TomChiron
Using a Teensy 4.1 just as a Soundcard to get one microphone signal into a Raspberry Pi looks like overkill to me - especially considering the goal of that great project idea to have a system as cheap as possible. I have no experience with Raspberries, but I am sure there would be other solutions which fulfill the need to have it small. There should be boards/ shields which even would make the building of the system easiert than dealing with a Teensy.
From the datasheet the AOM5024 seems to have a really good signal to noise ratio. The 80dB sound a bit too good to be true. Point is that there are many other small microphone capsules even in a range of 60dB S/N-ratio in the datasheet which should be sufficient. For example, you can make excellent recordings with the Panasonic WM61A which is not longer produced. According to Digikey a substitute would be the POM-3535L-3-R.
From the signal quality, i.e. mainly looking at the frequency response, all small microphone diagrams give a flat = linear response because that is physics.
I expect it to be more challenging to have a good mechanical protection from moisture and to have something to supress wind noise. A huge advantage of omnidirectional microphones is here that they are far less sensitive to that.
Another thing could be structure borne noise. When the housing of the system is mountend in a way that it can vibrate, move, or can take noise over from the mounted structure that could be a problem. But I would not expect too many problems here.
