Is there a simple E-paper driver for Teensy LC?
MichaelMeissner
Senior Member+
I bought one of the SPI e-paper displays (specifically the Waveshare 200x200 display):
I found a full featured driver for it at:
And it seems to work well on my Teensy 3.2 (and 3.5 if memory serves), but for a particular project I am using a Teensy LC to light up a wooden bowtie with neopixel rings. However, the bowtie is just barely bigger than the Teensy, so I can't use the 3.2 and the LC prop shield to translate the Teensy pin voltages to VIN (or use an external chip to do the same thing). I used the LC to drive the LEDs. The LC is great for this. I only have 12-32 rings, so the LC has enough space for the neopixels.
I want to measure how long the bowtie will last on the battery. In the past when I would use the 3.2 for similar projects, I would write into EEPROM memory every 15 minutes or so, and when the Teensy rebooted, it would print the previous runtime to the USB monitor. I could run it until the battery drained, and then boot it again under USB to see how long it lasted.
As I understand it, it is not a good idea to write a lot to the LC simulated EEPROM, so I figured get an epaper display and just print the uptime every 5-10 minutes The problem is the GxEPD driver is too big for the LC. Does anybody know of a slimmer e-paper driver that would work on the LC? I don't care about graphics, fonts, etc. I just want some simple text.
I've figured there are other ways to do this (make a USB cable that doesn't include the power line; write serial to a second Teensy that is running the display, and powered via USB; use an i2c or spi display that has separate power provided, but does use common grounds, etc.), but I was curious if there was a simpler driver for the epaper display.
I actually have that display as well somewhere in my work bench (the key is finding it once again). Thanks for the reminder.
I would need to plug the display into a breadboard, and reroute A3 and change the source. The display uses 11, 13, A0-A3. A3 is the CS pin. As I look at the source, it is all software SPI. The example also uses the String library. Yuck and yuck. But it is fairly simple, and just does text with no graphics. The screen on that 202x112 display takes 2,912 bytes (my 200x200 display would take 5,000 bytes which I didn't consider the LC when I bought it).
<edit>
The updated library is at https://github.com/jarek319/EPD215, and it does allow overriding the CS/DC/RS/BS pins. It does use hardware SPI, but the begin transaction call has been commented out. The quote example uses 27,720 bytes of flash (43%) and 5,636 (68%) of DRAM. This library does include the Adafruit_GFX library.
As a followup, the crowd supply teensy e-paper supply kit and the Pervasive Displays E2215CS062 (originally this was an option with the e-paper kit, but now you have to buy it separately) works with a Teensy LC. I have enough space that I can load all of the neopixel libraries that I use along with e-paper library.
My particular sketch uses:
Sketch uses 27164 bytes (42%) of program storage space. Maximum is 63488 bytes.
Global variables use 5800 bytes (70%) of dynamic memory, leaving 2392 bytes for local variables. Maximum is 8192 bytes.
Unfortunately, it looks like the E2215CS062 isn't currently available. There is a Waveshare 1.52" 152x152 display that has a similar memory size for the screen:
Michael. I have that same 1.54 inch display, actually both versions, B/W and B/W/R. However, I am having trouble getting it to work with the Teensy 3.2 which I wish to use for a meter project. I am using the GxEPD library as well. Would you mind posting how you connected the display to your teensy and any changes or tweaks you might have made? I did get the displays to work with nano, ESP8266 and ESP32 WROOM micro-controllers for other projects but I wish to use the Teensy 3.2 for this more complicated one.
Thank you in advance.
Mark
Hallo Michael,
You may want have a look at the attached code. It runs on a TeensyLC. Not much RAM left, but at least you can display a scalable font.
Sketch uses 26392 bytes (41%) of program storage space. Maximum is 63488 bytes.
Global variables use 7004 bytes (85%) of dynamic memory, leaving 1188 bytes for local variables. Maximum is 8192 bytes.
I took the code from Waveshare and copied some font code from Shabaz123. For references, see the top of the INO file.
For a different display, you may want to edit the DisplayInit function.
Regards,
Paul
  • Teensy_epd2in9_simplexfont.ino
Hello Paul,
thanks for your code. I can confirm this code also works unchanged on a Teensy 3.6 running @240MHz.
