egyptiandude93
Hi everyone, first time posting, thank you for reading my thread. I am trying to use the teensy 3.0 to record values from an analog input. The problem is I can't seem to get the teensy to read faster than 1khz. Ideally I need to be able to sample at a minimum of 10khz (enough to graph a 10khz sine wave) and write the values to a text file. I tried using arduino's analog read, and then using a separate program to log the data from the serial port in a text file, but it is still not fast enough. Any help you can give would be greatly appreciated.
-egyptiandude
-egyptiandude
