rajhefondo
Hi.
We are working for our Air Quality monitoring using ARDUINO BOARD.
We are using GPS(SkyNav EG25A1), SD CARD and Temperature Sensor.
We still dont have the important gasses but we are having trouble with our GPS and SD CARD.
PROBLEM in GPS:
1) The time we are getting is alternating with the GMT+8 that we put in the code and the UTC.
Because we need the constant GMT+8(PHILIPPINES TIME) not the UTC.
Example:
Time: 12:04:36
Time: 12:04:37
Time: 4:04:38
Time: 12:04:39
Time: 4:04:40
Time: 4:04:41
2) The Date is too long to updated sometimes it doesnt update.
PROBLEM in SD CARD:
1) I think his process in saving is so delayed.
2) And the FILE_WRITE is not exactly like in the SERIAL MONITOR. The data being saved is being duplicated
Example:
[OUTPUT IN SERIAL MONITOR]
Time: 12:04:36
Time: 12:04:37
Time: 4:04:38
Time: 12:04:39
Time: 4:04:40
Time: 4:04:41
[OUTPUT IN SD CARD]
Time: 12:04:36
Time: 12:04:36
Time: 12:04:36
Time: 12:04:36
Time: 12:04:36
Time: 12:04:36
Time: 12:04:37
Time: 12:04:37
Time: 12:04:37
Time: 12:04:37
Time: 12:04:37
Time: 4:04:38
Time: 4:04:38
Time: 4:04:38
Time: 4:04:38
Time: 4:04:38
Time: 4:04:38
Time: 12:04:39
This is the code that we use:
Please help me, thank you in advance.
I think that my library is not that updated or I don't know maybe the problem is still in the code.
Maybe not proper grouping of codes, the process that I want is not doing it.
PROBLEM in GPS:
Example:
Time: 12:04:36
Time: 12:04:37
Time: 4:04:38
Time: 12:04:39
Time: 4:04:40
Time: 4:04:41
PROBLEM in SD CARD:
Example:
Time: 12:04:36
Time: 12:04:37
Time: 4:04:38
Time: 12:04:39
Time: 4:04:40
Time: 4:04:41
[OUTPUT IN SD CARD]
Time: 12:04:36
Time: 12:04:36
Time: 12:04:36
Time: 12:04:36
Time: 12:04:36
Time: 12:04:36
Time: 12:04:37
Time: 12:04:37
Time: 12:04:37
Time: 12:04:37
Time: 12:04:37
Time: 4:04:38
Time: 4:04:38
Time: 4:04:38
Time: 4:04:38
Time: 4:04:38
Time: 4:04:38
Time: 12:04:39
#include <TinyGPS++.h> //GPS library
#include <SoftwareSerial.h> //GPS
#include <Time.h> //GPS
/*Choose two Arduino pins to use for software serial
The GPS Shield uses D2 and D3 by default when in DLINE mode*/
int chipSelect = 4; //Set chipSelect=4
File AQ_GPSTemp_Data; //variable for working with our file object
//initialization for GPS
static const int RXPin = 2;
static const int TXPin = 3;
//initialization for TempSensor
int val;
int temPin = 1;
float mv;
float cel;
// The Skytaq EM-506 GPS module included in the GPS Shield Kit
static const uint32_t GPSBaud = 9600; //Set GPS Baud Rate
const int UTC_offset = 8; // to correct the GPS UCT time to the Phil. Local Time
int Year;
byte Month;
byte Day;
byte Hour;
byte Minute;
byte Second;
// Create a TinyGPS++ object called "gps"
TinyGPSPlus gps;
// Create a software serial port called "gpsSerial"
SoftwareSerial gpsSerial(RXPin, TXPin);
//initialization for SD
gpsSerial.begin(GPSBaud); //GPS Serial.begin
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// see if the card is present and can be initialized
if (!SD.begin(chipSelect)){
Serial.println("Card failed, or not present");
//dont do anything
return;
Serial.println("card initialized.");
pinMode(10, OUTPUT); //Reserve pin 10 as an output
SD.begin(4); //initialize the SD card with chipSelectect connected in pin 4
//MAIN LOOP
// This sketch displays information every time a new sentence is correctly encoded.
