inline void lcdWriteReg (uint8_t reg)
digitalWrite (LCD_DC, LOW);
SPI.transfer (0);
SPI.transfer (reg);
void writecommand_cont(uint8_t c) __attribute__((always_inline)) {
uint16_t d = c;
maybeUpdateTCR(LPSPI_TCR_PCS(0) | LPSPI_TCR_FRAMESZ(15) | LPSPI_TCR_CONT);
_pimxrt_spi->TDR = d;
pending_rx_count++; //
waitFifoNotFull();
beginSPITransaction();
setAddr(x, y, x, y);
writecommand_cont(ILI9488_RAMWR); /// this ILI9388_RAMWR would be replaced with REG or use LAST depending on the function
write16BitColor(color, true);
endSPITransaction();
@mjs513 - Sounds like you are having some fun... Hopefully will get back to this display soon!
@sepp89117 - As we mentioned no idea, What version of Teensyduino? The latest released code has some SPI update to allow longer time from CS assert to start of signal. Maybe needed?
Maybe issues with some of their init commands in python maybe run slower, where on T4 maybe runs faster... Note: with most of our displays there are delays built in after some of the init strings, as a way to allow display to process previous command... You might want to compare your init to existing and see if you need to build in similar delays. Or sometimes it just is bad contacts with jumper wires that can give you a lot of grief.
Looks like you may want to do the following but @KurtE can confirm:
This from the drawpixel function.Code:beginSPITransaction(); setAddr(x, y, x, y); writecommand_cont(ILI9488_RAMWR); /// this ILI9388_RAMWR would be replaced with REG or use LAST depending on the function write16BitColor(color, true); endSPITransaction();
You might want to look at it from a function comparison basis or compare registers.
Now if its really a ILI9486 it might be more compatilble with the ILI9488 library. You might want to see if that works out of the box. Pretty much the same functions that are in the ILI9431 are in the ILI9488 library?
inline void lcdWriteDataRepeat(uint16_t data, unsigned long count)
lcdWriteReg(0x2C); //RAMWR
digitalWrite(LCD_DC, HIGH);
for (unsigned long i = 0; i < count; i++)
SPI.transfer16(data);
inline void lcdWriteDataCount(uint16_t *pData, unsigned long count)
while (count--)
SPI.transfer16(*pData++);
maybeUpdateTCR(LPSPI_TCR_PCS(0) | LPSPI_TCR_FRAMESZ(7) | LPSPI_TCR_CONT);
_pimxrt_spi->TDR = 0;
_pimxrt_spi->TDR = c;
waitFifoNotFull();
void writedata8_cont(uint8_t c) __attribute__((always_inline)) {
maybeUpdateTCR(LPSPI_TCR_PCS(1) | LPSPI_TCR_FRAMESZ(7) | LPSPI_TCR_CONT);
waitFifoNotFull();
void writecommand_last(uint8_t c) __attribute__((always_inline)) {
maybeUpdateTCR(LPSPI_TCR_PCS(0) | LPSPI_TCR_FRAMESZ(7));
waitTransmitComplete();
void writedata8_last(uint8_t c) __attribute__((always_inline)) {
maybeUpdateTCR(LPSPI_TCR_PCS(1) | LPSPI_TCR_FRAMESZ(7));
You don’t need delays anymore like they. There implementation is for rip and completely different. Adding delays will do exactly like what you are seeing
::begin 200010f0 255 255 255
ILI9488_t3::begin - End
ILI9488 Test!
Display Power Mode: 0x0
MADCTL Mode: 0x0
Pixel Format: 0x0
Image Format: 0x0
Self Diagnostic: 0x0
Benchmark Time (microseconds)
Screen fill 615266
Text 12121
Lines 154779
Horiz/Vert Lines 51432
Rectangles (outline) 28580
Rectangles (filled) 1487031
Circles (filled) 182145
Circles (outline) 124185
Triangles (outline) 33620
Triangles (filled) 491821
Rounded rects (outline) 55229
Rounded rects (filled) 1626714
Done!
