ninja2
The basic sketch below is for one of my Adafruit RFM95W Lora modules that I am trying to control with Teensy 4.1
It relies on this Lora library by Sandeep Mistry that is available via the IDE library manager.
The sketch compiles with warnings but doesn't work yet.
The warnings are about invalid conversion from 'int' to 'IRQ_NUMBER_t' but I couldn't fnd the data type for IRQ_NUMBER_t ??
I've not had to think about interrupts on Teensy before. Are they handled under same principles as general Arduino boards ?
Here are the compile warnings:
here is the code:
I have also modified the Lora.h in my libraries to recognise Teensy SPI1 pins as shown below. DIO0_PIN is the interrupt pin:
In file included from /home/cj/.arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4/wiring.h:39,
from /home/cj/.arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4/WProgram.h:46,
from /home/cj/.cache/arduino/sketches/1995C1DB9FDB144AA3AD17A324F4D31A/pch/Arduino.h:6,
from /home/cj/ARDUINO/SKETCHES/libraries/LoRa/src/LoRa.h:9,
from /home/cj/ARDUINO/SKETCHES/libraries/LoRa/src/LoRa.cpp:6:
/home/cj/ARDUINO/SKETCHES/libraries/LoRa/src/LoRa.cpp: In member function 'void LoRaClass::onReceive(void (*)(int))':
/home/cj/.arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4/core_pins.h:1784:59: warning: invalid conversion from 'int' to 'IRQ_NUMBER_t' [-fpermissive]
1784 | #define digitalPinToInterrupt(p) ((p) < NUM_DIGITAL_PINS ? (p) : -1)
| int
/home/cj/ARDUINO/SKETCHES/libraries/LoRa/src/LoRa.cpp:377:27: note: in expansion of macro 'digitalPinToInterrupt'
377 | SPI.notUsingInterrupt(digitalPinToInterrupt(_dio0));
In file included from /home/cj/ARDUINO/SKETCHES/libraries/LoRa/src/LoRa.h:10,
/home/cj/.arduino15/packages/teensy/hardware/avr/1.59.0/libraries/SPI/SPI.h:1171:45: note: initializing argument 1 of 'void SPIClass::notUsingInterrupt(IRQ_NUMBER_t)'
1171 | void notUsingInterrupt(IRQ_NUMBER_t interruptName);
/home/cj/ARDUINO/SKETCHES/libraries/LoRa/src/LoRa.cpp: In member function 'void LoRaClass::onTxDone(void (*)())':
| int
/home/cj/ARDUINO/SKETCHES/libraries/LoRa/src/LoRa.cpp:395:27: note: in expansion of macro 'digitalPinToInterrupt'
395 | SPI.notUsingInterrupt(digitalPinToInterrupt(_dio0));
Memory Usage on Teensy 4.1:
FLASH: code:14288, data:4040, headers:8292 free for files:8099844
RAM1: variables:4896, code:11592, padding:21176 free for local variables:486624
RAM2: variables:12416 free for malloc/new:511872
here is the code:
#include <Streaming.h>
#include <LoRa.h>
while (!Serial && millis() < 1000);
Serial << "\n\n==== LoraSender.b ====\n";
Serial << "* Start LoRa radio: ";
if (!LoRa.begin(915E6)) {
Serial << "FAILED program *HALT");
while (1);
Serial << "OK\n";
int counter = 0;
Serial << "Sending packet: " << counter << '\n';
LoRa.beginPacket();
LoRa.print("hello ");
LoRa.print(counter);
LoRa.endPacket();
counter++;
delay(5000);
#ifdef __IMXRT1062__ // setup for SPI1 on T4.*
#define LORA_DEFAULT_SPI SPI1
#define LORA_DEFAULT_SPI_FREQUENCY 8E6
#define LORA_DEFAULT_SS_PIN 38
#define LORA_DEFAULT_RESET_PIN 2
#define LORA_DEFAULT_DIO0_PIN 3
#elif defined(ARDUINO_SAMD_MKRWAN1300)
#define LORA_DEFAULT_SPI_FREQUENCY 200000
#define LORA_DEFAULT_SS_PIN LORA_IRQ_DUMB
#define LORA_DEFAULT_RESET_PIN -1
#define LORA_DEFAULT_DIO0_PIN -1
#elif defined(ARDUINO_SAMD_MKRWAN1310)
#define LORA_DEFAULT_DIO0_PIN LORA_IRQ
#else
#define LORA_DEFAULT_SS_PIN 10
#define LORA_DEFAULT_RESET_PIN 9
#define LORA_DEFAULT_DIO0_PIN 2
