Intermittent USB HOST and MSC init failure in driveInfo.ino.
wwatson
Ran into a situation where a USB drive would fail to initialize properly. This showed up in two files. driveInfo.ino in the USBHost_t36 library and in an example sketch of mine copyFileUSB.ino. The drive init portion in setup() was incorrect:
  Serial.print("\nInitializing USB MSC drive...");
  // Wait for the drive to start.
  while (!myDrive) {
    myusb.Task();
This waited for the drive to appear which it did. But sometimes the filesystem portion was not ready and any disk operation would fail. So changed it to:
  Serial.print("\nWaiting for partition to...");
  while (!myFiles) {
    myusb.Task();
That fixed the problem. Will issue a PR for driveInfo.ino.
  while (!myDrive) {
    myusb.Task();
  while (!myFiles) {
    myusb.Task();
Haven't run into that problem - don't think but definitely good to make that change - will have to check on one of the drives I have laying around that never worked
  while (!myDrive) {
    myusb.Task();
  while (!myFiles) {
    myusb.Task();
Should it wait forever without a timeout?
@BriComp - No it should not and it does not...
  while (!myFiles) {
    myusb.Task();
Surely if for some reason myFiles NEVER becomes TRUE it will loop forever, or am I missing something?
@mjs513 - It happened much more consistently with the copyFile.ino sketch than it did with the driveInfo.ino sketch.
If anybody wants to test, here is the sketch that was failing intermittently:
  MSC Drive read/write copy file
#include <USBHost_t36.h>
// Setup USBHost_t36 and as many HUB ports as needed.
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
USBHub hub4(myusb);
// Setup MSC for the number of USB Drives you are using. (Two for this example)
// Mutiple  USB drives can be used. Hot plugging is supported. There is a slight
// delay after a USB MSC device is plugged in. This is waiting for initialization
// but after it is initialized ther should be no delay.
USBDrive myDrive(myusb);
USBFilesystem firstPartition(myusb);
File myFile;
File myFile1;
// Size of read/write buffer. Start with 4096.
// Have tried 4096, 8192, 16384, 32768 and 65536.
// Usually settle on 16384
const size_t BUF_SIZE = 16384;
// File size in MB where MB = 1,024,000 bytes.
const uint32_t FILE_SIZE_MB = 32;
// File size in bytes.
const uint32_t FILE_SIZE = 1024000UL*FILE_SIZE_MB;
FASTRUN uint8_t* buf[BUF_SIZE];
uint32_t t;
uint32_t flSize = 0;
float MBs = 1.0f;
// Wait for port to open:
   while (!Serial) {
    yield();
  // Start USBHost_t36, HUB(s) and USB devices.
  myusb.begin();
/*// This does not fail to init.
  // Wait for claim proccess to finish.
  while(!firstPartition) {
    myusb.Task();
  // This portion of code fails to init properly
  // intermittently.
  while (!myDrive) {
    myusb.Task();
  Serial.println("initialization done.");
  Serial.print("\nTesting Write, Copy and Read. BUF_SIZE = ");
  Serial.println(BUF_SIZE);
  Serial.println("\nDirectory Listing");
  File root = firstPartition.open("/");
  Serial.println("Directory listing for USB drive:");
  printDirectory(root, 0);
  // fill buf with known data
  if (BUF_SIZE > 1) {
    for (size_t i = 0; i < (BUF_SIZE - 2); i++) {
      buf[i] = (uint8_t *)('A' + (i % 26));
    buf[BUF_SIZE-2] = (uint8_t *)'\r';
  buf[BUF_SIZE-1] = (uint8_t *)'\n';
  uint32_t n = FILE_SIZE/BUF_SIZE;
  if(firstPartition.exists("test.txt"))
	firstPartition.remove("test.txt");
  // open the file.
  myFile = firstPartition.open("test.txt", FILE_WRITE_BEGIN);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("\nWriting to test.txt...");
  t = millis();
  for (uint32_t i = 0; i < n; i++) {
    if (myFile.write(buf, BUF_SIZE) != BUF_SIZE) {
      Serial.printf("Write Failed: Stopping Here...");
      while(1);
  t = millis() - t;
  flSize = myFile.size();
  MBs = flSize / t;
  Serial.printf("Wrote %lu bytes %f seconds. Speed : %f MB/s\n",flSize, (1.0 * t)/1000.0f, MBs / 1000.0f);
  // close the file:
  myFile.close();
    // if the file didn't open, print an error:
    Serial.println("Error opening test.txt: Write Failed: Stopping Here...");
    while(1);
  // re-open the file for reading:
  myFile = firstPartition.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
	if(firstPartition.exists("copy.txt"))
		firstPartition.remove("copy.txt");
    // open the second file for writing.
    myFile1 = firstPartition.open("copy.txt", FILE_WRITE_BEGIN);
    if (myFile1) {
      Serial.printf("Copying test.txt to copy.txt...");
	  t = millis();
      while(myFile.read(buf, BUF_SIZE) == BUF_SIZE) {
        if (myFile1.write(buf, BUF_SIZE) != BUF_SIZE) {
          Serial.printf("Write Failed: Stoppiing Here...");
          while(1);
    t = millis() - t;
    MBs = flSize / t;
    Serial.printf("Copied %lu bytes %f seconds. Speed : %f MB/s\n",flSize, (1.0 * t)/1000.0f, MBs/1000.0f);
    // close the files:
    myFile.close();
    myFile1.close();
    Serial.println("error opening test.txt");
  // re-open the second file for reading:
  myFile1 = firstPartition.open("copy.txt");
  if (myFile1) {
    Serial.println("copy.txt:");
    // open the file for a read.