ILI9488 Test!
MADCTL Mode: 0x0
Pixel Format: 0x0
Image Format: 0x0
Screen fill 615251
Text 10900
Lines 154565
Horiz/Vert Lines 51149
Rectangles (outline) 28389
Rectangles (filled) 1487036
Circles (filled) 177769
Circles (outline) 104362
Triangles (outline) 33453
Triangles (filled) 487330
Rounded rects (outline) 54478
Rounded rects (filled) 1626238
Done!
Orig updated delta delta/orig*100
Screen fill 615266 615251 15 0.00243797
Text 12121 10900 1221 10.07342628
Lines 154779 154565 214 0.13826165
Horiz/Vert Lines 51432 51149 283 0.550241095
Rectangles (outline) 28580 28389 191 0.66829951
Rectangles (filled) 1487031 1487036 -5 -0.00033624
Circles (filled) 182145 177769 4376 2.402481539
Circles (outline) 124185 104362 19823 15.96247534
Triangles (outline) 33620 33453 167 0.496728138
Triangles (filled) 491821 487330 4491 0.913137097
Rounded rects (outline) 55229 54478 751 1.359792862
Rounded rects (filled) 1626714 1626238 476 0.029261444
Sum of times 4862923 4830920 32003 0.658102133
uint16_t _previous_addr_x0 = 0xffff;
uint16_t _previous_addr_x1 = 0xffff;
uint16_t _previous_addr_y0 = 0xffff;
uint16_t _previous_addr_y1 = 0xffff;
void setAddr(uint16_t x0, uint16_t y0, uint16_t x1, uint16_t y1)
if ((x0 != _previous_addr_x0) || (x1 != _previous_addr_x1)) {
writecommand_cont(ILI9488_CASET); // Column addr set
writedata16_cont(x0); // XSTART
writedata16_cont(x1); // XEND
_previous_addr_x0 = x0;
_previous_addr_x1 = x1;
if ((y0 != _previous_addr_y0) || (y1 != _previous_addr_y1)) {
writecommand_cont(ILI9488_PASET); // Row addr set
writedata16_cont(y0); // YSTART
writedata16_cont(y1); // YEND
_previous_addr_y0 = y0;
_previous_addr_y1 = y1;
I can potentially help out with the porting of my optimizations to the ILI9488/ILI9486. At the moment I only have a 3.5" Kuman Uno shield that seems to want 5v signals. My initial test on the Teensy4 failed to make it work. Does anyone here know if they have gotten this display (link below) to work on the Teensy 4 maybe with some mod to the power circuit?
https://www.amazon.com/gp/product/B075FP83V5
Larry B.
Any chance to port these changes to the HX8357 library once you’re satisfied with the results?
Happy to test on the 4.0/4.1. Im using triangles (the gauge sketch you put together for me) and text on the display.
Screen fill 512766 512757 9 0.001755187
Text 113393 97927 15466 13.6392899
Lines 166179 166406 -227 -0.136599691
Horiz/Vert Lines 43599 43266 333 0.763778986
Rectangles (outline) 24406 24182 224 0.917807097
Rectangles (filled) 1239425 1239577 -152 -0.012263751
Circles (filled) 169231 164399 4832 2.855268834
Circles (outline) 136611 112142 24469 17.91144198
Triangles (outline) 35298 35191 107 0.303133322
Triangles (filled) 421949 416593 5356 1.269347717
Rounded rects (outline) 55128 53980 1148 2.082426353
Rounded rects (filled) 1365167 1364834 333 0.02439262
Sums 4283152 4231254 51898 1.211677755
#if 1
writecommand(ST7735_CASET); // Column addr set
writedata16(x0+_xstart); // XSTART
writedata16(x1+_xstart); // XEND
writecommand(ST7735_RASET); // Row addr set
writedata16(y0+_ystart); // YSTART
writedata16(y1+_ystart); // YEND
#else
BEFORE AFTER
Rotations 0 1 0 1
tftPrintTest: 1611 1611 1610 1610
testlines: 536 535 535 535
tftPrintTest: 73 73 73 74
testdrawrects: 65 71 65 70
tftPrintTest: 593 1199 592 1199
testfill/drawcircles: 204 205 191 190
testroundrects: 124 123 121 122
testtriangles: 73 80 74 79
mediabuttons: 1115 1114 1115 1115
Totals: 4394 5012 4376 4995
Awesome. Will update this week and test.I just pushed up a change back to @mjs513... Again not breathtaking speed ups, but...
