently have several Teensy 4.1 boards here. I’ve worked extensively with the Audio Library and the existing USB audio examples.
When I said “getting familiar with the RT1062 USB and audio code”, I specifically meant the lower-level implementation details (USB descriptors, endpoint handling, and SAI/USB interaction on RT1062), not the Teensy platform or audio framework in general.
So this isn’t a first-time bring-up situation, it’s more about digging deeper into the internals before extending them.
I'm curious where you ended up with this. I've written a very slimmed down floating point-based audio pipeline supporting multiple sampling rates. I modified the stock I2S inputs and outputs and it works like charm at least up to 192kHz and probably beyond. But I kind of hit a brick wall trying to write an USB input to go with it. Well... I sort of have it working, but it involves hacking the descriptors and guesstimating the sampling rate. It's here: https://github.com/prydin/param-eq/tree/main/dsp/src/audio_pipeline (I should probably be a good boy and include Paul's copyright notice on some of the files that are based on his work. Consider it done...)
Anyway... I'd be interested in knowing how other folks have attacked this!
Heyy im back with few questions im facing problems with
1.Can I bypass the AudioStream framework and directly interface USB audio buffers to SAI (I2S) using EDMA?
Are there examples of using SAI + DMA without the Audio library abstraction?
2. What is the recommended way to configure SAI (I2S) with EDMA manually on Teensy 4.1?
Are there low-level examples (without Audio library) for continuous DMA-driven audio transmission?
3.How is the SAI clock derived on Teensy 4.1, and can it be tuned for precise audio rates (e.g., 44.1k/48k families at high multiples)?
Is it possible to use an external MCLK or adjust PLL settings for tighter synchronization with USB feedback?
4.Where in the Teensy USB stack can I directly access incoming isochronous audio packets before they enter the Audio library pipeline?
I want to route USB data into a custom buffer system.
Wow, so many questions. Here's an attempt at a quick answers
Sure. This is essentially bare metal programming. You can do anything you want!
No. Or probably not, for a few reasons.
USB has its own bus master DMA, so it doesn't use the EDMA controller at all.
The data format might be different.
USB might deliver different number of samples in each packet, depending on recent isochronous rate feedback. Usually EDMA is configured to send a fixed size buffer.
Not really. Maybe NXP's code? There have been some forum conversations about alternate ways to use SAI, like the guy who build a (rather dangerous) laser etching machine.
Well, to state the overly obvious, the audio library (which uses AudioStream) is definitely the recommended way.
Again, not really.
Yes, PLL4 gives fine grain resolution. See 14.6.1.3.4 on page 1028 in the reference manual, and also page 1106 for the actual registers.
External MCLK, no. EDIT: maybe. IOMUXC_GPR_GPR1 info on page 326 seems to suggest MCLK might be able to work as an input. How to use it that way, I have no idea.
External BCLK, yes. See the slave mode I2S stuff in the audio library.
Adjusting PLL4 while everything is running, unknown. On pages 1029-1032 you can find stuff about clock switching and bypass for the other PLLs for system buses, but it's unclear (at least to me) whether any of that applies to PLL4 for audio. If you experiment with this, I hope you'll share whatever you learn. Maybe it'll help others who also want to adjust the audio clock?
The file you need to edit in the core library is named usb_audio.cpp.
I understood but there something I need you to take a look
1. Given that USB delivers variable packet sizes and EDMA for SAI typically uses fixed transfer sizes, what is the recommended pattern to bridge these domains?
Is it acceptable to:
- accumulate USB packets into a software ring buffer
- feed EDMA with fixed-size chunks from that buffer
Or is there a more efficient mechanism within the Teensy framework?
2.Given that USB delivers variable packet sizes and EDMA for SAI typically uses fixed transfer sizes, what is the recommended pattern to bridge these domains?
3.For low-latency and high sample rate use (beyond typical Audio library constraints), is there a supported way to bypass AudioStream and directly control SAI + EDMA while still using the USB stack?
Or would this require modifying core files?
4.Does the current USB audio implementation support custom feedback endpoint behavior for precise rate matching?
If not, which parts of the USB stack would need modification to implement custom feedback control?
I’m aiming to build a high-sample-rate UAC2 pipeline with explicit buffer control rather than relying on AudioStream, so I’m trying to understand the correct integration points before modifying the core.
If you want to write software differently that what's already provided, you need to dive into the technical details and make your own decisions regarding these many design choices. The existing code is open source, so maybe it can help. I can sometimes answer questions about how the hardware and published code works. But my time is quite limited. I just can't get heavily involved in the details of how you would write your own code to do essentially the same thing. Most of these questions are things you need to answer for yourself by exploring the deeper technical details.
