defragster
Senior Member+
Two issues with Teensy Ports in IDE:
> Using DUAL or Triple Serial on USB only presents the primary device to connect for SerMon usage.
- Could it recognize and present the second (third) USB port to connect?
> Using IDE 2 Sermon and once connected the Device is not 'released' (on Windows) for use - even when IDE 2 <edit: 2 not 1> Teensy SerMon is closed - by other Serial Monitor apps.
- IDE 2 closing the 'Teensy Ports' SerMon does not allow IDE 1 or TyCommander to connect to that port
-- requires going to TaskMan and killing "Arduino IDE" / teensy-monitor.exe
- then closing in IDE 1 releases it for use in TyCommander.
-- Connecting again with IDE 2 works, but is then again 'HELD' and not usable by other apps while 'teensy-monitor.exe' is active.