With T4.1Code:Orig updated delta delta/orig*100 Screen fill 512766 512757 9 0.001755187 Text 113393 97927 15466 13.6392899 Lines 166179 166406 -227 -0.136599691 Horiz/Vert Lines 43599 43266 333 0.763778986 Rectangles (outline) 24406 24182 224 0.917807097 Rectangles (filled) 1239425 1239577 -152 -0.012263751 Circles (filled) 169231 164399 4832 2.855268834 Circles (outline) 136611 112142 24469 17.91144198 Triangles (outline) 35298 35191 107 0.303133322 Triangles (filled) 421949 416593 5356 1.269347717 Rounded rects (outline) 55128 53980 1148 2.082426353 Rounded rects (filled) 1365167 1364834 333 0.02439262 Sums 4283152 4231254 51898 1.211677755
Thanks Mike,
Not sure at times how much these change help or not... Often times it depends on how much time the code overhead is versus how many times it avoids with reducing the bytes sent out SPI. Example did same code change for the ST7735/89_t3 code base and tried it on T4 with ST7789 2" version... Code change:
I tried it with and without the change:
Using a version of the graphic test that works in all 4 orientations and prints out timings...Code:#if 1 uint16_t _previous_addr_x0 = 0xffff; uint16_t _previous_addr_x1 = 0xffff; uint16_t _previous_addr_y0 = 0xffff; uint16_t _previous_addr_y1 = 0xffff; void setAddr(uint16_t x0, uint16_t y0, uint16_t x1, uint16_t y1) __attribute__((always_inline)) { if ((x0 != _previous_addr_x0) || (x1 != _previous_addr_x1)) { writecommand(ST7735_CASET); // Column addr set writedata16(x0+_xstart); // XSTART writedata16(x1+_xstart); // XEND _previous_addr_x0 = x0; _previous_addr_x1 = x1; } if ((y0 != _previous_addr_y0) || (y1 != _previous_addr_y1)) { writecommand(ST7735_RASET); // Row addr set writedata16(y0+_ystart); // YSTART writedata16(y1+_ystart); // YEND _previous_addr_y0 = y0; _previous_addr_y1 = y1; } } #else void setAddr(uint16_t x0, uint16_t y0, uint16_t x1, uint16_t y1) __attribute__((always_inline)) { writecommand(ST7735_CASET); // Column addr set writedata16(x0+_xstart); // XSTART writedata16(x1+_xstart); // XEND writecommand(ST7735_RASET); // Row addr set writedata16(y0+_ystart); // YSTART writedata16(y1+_ystart); // YEND } #endif
And not much difference:
Code:BEFORE AFTER Rotations 0 1 0 1 tftPrintTest: 1611 1611 1610 1610 testlines: 536 535 535 535 tftPrintTest: 73 73 73 74 testdrawrects: 65 71 65 70 tftPrintTest: 593 1199 592 1199 testfill/drawcircles: 204 205 191 190 testroundrects: 124 123 121 122 testtriangles: 73 80 74 79 mediabuttons: 1115 1114 1115 1115 Totals: 4394 5012 4376 4995
I show two of the orientations. Find that the landscape versus portrait at least on one of the tests is a lot different in timing...
But the before versus the later is not a big difference.
It is the ILI9486 in 8-bit parallel mode. I would like to see how fast I can push it on the Teensy 4. The ATmega328 speed controlling it doesn't impress me much, but at least it performs better than an SPI display on slow CPUs.