I also have the 1.54" e-ink screen from Waveshare and later this week I will try to get this running.
groeten, bedankt, Otto
Hello Hersoft,
My reaction is a little bit late of the last comment, but did you managed to run the code for the 1.54 e-ink screen from Waveshare? Could you share your code?
This would be very nice. Thank you.
FWIW, Adafruit has recently come out with a series of e-ink displays that have a flash memory controller along with the display. This means you don't have to dedicate a large chunk of SRAM to buffering the screen.
Note, the mount for the feather wing displays is opposite to the way I mount the teensy feather adapter -- I usually mount the adapter on top of the Teensy and have the traditional Teensy pins underneath and female headers for the feather wings on top.
I've tried the tri-color displays, and they are really slow (about 15 seconds to update the display).
Obviously having the screen buffer in a separate flash memory region means you will have to first read from the flash memory before updating the screen, but you don't have to have the 5-7K screen buffer in your local memory (which as I said in the first post is a problem with the LC). However, the displays are slow enough that I doubt the extra time to read from the flash memory will be that noticeable.
Hi MichaelMeissner,
Thank you for your fast feedback. But I like this little peace of code, because I can use it without some big change if I use an other board.
The problem is, that I don't know how to rotate a picture.
I would like to know, how I can rotate the ep_write_text() function from the example of PaulS.
I try to extract this information from Adafruit GFX function, but I couldn't really find it.
I see only two solution: Change the function or rotate the full picture.
I know that I have a vector of some picture which will be build up in 200/8(xvalue) * 200 (yvalue) but I didn't find the right way to rotate it...
Hello,
hmmm, I just started again with this display (1.54" 200x200 dots)
Have been playing with the demo code from the library on Teensy 3.6 together with Ultimate GPS and Lipo batt etc.
Yes, for me it is not easy to find the function description from the library, English is not my native language and this must be true also for the person who wrote the library I guess.
I'll keep working @ it but might be tempted to switch over to a Waveshare 1.54 color Oled if I do not get it to work, however sad this would be because of power drain.
Regards, Otto
Thought I'd try resuscitating this thread as I've not had any luck asking a new question on this forum.
I too am trying to get the GxEPD_Example.ino from https://github.com/ZinggJM/GxEPD to work with teensy 3.2 and Waveshare 1.54inch e-paper. I've confirmed all my hardware is ok and so the problem must be s/w or pin connections. I've tried the pin configuration posted by ANDYUK:
Working pin mapping as follows;
E-paper > Teensy 3.2
Busy > 7
RST > 9
DC > 8
CS > 10
CLK > 13
DIN > 11
and the Uno configuration in the Waveshare documentation which has pin 8 and 9 reversed. I've specified these pins in the s/w configuration:
GxIO_Class io(SPI, /*CS=*/ 10, /*DC=*/ 8, /*RST=*/ 9);
GxEPD_Class display(io, /*RST=*/ 9, /*BUSY=*/ 7);
A couple of people in this thread were trying to solve the problem and I'd like to know if any succeeded, apart from Michael.
Sorry to revitalize an old post, but I stumbled across this when I couldn't get my WaveShare 2.7" e-ink screen to work.
After doing some research, WaveShare and good display sell the same e-ink screens. While WaveShare has some excellent examples, GoodDisplay has a much more basic example to test the core functionally.
Debugging with GoodDisplay's code, I found the busy single never goes high during the initialization of the screen. Using another output, I trigger the busy pin by jumpering them with a 470 ohm resistor. (pin 14 to pin 8 in my example) then turn off this output after the screen clears. It appears this is only necessary during boot.
