how to play .wav file using Read first 6 charactor in file Name ?????
charnjit
i am playing .wav files using "TeensyVariablePlayback" library
Files are stored on my SD card are like this
in this form i am unable to see what sound in in which fille
if i placed flies in this form
can Teensy play .wav file using read first 6 charactor from file name ang play quicky.
as Read
001_05
only
from file name
001_05  96 x Trikit.wav
ignore 7th char and others.
i hope you understand what i am thinking.
how many charactors (maximum lenth) can be a .wav file name. ???
thank you
I am sorry, this post in your view list.
Perhaps, I am failed to show, what is in my mind about audio library.
Detecting the first 6 characters in the file name is independent of the audio library
Use a regex to read/display the first 6 characters.
Define in your logic if it should be played or not based on a match.