while (gpsSerial.available() > 0) //enabling the GPS Module
if (gps.encode(gpsSerial.read()))
displayInfo(); //Provide the corresponding readings from the different sensors
AQ_GPSTemp_Data= SD.open("GPSData.txt", FILE_WRITE); //Open AirQuality_GPSandTEMP_Data.text on the SD card
//as a file to write the readings
if (AQ_GPSTemp_Data){
AQ_GPSTemp_Data.print(F("Location: "));
AQ_GPSTemp_Data.print(gps.location.lat(), 6); //latitude
AQ_GPSTemp_Data.print(F(","));
AQ_GPSTemp_Data.print(gps.location.lng(), 6); //longitude
AQ_GPSTemp_Data.print(F(" Date/Time: "));
AQ_GPSTemp_Data.print(gps.date.month()); //month
AQ_GPSTemp_Data.print(F("/"));
AQ_GPSTemp_Data.print(gps.date.day()); //day
AQ_GPSTemp_Data.print(gps.date.year()); //year
AQ_GPSTemp_Data.print(F(" "));
AQ_GPSTemp_Data.print(Hour); //hour
AQ_GPSTemp_Data.print(F(":"));
AQ_GPSTemp_Data.print(Minute); //minute
AQ_GPSTemp_Data.print(Second); //second
AQ_GPSTemp_Data.print(" TEMPERATURE=");
AQ_GPSTemp_Data.print(cel); //temp in degree celsius
AQ_GPSTemp_Data.println("*C");
AQ_GPSTemp_Data.close(); //close the file
/* If 5000 milliseconds pass and there are no characters coming in
over the software serial port, show a "No GPS detected" error*/
if (millis() > 5000 && gps.charsProcessed() <10)
Serial.println(F("No GPS detected"));
while(true);
void displayInfo() //Display Readings from sensors
GPSLocation(); //GPS latitude and Longitude
GPSDate(); //GPS Date in MM/DD/YY format
GPSTime(); //GPS Phil. time in HH:MM:SS format
TempSensor(); //Read Temperature Sensor
//Functions in the [displayInfo()].
void GPSLocation() //Location of the GPS
Serial.print(F("Location: "));
if (gps.location.isValid()) //checks if there is any valid information for the location
Serial.print(gps.location.lat(), 6); // Latitude
Serial.print(F(","));
Serial.print(gps.location.lng(), 6); // Longitude
Serial.print(F("INVALID")); // no valid info
void GPSDate() //Current Date
Serial.print(F(" Date/Time: "));
if (gps.date.isValid()) //checks if there is any valid information for the date
Serial.print(gps.date.month()); //month
Serial.print(F("/"));
Serial.print(gps.date.day()); //day
Serial.print(gps.date.year()); //year
Serial.print(F("INVALID")); //no valid info
void GPSTime() //Current Time
Serial.print(F(" "));
if (gps.time.isValid()&& gps.date.isValid()) //checks if there is any valid information for the time
Year = gps.date.year();
Month = gps.date.month();
Day = gps.date.day();
Hour = gps.time.hour();
Minute = gps.time.minute();
Second = gps.time.second();
setTime(Hour,Minute,Second,Day,Month,Year); // Set Time from GPS data string
adjustTime(UTC_offset * SECS_PER_HOUR); //Calculate current Time Zone time by offset value
Year = year();
Month = month();
Day = day();
Hour = hour();
Minute = minute();
Second = second();
if (Hour < 10) Serial.print(F("0"));
Serial.print(Hour); //hour
Serial.print(F(":"));
if (Minute < 10) Serial.print(F("0"));
Serial.print(Minute); //minute
if (Second < 10) Serial.print(F("0"));
Serial.print(Second); //second
void TempSensor() //ambient temperature
val = analogRead(temPin);
mv = (val/1024.0)*5000;
cel = mv/10;
Serial.print(F(" TEMPERATURE = "));
Serial.print(cel); //temperature value in degree Celcius
Serial.print(F("*C"));