#include"Ap_29demo.h"
//IO settings
int BUSY_Pin = 8;
int RES_Pin = 9;
int DC_Pin = 10;
int CS_Pin = 11;
int SCK_Pin = 12;
int SDI_Pin = 13;
//santa_cruz
int init_Pin = 14;
#define EPD_W21_MOSI_0  digitalWrite(SDI_Pin,LOW)
#define EPD_W21_MOSI_1  digitalWrite(SDI_Pin,HIGH)
#define EPD_W21_CLK_0 digitalWrite(SCK_Pin,LOW)
#define EPD_W21_CLK_1 digitalWrite(SCK_Pin,HIGH)
#define EPD_W21_CS_0 digitalWrite(CS_Pin,LOW)
#define EPD_W21_CS_1 digitalWrite(CS_Pin,HIGH)
#define EPD_W21_DC_0  digitalWrite(DC_Pin,LOW)
#define EPD_W21_DC_1  digitalWrite(DC_Pin,HIGH)
#define EPD_W21_RST_0 digitalWrite(RES_Pin,LOW)
#define EPD_W21_RST_1 digitalWrite(RES_Pin,HIGH)
#define isEPD_W21_BUSY digitalRead(BUSY_Pin)
//santa_cruz
#define initalize_0 digitalWrite(init_Pin,LOW)
#define initalize_1 digitalWrite(init_Pin,HIGH)
////////FUNCTION//////
void DELAY_100nS(unsigned int delaytime);
void driver_delay_us(unsigned int xus);
void driver_delay_xms(unsigned long xms);
void DELAY_S(unsigned int delaytime);
void SPI_Delay(unsigned char xrate);
void SPI_Write(unsigned char value);
void EPD_W21_WriteDATA(unsigned char command);
void EPD_W21_WriteCMD(unsigned char command);
//EPD
void EPD_W21_Init(void);
void EPD_init(void);
void PIC_display1(void);
void PIC_display2(void);
void EPD_sleep(void);
void EPD_refresh(void);
void lcd_chkstatus(void);
void PIC_display_Clean(void);
unsigned char HRES,VRES_byte1,VRES_byte2;
   pinMode(BUSY_Pin, INPUT);
   pinMode(RES_Pin, OUTPUT);
   pinMode(DC_Pin, OUTPUT);
   pinMode(CS_Pin, OUTPUT);
   pinMode(SCK_Pin, OUTPUT);
   pinMode(SDI_Pin, OUTPUT);
   pinMode(init_Pin, OUTPUT);
   Serial.println("1");
   initalize_1;
   //PICTURE1
   EPD_init(); //EPD init
   PIC_display1();
   EPD_refresh();//EPD_refresh
   EPD_sleep();//EPD_sleep,Sleep instruction is necessary, please do not delete!!!
   //PICTURE2
   PIC_display2();
   Serial.println("Clean Start");
   //PICTURE Clean
   PIC_display_Clean();
   Serial.println("Clean End");
//Tips//
/*When the electronic paper is refreshed in full screen, the picture flicker is a normal phenomenon, and the main function is to clear the display afterimage in the previous picture.
  When the local refresh is performed, the screen does not flash.*/
/*When you need to transplant the driver, you only need to change the corresponding IO. The BUSY pin is the input mode and the others are the output mode. */
byte incomingByte = 0; // for incoming serial data
    Serial.println("disable init pin");
    initalize_0;
    Serial.println("Starting Read");
    while(1)
      if (Serial.available() > 0) {
      incomingByte = Serial.read();
      //ASCII '1'
      if(incomingByte == 49){
      Serial.println("1 detected");
      //PICTURE2
      PIC_display2();
      //PICTURE Clean
///////////////////EXTERNAL FUNCTION////////////////////////////////////////////////////////////////////////
/////////////////////delay//////////////////////////////////////
void driver_delay_us(unsigned int xus)  //1us
  for(;xus>1;xus--);
void driver_delay_xms(unsigned long xms) //1ms
    unsigned long i = 0 , j=0;
    for(j=0;j<xms;j++)
        for(i=0; i<256; i++);
  int i,j,k;
  for(i=0;i<delaytime;i++)
    for(j=0;j<4000;j++)
      for(k=0;k<222;k++);
//////////////////////SPI///////////////////////////////////
  unsigned char i;
  while(xrate)
    for(i=0;i<2;i++);
    xrate--;
    unsigned char i;
  SPI_Delay(1);
    for(i=0; i<8; i++)
        EPD_W21_CLK_0;
    SPI_Delay(1);
        if(value & 0x80)
          EPD_W21_MOSI_1;
          EPD_W21_MOSI_0;
        value = (value << 1);
    SPI_Delay(1);
    driver_delay_us(1);
        EPD_W21_CLK_1;
