I'm running into an issue in a MIDI controller project I'm working on. I'm trying to make an MPE controller that will send pitch bend data over 8 channels of MIDI. But for some reason, I can only send 2 channels at a time. Every time I introduce a third channel, the program completely crashes.
Is there something I'm missing about the MIDI library that I need to address to be able to do this?
Here's a condensed version of the code. I'm using a serial output on the Teensy 4.1.
Any help would be greatly appreciated.
#include <MIDI.h>
// DIN MIDI
MIDI_CREATE_INSTANCE(HardwareSerial, Serial3, MIDI);
MIDI.begin();
updateSlider(1, analogRead(A0));
updateSlider(2, analogRead(A1));
updateSlider(3, analogRead(A2));
updateSlider(4, analogRead(A3));
updateSlider(5, analogRead(A4));
updateSlider(6, analogRead(A5));
updateSlider(7, analogRead(A6));
updateSlider(8, analogRead(A7));
void updateSlider(byte sliderNumber, int value) {
int osc1Bend,
osc2Bend,
osc3Bend,
osc4Bend,
osc5Bend,
osc6Bend,
osc7Bend,
osc8Bend;
// Pitch bend goes from -8192 to +8192.
// The MPE standard is 48 semitones for a full pitch up/down.
int pitchBendMultiplier = 8192 / 48;
switch (sliderNumber) {
case 1:
osc1Bend = map(value, 0, 1023, 0, 3 * pitchBendMultiplier);
MIDI.sendPitchBend(osc1Bend, sliderNumber);
case 2:
osc2Bend = map(value, 0, 1023, 0, 3 * pitchBendMultiplier);
MIDI.sendPitchBend(osc2Bend, sliderNumber);
case 3:
osc3Bend = map(value, 0, 1023, 0, 3 * pitchBendMultiplier);
MIDI.sendPitchBend(osc3Bend, sliderNumber);
case 4:
osc4Bend = map(value, 0, 1023, 0, 3 * pitchBendMultiplier);
MIDI.sendPitchBend(osc4Bend, sliderNumber);
case 5:
osc5Bend = map(value, 0, 1023, 0, 3 * pitchBendMultiplier);
MIDI.sendPitchBend(osc5Bend, sliderNumber);
case 6:
osc6Bend = map(value, 0, 1023, 0, 3 * pitchBendMultiplier);
MIDI.sendPitchBend(osc6Bend, sliderNumber);
case 7:
osc7Bend = map(value, 0, 1023, 0, 3 * pitchBendMultiplier);
MIDI.sendPitchBend(osc7Bend, sliderNumber);
case 8:
osc8Bend = map(value, 0, 1023, 0, 3 * pitchBendMultiplier);
MIDI.sendPitchBend(osc8Bend, sliderNumber);
