I'm making the project "Audio Guessbook" from this tutorial:
I'm using a Teensy 4.0 with an Audio Shield similar to the tutorial.
Everything work fine exept: a noise coming from the function "frec.write(buffer, sizeof buffer);" when recording a message.
Look like the noise is synchro to the led of the Teensy 4.0 just below the SD Card.
Here what I've checked so far:
- wiring look ok, visually checked multiple time
- no error in code
- used different power supply (from mac & normal plug)
- used a ground isolator
- tested 3 differents mic
- used different card sd (32gb can't write on it but can read - 16gb doesn't work - a 128MB work fine)
- wire directly to the teensy without passing by the phone card
I'm asking for any help - the wedding is in one week and I'm just out of solution... :/
Here is a link to the noise:
https://www.dropbox.com/scl/fi/4zfo93ejl3r3lstv99qm2/noise.mp3?rlkey=3u7ziepf4urqj0grsosggsu9l&dl=0
Thanks.
- no error in code
Thanks.