        SPI_Delay(1);
    SPI_Delay(1);
    EPD_W21_CS_0;
  EPD_W21_DC_0;   // command write
  SPI_Write(command);
  EPD_W21_CS_1;
    SPI_Delay(1);
    EPD_W21_CS_0;
  EPD_W21_DC_1;   // command write
  SPI_Write(command);
  EPD_W21_CS_1;
/////////////////EPD settings Functions/////////////////////
  EPD_W21_RST_0;    // Module reset
  delay(1);//At least 10ms delay
  EPD_W21_RST_1;
void EPD_init(void)
    EPD_W21_Init(); //Electronic paper IC reset
    EPD_W21_WriteCMD(0x06);         //boost soft start
    EPD_W21_WriteDATA (0x07);   //A
    EPD_W21_WriteDATA (0x07);   //B
    EPD_W21_WriteDATA (0x17);   //C
    EPD_W21_WriteCMD(0x04);  //Power on
    lcd_chkstatus();        //waiting for the electronic paper IC to release the idle signal
    EPD_W21_WriteCMD(0x00);     //panel setting
    EPD_W21_WriteDATA(0x1f);    //LUT from OTP£¬128x296
    EPD_W21_WriteCMD(0x0d);     //VCOM to 0V fast
    EPD_W21_WriteCMD(0x16);
    EPD_W21_WriteDATA(0x00);        //KW-BF   KWR-AF  BWROTP 0f
    EPD_W21_WriteCMD(0xF8);         //boostÉ趨
    EPD_W21_WriteDATA (0x60);
    EPD_W21_WriteDATA(0xa5);
    EPD_W21_WriteDATA (0x73);
    EPD_W21_WriteDATA (0x23);
    EPD_W21_WriteDATA (0x7C);
    EPD_W21_WriteCMD(0X50);
    EPD_W21_WriteDATA(0x97);    //WBmode:VBDF 17|D7 VBDW 97 VBDB 57   WBRmode:VBDF F7 VBDW 77 VBDB 37  VBDR B7
    EPD_W21_WriteCMD(0x12);     //DISPLAY REFRESH
    driver_delay_xms(100);          //!!!The delay here is necessary, 200uS at least!!!
    lcd_chkstatus();
    EPD_W21_WriteCMD(0X02);   //power off
    EPD_W21_WriteCMD(0X07);   //deep sleep
    EPD_W21_WriteDATA(0xA5);
    unsigned int i;
    EPD_W21_WriteCMD(0x10);        //Transfer old data
    for(i=0;i<5808;i++)
    EPD_W21_WriteDATA(0xff);
    EPD_W21_WriteCMD(0x13);        //Transfer new data
    for(i=0;i<5808;i++)
     EPD_W21_WriteDATA(pgm_read_byte(&gImage_1[i]));
    unsigned int i;
    for(i=0;i<5808;i++)
    for(i=0;i<5808;i++)
     EPD_W21_WriteDATA(pgm_read_byte(&gImage_2[i]));
    unsigned int i;
    for(i=0;i<5808;i++)
    for(i=0;i<5808;i++)
  while(isEPD_W21_BUSY==0);
  driver_delay_xms(200);
///////////////////////END////////////////////////////////////
Header file
#include <avr/pgmspace.h>
////////////////array/////////////////////////
const unsigned char gImage_1[5808] PROGMEM = { /* 0X81,0X01,0X28,0X01,0X98,0X00, */
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFC,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X7E,0X18,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X07,0XE0,0X00,0X07,
0XFF,0XC0,0X0C,0X00,0X00,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X00,0X00,0X00,0X00,0X02,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,
0X00,0X00,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFC,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X7F,0XFF,0XFF,0XC3,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF1,0XE4,0X00,0X00,0X00,0X00,0X00,0X00,0X3F,0XFF,
0XF8,0X00,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X8E,0X6C,0X03,0X80,
0X00,0X00,0X00,0X00,0X07,0X00,0X00,0X00,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFE,0X62,0X40,0X1F,0XF9,0X80,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X7F,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF9,0X82,0X07,0XFF,0XFF,0XE0,0X00,0X00,0X00,
0X08,0X32,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE2,0X00,0X03,
0XFF,0XFF,0XF8,0X00,0X00,0X00,0X03,0X52,0X00,0X00,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XC8,0X31,0XF0,0X1F,0XFF,0XFF,0XC3,0X00,0X00,0X02,0X52,0X00,0X00,
0X00,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X30,0XF1,0XF7,0X87,0XFF,0XFF,0XFF,
