// Converted to only 1 buffer per ADC, reduced to a small example.
//Based on Example by SaileNav
#include "DMAChannel.h"
#include "ADC.h"
#define BUF_SIZE 256
ADC *adc = new ADC(); // adc object
DMAChannel* dma0 = new DMAChannel(false);
DMAChannel* dma1 = new DMAChannel(false);
DMAChannel* dma2 = new DMAChannel(false);
DMAChannel* dma3 = new DMAChannel(false);
//ChannelsCfg order must be {CH1, CH2, CH3, CH0 }, adcbuffer output will be CH0, CH1, CH2, CH3
//Order must be {Second . . . . . . . . First} no matter the number of channels used.
const uint16_t ChannelsCfg_0 [] = { 0x47, 0x4F, 0x44, 0x46 }; //ADC0: CH0 ad6(A6), CH1 ad7(A7), CH2 ad15(A8), CH3 ad4(A9)
const uint16_t ChannelsCfg_1 [] = { 0x45, 0x46, 0x47, 0x44 }; //ADC1: CH0 ad4(A17), CH1 ad5(A16), CH2ad6(A18), CH3 ad7(A19)
const int ledPin = 13;
DMAMEM static volatile uint16_t __attribute__((aligned(BUF_SIZE+0))) adcbuffer_0[BUF_SIZE];
DMAMEM static volatile uint16_t __attribute__((aligned(BUF_SIZE+0))) adcbuffer_1[BUF_SIZE];
volatile int d2_active;
// initialize the digital pin as an output.
pinMode(ledPin, OUTPUT);
d2_active = 0;
pinMode(2, INPUT_PULLUP);
pinMode(4, OUTPUT);
pinMode(6, OUTPUT);
attachInterrupt(2, d2_isr, FALLING);
// clear buffer
for (int i = 0; i < BUF_SIZE; ++i){
adcbuffer_0[i] = 50000;
adcbuffer_1[i] = 50000;
setup_adc();
setup_dma();
elapsedMillis debounce;
while(1){
uint8_t pin = 0;
if(d2_active) pin=1;
if(pin>0){
for (int i = 0; i < BUF_SIZE; i = i + 4){
int a = adcbuffer_0[i];
Serial.print(a);
Serial.print(".");
int b = adcbuffer_0[i+1];
Serial.print(b);
Serial.print(".");
int c = adcbuffer_0[i+2];
Serial.print(c);
Serial.print(".");
int d = adcbuffer_0[i+3];
Serial.print(d);
Serial.print("...");
int e = adcbuffer_1[i];
Serial.print(e);
Serial.print(".");
int f = adcbuffer_1[i+1];
Serial.print(f);
Serial.print(".");
int g = adcbuffer_1[i+2];
Serial.print(g);
Serial.print(".");
int h = adcbuffer_1[i+3];
Serial.println(h);
digitalWrite(ledPin, HIGH); // set the LED on
delay(50); // wait for a second
digitalWrite(ledPin, LOW); // set the LED off
d2_active = 0;
delay(100); // wait for a second
void setup_dma() {
dma0->begin(true); // allocate the DMA channel
dma0->TCD->SADDR = &ADC0_RA; // where to read from
dma0->TCD->SOFF = 0; // source increment each transfer
dma0->TCD->ATTR = 0x101;
dma0->TCD->NBYTES = 2; // bytes per transfer
dma0->TCD->SLAST = 0;
dma0->TCD->DADDR = &adcbuffer_0[0];// where to write to
dma0->TCD->DOFF = 2;
dma0->TCD->DLASTSGA = -2*BUF_SIZE;
dma0->TCD->BITER = BUF_SIZE;
dma0->TCD->CITER = BUF_SIZE;
dma0->triggerAtHardwareEvent(DMAMUX_SOURCE_ADC0);
dma0->disableOnCompletion(); // require restart in code
dma0->interruptAtCompletion();
dma0->attachInterrupt(dma0_isr);
