Here's the diff of usb_desc.c:
Here's an example sketch [Take note of the bold, blue code]:
This seems to be in line with the following text from the "7.1.4.5 Resume" section of the "Universal Serial Bus Specification, Rev. 1.0, January 15, 1996":
"The remote wake-up device must hold the resume signaling for at least 10 ms and no more than 15 ms."
--- usb_desc.c.fail 2014-09-10 13:31:49.000000000 -0700
+++ usb_desc.c 2014-09-15 16:29:19.000000000 -0700
@@ -316,7 +316,8 @@
NUM_INTERFACE, // bNumInterfaces
1, // bConfigurationValue
0, // iConfiguration
- 0xC0, // bmAttributes
+ // daperl 0xC0, // bmAttributes
+ 0xA0, // bmAttributes
50, // bMaxPower
#ifdef CDC_IAD_DESCRIPTOR
/* Buttons to USB Keyboard Example - Special Media Player Keys
You must select Keyboard from the "Tools > USB Type" menu
#include <Bounce.h>
// Create Bounce objects for each button. The Bounce object
// automatically deals with contact chatter or "bounce", and
// it makes detecting changes very simple.
Bounce button0 = Bounce(0, 10);
Bounce button1 = Bounce(1, 10); // 10 ms debounce time is appropriate
Bounce button2 = Bounce(2, 10); // for most mechanical pushbuttons
Bounce button3 = Bounce(3, 10);
Bounce button4 = Bounce(4, 10); // if a button is too "sensitive"
Bounce button5 = Bounce(5, 10); // you can increase this time.
// Configure the pins for input mode with pullup resistors.
// The pushbuttons connect from each pin to ground. When
// the button is pressed, the pin reads LOW because the button
// shorts it to ground. When released, the pin reads HIGH
// because the pullup resistor connects to +5 volts inside
// the chip.
//pinMode(0, INPUT_PULLUP);
//pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
//pinMode(5, INPUT_PULLUP);
// Update all the buttons. There should not be any long
// delays in loop(), so this runs repetitively at a rate
// faster than the buttons could be pressed and released.
button0.update();
button1.update();
button2.update();
button3.update();
button4.update();
button5.update();
// Check each button for "falling" edge.
// falling = high (not pressed - voltage from pullup resistor)
// to low (pressed - button connects pin to ground)
if (button0.fallingEdge()) {
Keyboard.set_media(KEY_MEDIA_PREV_TRACK);
Keyboard.send_now(); // send the button press
Keyboard.set_media(0);
Keyboard.send_now(); // send the button release
if (button1.fallingEdge()) {
Keyboard.set_media(KEY_MEDIA_PLAY_PAUSE);
if (button2.fallingEdge()) {
Keyboard.set_media(KEY_MEDIA_NEXT_TRACK);
if (button3.fallingEdge()) {
Keyboard.set_media(KEY_MEDIA_VOLUME_DEC);
if (button4.fallingEdge()) {
[B][COLOR="#0000FF"] uint8_t tmp = USB0_CTL;
USB0_CTL |= USB_CTL_RESUME;
delay(12);
USB0_CTL = tmp;
[/COLOR][/B]#if 0
Keyboard.set_media(KEY_MEDIA_VOLUME_INC);
if (button5.fallingEdge()) {
Keyboard.set_media(KEY_MEDIA_EJECT);
delay(300); // Mac OS-X will not recognize a very short eject press