0XE0,0X00,0X06,0X58,0X00,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X73,
0XE1,0XF3,0XF1,0XFF,0XFF,0XFF,0X80,0X00,0X04,0X48,0X00,0X00,0X00,0X1F,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFE,0XE3,0XE1,0XF9,0XFC,0X7F,0XFF,0XFF,0X00,0X00,0X04,0X40,
0X00,0X00,0X00,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFD,0XC7,0XE1,0XFE,0X7E,0X1F,
0XFF,0XFF,0X21,0X04,0X95,0X20,0X00,0X00,0X00,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFB,0X87,0XE1,0XFF,0X3F,0X47,0XFF,0XF0,0X31,0X84,0XA4,0X94,0X00,0X00,0X00,0X3F,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF9,0X87,0XC0,0XFF,0X3E,0X71,0XFF,0XC6,0X10,0XC4,
0X80,0X04,0X00,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF5,0X07,0XC0,0XFF,
0X9E,0X78,0X00,0X07,0X18,0X46,0X00,0X00,0X00,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XEB,0X07,0XE0,0XFF,0X8E,0X79,0X80,0XE3,0X9E,0X24,0X3F,0XFC,0X00,0X00,
0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE3,0X07,0XE0,0XFF,0X8E,0X79,0XC3,0XF3,
0X93,0X30,0XFF,0XFF,0X00,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XD3,0X07,
0XE0,0XFF,0X87,0X79,0XC3,0XF3,0X99,0X93,0XFF,0XFF,0XF0,0X00,0X00,0X3F,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XD7,0X07,0XE0,0XFF,0XC3,0X3D,0XC9,0XF3,0XDD,0X87,0XFF,0XFF,
0XFC,0X00,0X4F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XD7,0X07,0XE0,0X7F,0XC3,0XBC,
0XCC,0XD9,0XCC,0X8F,0XFF,0XFF,0XFF,0XF8,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X87,0X07,0XE0,0X7F,0XC1,0X9C,0XE4,0X49,0XEE,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X87,0X07,0XE0,0X7F,0XC1,0XCC,0X66,0X6C,0XE6,0X3F,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X86,0X07,0XE0,0X3F,
0XE0,0XCC,0X76,0X76,0XE6,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0X86,0X07,0XF0,0X3F,0XE0,0XCE,0X32,0X76,0X70,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X86,0X07,0XF0,0X1F,0XE0,0X66,0X32,0X76,
0X61,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X0E,0X07,
0XF0,0X1F,0XF0,0X66,0X13,0X77,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X0E,0X07,0XF0,0X0F,0XF0,0X27,0X13,0X73,0X1F,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X0E,0X07,0XF0,0X0F,0XF0,0X33,
0X13,0X76,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X0E,0X07,0XF8,0X07,0XF8,0X33,0X93,0X72,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X0E,0X07,0XF8,0X07,0XF8,0X19,0X93,0X70,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X1E,0X07,0XF8,0X03,
0XFC,0X19,0X92,0X61,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0X1E,0X07,0XFC,0X03,0XFC,0X19,0X92,0X47,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X1E,0X07,0XFC,0X03,0XFC,0X19,0X96,0X0F,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X1E,0X07,
0XFC,0X01,0XFE,0X19,0XB6,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X1C,0X03,0XFE,0X01,0XFE,0X09,0XB6,0X7F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X1C,0X03,0XFE,0X00,0XFE,0X09,
0X34,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X1C,0X03,0XFF,0X00,0XFF,0X09,0XB1,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X1E,0X03,0XFF,0X80,0XE7,0X09,0XB1,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X1E,0X03,0XFF,0X80,
0X67,0X09,0XB3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0X1E,0X01,0XFF,0XC0,0X63,0X09,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X1E,0X01,0XFF,0XC0,0X23,0X0D,0X03,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X1E,0X00,
0XFF,0XE0,0X33,0X0C,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X1E,0X00,0X7F,0XF0,0X31,0X8E,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9F,0X00,0X3F,0XF0,0X31,0X86,
