Hello,
I am new either to can bus and c++, therefore forgive me for asking silly questions, but I am stucked on this issue for 3 weeks now, and I can't find the solution.
I have two teensy boards that have to communicate with each other: one sends messages and the other reads them.
The receiver prints a sort of error message "no data on the bus", everytime read.msg() returns false.
Since the sender transmits signal faster, I expect that there is always a message to read, but instead every now and then I get the message error.
For this reason, I tried to check the bit ACK to verify the reception.
I searched a lot on the internet and finally I found the possibility to check errors using the CAN_error_t message and the function error(). I wrote them in the sender code but at this point I faced another problem.
Even if the receiver is not powered, no error is printed (except at the beginning). I disconnected also one extremity of the can bus, but still no error.
Can someone tell me what I am doing wrong? I expect to see an ACK error without powering the receiver, and some errors like bus off for improper termination of the can bus.
The wirings should be fine, both the teensy boards are equipped with a transciever, and the can bus is terminated with 120 ohm resistor at each end. I think it is a softwer problem, but still can't understand such behavior.
Here below the two codes for the sender and receiver
SENDER:
RECEIVER:
SENDER:
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> myCan;
CAN_error_t Can_err;
while(!Serial);
myCan.begin();
myCan.setBaudRate(1000000);
Serial.println("initialized");
// sender
CAN_message_t msg;
msg.id=0x001;
msg.flags.extended=0;
msg.len=5;
Serial.print("message ID: 0x");
Serial.println(msg.id);
msg.buf[0]='h';
msg.buf[1]='e';
msg.buf[2]='l';
msg.buf[3]='l';
msg.buf[4]='o';
myCan.write(msg);
myCan.error(Can_err,true);
RECEIVER:
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> can1;
CAN_message_t msg;
while (!Serial);
can1.begin();
can1.setBaudRate(1000000);
Serial.println("FlexCan_T4 initialized for rec");
can1.enableFIFO();
can1.mailboxStatus();
if (can1.read(msg)){
Serial.print("ID: 0x");Serial.print(msg.id, HEX);
Serial.print("|");
Serial.print("buffer: ");
for (int i=0; i<msg.len; i++){
Serial.print(char (msg.buf[i]));}
Serial.println(" ");
Serial.println("No data on the bus");
delay(2000);
