How to route audio to read timecode data
mellos
I'm trying to read linear timecode data on the Teensy Audio Shield line in (3.5mm) using a Teensy 4.1 FrankB's LinearTimecodeDecoder library (https://github.com/FrankBoesing/LinearTimecode-Decoder). However, despite this working last night it no longer works today....
I was able to get this sketch working well for a while but then it stopped working even though I didn't change anything. The audio shield and teensy are running fine with other examples. To make my sketch, I modified the ltc_usb example and added support for the audio shield. I have a feeling my audio routing isn't correct but maybe something else is a miss.
/* Linear Timecode for Audio Library for Teensy 3.x / 4.x
   USB-Audio Example
   Copyright (c) 2019, Frank Bösing, f.boesing (at) gmx.de
   Development of this audio library was funded by PJRC.COM, LLC by sales of
   Teensy and Audio Adaptor boards.  Please support PJRC's efforts to develop
   open source software by purchasing Teensy or other PJRC products.
   Permission is hereby granted, free of charge, to any person obtaining a copy
   of this software and associated documentation files (the "Software"), to deal
   in the Software without restriction, including without limitation the rights
   to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
   copies of the Software, and to permit persons to whom the Software is
   furnished to do so, subject to the following conditions:
   The above copyright notice, development funding notice, and this permission
   notice shall be included in all copies or substantial portions of the Software.
   THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
   IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
   FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
   AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
   LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
   OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
   THE SOFTWARE.
 https://forum.pjrc.com/threads/41584-Audio-Library-for-Linear-Timecode-(LTC)
 LTC example audio at: https://www.youtube.com/watch?v=uzje8fDyrgg
 Howto: Set USB-Type to USB-Audio, on PC: Play LTC Audio and set autio-output to use Teensy as audio-device.
#include <analyze_ltc.h>
const int lineIn = AUDIO_INPUT_LINEIN;
AudioInputI2S       audioInput;
AudioOutputI2S      output;
AudioAnalyzeLTC     ltc1;
// Create Audio connections between the components
AudioConnection patchCord1(audioInput, 0, output, 0);
AudioConnection patchCord2(audioInput, 1, output, 1);
AudioConnection patchCord3(audioInput, 0, ltc1, 0);
ltcframe_t ltcframe;
  AudioMemory(12);
  audioShield.enable();
  audioShield.inputSelect(lineIn);
  audioShield.volume(1);
  if (ltc1.available()) {
    ltcframe = ltc1.read();
    Serial.printf("%02d:%02d:%02d.%02d\n", ltc1.hour(&ltcframe), ltc1.minute(&ltcframe), ltc1.second(&ltcframe), ltc1.frame(&ltcframe));
Turns out that my auxiliary port must not work anymore because soldering directly to the line in pins works fine.