0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X9F,0X00,0X3F,0XF8,0X38,0X80,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X8F,0X00,0X1F,0XF8,0X18,0X40,0X03,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XCF,0X80,0X0F,0XFC,
0X0C,0X20,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XCF,0XC0,0X0F,0XFC,0X06,0X30,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC7,0XC0,0X07,0XFE,0X02,0X00,0X00,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC3,0XF0,
0X03,0XFF,0X03,0X00,0X00,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XC1,0XF8,0X01,0XFF,0X81,0X00,0X00,0X7F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XD0,0XFE,0X00,0XFF,0XC0,0X00,
0X00,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XD8,0X7F,0X80,0X3F,0XF0,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XCC,0X1F,0XE0,0X1F,0XF8,0X00,0X00,0X3F,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XEC,0X0F,0XF0,0X0F,
0XFC,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XE6,0X0F,0XF8,0X0F,0XFE,0X00,0X00,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0X07,0XFC,0X07,0XFE,0X00,0X00,0X1F,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE3,0X83,
0XFE,0X03,0XFF,0X00,0X00,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XE3,0X81,0XFE,0X01,0XFF,0X00,0X00,0X0F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF1,0XC0,0XFF,0X00,0XFF,0X80,
0X00,0XCF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XF1,0XE0,0XFF,0X80,0X7F,0XE0,0X01,0XCF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF4,0XE0,0X7F,0XC0,0X3F,0XF8,0X03,0XCF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF4,0XF0,0X3F,0XE0,
0X1F,0XFF,0X1F,0XCF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XF4,0X78,0X1F,0XE0,0X0F,0XFF,0XFF,0X8F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF6,0X78,0X1F,0XF0,0X07,0XFF,0XFF,0X0F,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF6,0X3C,
0X0F,0XF8,0X03,0XFF,0XFE,0X2F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XF2,0X1E,0X07,0XFC,0X01,0XFF,0XFC,0X6F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE3,0X1E,0X03,0XFE,0X00,0X7F,
0XF0,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XE3,0X0F,0X01,0XFF,0X00,0X1F,0XC1,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE1,0X8F,0X81,0XFF,0X80,0X00,0X03,0XEF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE1,0X87,0X80,0XFF,
0XE0,0X00,0X07,0XCF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XE1,0X87,0XC0,0X3F,0XF0,0X00,0X0F,0X8F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0XC3,0XE0,0X0F,0XFC,0X00,0X1F,0XAF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE4,0XC1,
0XE0,0X03,0XFF,0X00,0X7F,0X6F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XE4,0XE1,0XF0,0X01,0XFF,0XE3,0XFE,0X6F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE4,0X60,0XF8,0X00,0X7F,0XFF,
0XFC,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XE4,0X70,0X7C,0X00,0X3F,0XFF,0XF9,0XCF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE6,0X30,0X3F,0X00,0X0F,0XFF,0XF1,0XCF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE6,0X38,0X3F,0XC0,
0X03,0XFF,0XE3,0X8F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XC2,0X1C,0X1F,0XF0,0X00,0XFF,0X07,0X6F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC3,0X1C,0X0F,0XFC,0X00,0X00,0X0E,0XEF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC3,0X0E,
0X03,0XFF,0X00,0X00,0X1E,0XCF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X83,0X8F,0X01,0XFF,0XC0,0X00,0X3D,0XDF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X81,0XC7,0X80,0X7F,0XFC,0X00,
