fouzi
Title: How to Trick Wokwi to Emulate an Unsupported Teensy 4.0? (Hardware & Software Emulation)
The Problem:
I wanted to develop a project combining the Teensy 4.0, the Teensy Audio Shield Rev D, and a TFT ILI9341 Screen. However, Wokwi emulator does not support Teensy 4.0, and the Audio Shield is missing as a visual component in the simulator.
The Creative Solution (The Trick):
Instead of giving up, I designed a workaround using Blind Hardware Emulation. I used the powerful ESP32-S3 chip as a substitute and reconfigured its hardware through a smart combination of wiring and programming:
Once the audio pins were secured, I utilized the remaining free pins (GPIO 21, 3, 7) to connect and successfully boot the TFT screen without any interference!
The Ultimate Benefit: This entire project setup (Schematic & Code) is 100% ready to be ported directly to a real Teensy 4.0 hardware. It will work instantly because we resolved all electronic and software conflicts beforehand inside the emulator!
The Problem:
- Hardware Mapping:
I carefully studied the pinout datasheet of the Teensy 4.0 and Audio Shield, mapping them physically onto the ESP32-S3, keeping the SPI bus open to be shared safely later between the SD card and the screen. - Software Reservation:
I wrote a specific code that acts as a "safety lock." It digitally occupies and reserves all 13 pins required by the Audio Shield (such as I2S, I2C, and Chip Select pins) to keep them busy and protect them from any data or signal conflicts during simulation.