    if (myFile1) {
      Serial.printf("Reading File: copy.txt...");
	  t = millis();
      while(myFile1.read(buf, BUF_SIZE) == BUF_SIZE);
    t = millis() - t;
    flSize = myFile1.size();
    MBs = flSize / t;
    Serial.printf("Read %lu bytes %f seconds. Speed : %f MB/s\n",flSize, (1.0 * t)/1000.0f, MBs/1000.0f);
    // close the files:
    myFile1.close();
    Serial.println("Error opening copy.txt");
  Serial.printf("Done..\n");
	// nothing happens after setup
void printDirectory(File dir, int numSpaces) {
   while(true) {
     File entry = dir.openNextFile();
     if (! entry) {
       //Serial.println("** no more files **");
     printSpaces(numSpaces);
     Serial.print(entry.name());
     if (entry.isDirectory()) {
       Serial.println("/");
       printDirectory(entry, numSpaces+2);
       // files have sizes, directories do not
       printSpaces(48 - numSpaces - strlen(entry.name()));
       Serial.print("  ");
       Serial.println(entry.size(), DEC);
     entry.close();
void printSpaces(int num) {
  for (int i=0; i < num; i++) {
    Serial.print(" ");
This was tested on both a T4.1 and T4.0. The failure:
Initializing USB MSC drive...initialization done.
Testing Write, Copy and Read. BUF_SIZE = 16384
Directory Listing
There were three things I tried to consistently cause the failure:
1. Uploading sketch multiple time in a row.
2. Unplugging and replugging multiple times.
3. Pushing the program button multiple times.
It would init properly sometimes and sometimes not. Normal init output put looks like:
Directory Listing
test.txt                                          32768000
copy.txt                                          32768000
32MEGfile.dat                                     32768000
MSCtesting.bas                                    534
test.bas                                          95
bench.dat                                         32768000
Writing to test.txt...Wrote 32768000 bytes 2.674000 seconds. Speed : 12.254000 MB/s
test.txt:
Copying test.txt to copy.txt...Copied 32768000 bytes 4.510000 seconds. Speed : 7.265000 MB/s
copy.txt:
Reading File: copy.txt...Read 32768000 bytes 1.501000 seconds. Speed : 21.830000 MB/s
Done..
You will see two init sections in the sketch. The working version is commented out.
@Paul merged the PR.
  while (!myFiles) {
    myusb.Task();
I see what you are getting at. I thought you were talking about:
  while (!myDrive) {
    myusb.Task();
The only time it will hang forever is if there is no drive plugged in. Which kinda defeats the whole idea:) I have a couple of failed USB sticks that I test with and when I test those the result is:
Directory Listing
I suppose you could add a timeout but how long do you wait? The init times on some of these devices can be over a minute. Hard drive especially...
EDIT: I am working on several examples loosely related to SdFat and some of my previous examples. One of those will be examples of error checking. There is quite a bit of error checking going on in MSC already.
  while (!myDrive) {
    myusb.Task();
Directory Listing
I was most concerned about a failing (not completely failed) drive, but looks like you might have that handled.
Let's say I'm working on it:)
Just for an example, I run the driveInfo.ino sketch from the USBHost_t36 library and I forgot to plug in a USB drive I would see:
Waiting for Drive to initialize...
Then wondering why nothing was happening I realize I did not plug in a drive. I plug it in and:
Device Info:
       connected: 1
     initialized: 1
   USB Vendor ID: 0781
  USB Product ID: 5590
      HUB Number: 1
        HUB Port: 1
  Device Address: 2
Removable Device: YES
        VendorID:  SanDisk
       ProductID:            Ultra
      RevisionID: 1.00
         Version: 6
    Sector Count: 60062499
     Sector size: 512
   Disk Capacity: 30751999488 Bytes
Partition Table
        part,boot,bgnCHS[3],type,endCHS[3],start,length
exFAT:  1,0,0x4,0x1,0x4,0x7,0xFE,0xC2,0xFF,2048,60059648
pt_#0:  2,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
pt_#0:  3,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
pt_#0:  4,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
         < unused area starting at: 60061696 length 803 >
Volume name: 32GUSBEXFAT
Volume type: FAT64
Cluster Size: 32768 bytes
Volume size: 30745296896 bytes
 Space used: 131334144 bytes  (143 ms to compute)
Files:
2023-01-01 00:00     32768000 test.txt
2023-01-01 00:00     32768000 copy.txt
2019-01-01 00:00     32768000 32MEGfile.dat
2023-03-31 11:14          534 MSCtesting.bas
2023-04-04 14:34           95 test.bas
2023-01-01 00:00     32768000 bench.dat
If the device is faulty I would see:
Device Info:
       connected: 1
     initialized: 0
   USB Vendor ID: 0000
  USB Product ID: 0000
      HUB Number: 0
        HUB Port: 0
  Device Address: 0
Removable Device: NO
        VendorID:
       ProductID:
      RevisionID:
         Version: 0
    Sector Count: 0
     Sector size: 0
   Disk Capacity: 0 Bytes
Volume name:
Volume type: FAT0
Cluster Size: 0 bytes
Volume size: 0 bytes
 Space used: 0 bytes  (0 ms to compute)
Files:
Which shows something is definitely wrong.
The user can add a timeout to:
elapsedMillis timeout;
  while (!myDrive) {
    myusb.Task();
if(timeout > 5000) {
  Serial.println("Timeout: no device detected. Halting...");
  while(1);
And after let's say 5 seconds an error would be reported:
There are several way's the user can handle timeouts. Kind of a dealers choice...
