I am thinking use of PSRAM chip with teensy 4.1 . before buy chip , i want to ask .,,, if a drum pattern .wav is being played in loop_mode from SD card using [TeensyVariablePlayback] . can i play drum sample together it in polyphony mode by load drum samples .raw files from sd card to PSRAM 8mb.
how fast play accuracy ??? is it fast than direct play .wav from sd card like professional octapad???
how much / how long .raw sample can be load into psram ??? like length & size of sample???
how much time take it in load from sd to psram accord length & size of sample???
when samples are being loaded ,will current running .wav file be affected ??
PSRAM chip Please check this is it ths one ???
as shown in this pic......
on which location chip should be solder "A" or "B" ?
if any one of both can be use .
i have to modify .wav files on sd card from pc .. in future if sd card slot missing pins by repetitively remove & insert sd card . can i use any external sd card board with jumper wires to teensy 4.1??
i will place order for PSRAM chip after your suggestion ..
thank you....
thank you....