dma1->begin(true); // allocate the DMA channel
dma1->TCD->SADDR = &ChannelsCfg_0[0];
dma1->TCD->SOFF = 2; // source increment each transfer (n bytes)
dma1->TCD->ATTR = 0x101;
dma1->TCD->SLAST = -8; // num ADC0 samples * 2
dma1->TCD->BITER = 4; // num of ADC0 samples
dma1->TCD->CITER = 4; // num of ADC0 samples
dma1->TCD->DADDR = &ADC0_SC1A;
dma1->TCD->DLASTSGA = 0;
dma1->TCD->NBYTES = 2;
dma1->TCD->DOFF = 0;
dma1->triggerAtTransfersOf(*dma0);
dma1->triggerAtCompletionOf(*dma0);
dma2->begin(true); // allocate the DMA channel
dma2->TCD->SADDR = &ADC1_RA; // where to read from
dma2->TCD->SOFF = 0; // source increment each transfer
dma2->TCD->ATTR = 0x101;
dma2->TCD->NBYTES = 2; // bytes per transfer
dma2->TCD->SLAST = 0;
dma2->TCD->DADDR = &adcbuffer_1[0];// where to write to
dma2->TCD->DOFF = 2;
dma2->TCD->DLASTSGA = -2*BUF_SIZE;
dma2->TCD->BITER = BUF_SIZE;
dma2->TCD->CITER = BUF_SIZE;
dma2->triggerAtHardwareEvent(DMAMUX_SOURCE_ADC1);
dma2->disableOnCompletion(); // require restart in code
dma2->interruptAtCompletion();
dma2->attachInterrupt(dma2_isr);
dma3->begin(true); // allocate the DMA channel
dma3->TCD->SADDR = &ChannelsCfg_1[0];
dma3->TCD->SOFF = 2; // source increment each transfer (n bytes)
dma3->TCD->ATTR = 0x101;
dma3->TCD->SLAST = -8; // num ADC1 samples * 2
dma3->TCD->BITER = 4; // num of ADC1 samples
dma3->TCD->CITER = 4; // num of ADC1 samples
dma3->TCD->DADDR = &ADC1_SC1A;
dma3->TCD->DLASTSGA = 0;
dma3->TCD->NBYTES = 2;
dma3->TCD->DOFF = 0;
dma3->triggerAtTransfersOf(*dma2);
dma3->triggerAtCompletionOf(*dma2);
dma0->enable();
dma1->enable();
dma2->enable();
dma3->enable();
void setup_adc() {
//ADC0
adc->setAveraging(1, ADC_0); // set number of averages
adc->adc0->setResolution(12); // set bits of resolution
adc->setConversionSpeed(ADC_MED_SPEED, ADC_0); // change the conversion speed
adc->setSamplingSpeed(ADC_MED_SPEED, ADC_0); // change the sampling speed
//adc->adc0->setReference(ADC_REF_1V2);
//ADC1
adc->setAveraging(1, ADC_1); // set number of averages
adc->adc1->setResolution(12); // set bits of resolution
adc->setConversionSpeed(ADC_MED_SPEED, ADC_1); // change the conversion speed
adc->setSamplingSpeed(ADC_MED_SPEED, ADC_1); // change the sampling speed
//adc->adc1->setReference(ADC_REF_1V2);`
ADC1_CFG2 |= ADC_CFG2_MUXSEL;
adc->adc0->enableDMA(); //ADC0_SC2 |= ADC_SC2_DMAEN; // using software trigger, ie writing to ADC0_SC1A
adc->adc1->enableDMA();
void d2_isr(void) {
if(debounce > 200){
d2_active = 1;
debounce = 0;
else{return;}
void dma0_isr(void) {
dma0->clearInterrupt();
dma0->enable();
digitalWriteFast(4, HIGH);
digitalWriteFast(4, LOW);
void dma2_isr(void) {
dma2->clearInterrupt();
dma2->enable();
digitalWriteFast(6, HIGH);
digitalWriteFast(6, LOW);