0XF9,0X9F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X01,0XC3,0XC0,0X0F,0XFF,0XFF,0XF3,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X00,0XE1,0XE0,0X00,0X7F,0XFF,0XC6,0X3F,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X00,0X70,0XF8,0X00,
0X0F,0XFF,0X1C,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFE,0X00,0X38,0X3E,0X00,0X00,0X00,0X39,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X40,0X1E,0X1F,0X80,0X00,0X00,0XF6,0X7F,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X60,0X0F,
0X87,0XFF,0XF0,0X0F,0XCE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFC,0X30,0X07,0XE1,0XFF,0XFF,0XFF,0X38,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X18,0X01,0XF8,0X3F,0XFF,0XFC,
0X71,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,
0X0E,0X00,0X20,0X00,0X0F,0X81,0XC1,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFB,0X07,0XC0,0X00,0X00,0X00,0X0F,0X1B,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF9,0X81,0XFE,0X00,0X00,
0X00,0X7C,0X77,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XF8,0XC0,0X7F,0XFF,0XC3,0XFF,0XE3,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X60,0X1F,0XFF,0XFF,0XFE,0X1F,0XCF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF4,0X30,0X01,
0XFF,0XFE,0X00,0XFC,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XE2,0X1C,0X00,0X00,0X00,0X07,0XC3,0XCF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC1,0X0F,0X00,0X00,0X00,0XF8,0X1F,
0X8F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,
0X83,0XF0,0X00,0X1F,0XC1,0X30,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XF6,0X00,0XC1,0XFF,0XFF,0XFE,0X0F,0X08,0X07,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X00,0X60,0X7F,0XFF,0XF0,
0X7E,0X1C,0X03,0XF8,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X00,0X00,0X30,0X0F,0XFF,0X81,0XF8,0X01,0XC1,0X83,0XF8,0X7F,0XFF,0XFF,0X0F,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X00,0X00,0X18,0X00,0X00,0X07,0XE2,0X03,0XF8,0X3F,
0X9E,0X08,0X1F,0XF0,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X00,0X00,0X0C,0X00,
0X00,0X3F,0X8C,0X83,0XFF,0XFC,0X00,0X01,0X80,0X00,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0X00,0X18,0X47,0X00,0X01,0XFE,0X1B,0X01,0XFF,0XF8,0X00,0X01,0XB0,0X00,
0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X00,0X04,0X21,0XF8,0X1F,0XF8,0X26,0X01,
0XBF,0XFF,0XC0,0X01,0XB0,0X00,0X00,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X03,0X80,
0X18,0X7F,0XFF,0XE0,0XCC,0X01,0X7F,0XFF,0XD8,0X00,0X18,0X00,0X00,0X07,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFC,0X00,0XE0,0X0C,0X0F,0XFE,0X03,0X92,0X10,0X77,0XFF,0XDA,0X80,
0X18,0X00,0X00,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X00,0X70,0X03,0X00,0X00,0X0F,
0X06,0X30,0X6C,0X9E,0X5A,0X8C,0X10,0X00,0X00,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,
0X18,0X18,0X21,0X80,0X00,0X7F,0X0C,0X60,0XEC,0XDA,0X5B,0X8C,0X31,0X80,0X00,0X07,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X0E,0X0C,0X38,0X60,0X07,0XF8,0X18,0X60,0XED,0XDE,
0X5A,0X88,0XB1,0X90,0X00,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X06,0X02,0X0C,0X1C,
0X1F,0X81,0X92,0X00,0XEC,0XDE,0X4A,0X88,0XA1,0X90,0X00,0X07,0XFF,0XFF,0XFF,0XFF,
0XFF,0XE0,0X03,0X00,0X03,0X07,0XF8,0X01,0X83,0X20,0XEC,0XDF,0X42,0X88,0X81,0X10,
0X00,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XE3,0X81,0XC0,0X01,0XC0,0X38,0X38,0X03,0X30,
0XEC,0XDD,0X06,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XE1,0XC0,0XE0,
0X18,0X70,0X0E,0X3C,0X31,0X10,0XE8,0X50,0X00,0X00,0X3F,0X80,0X00,0X01,0XFF,0XFF,
0XFF,0XFF,0XFF,0XC0,0XE0,0X38,0X06,0X0C,0X0F,0X0E,0X18,0X98,0X68,0X40,0X00,0X03,
0XFF,0XFE,0X00,0X00,0X7F,0XFF,0XFF,0XFF,0XFF,0X80,0X70,0X1E,0X01,0X83,0X07,0X83,
0X9C,0X88,0X60,0X0F,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X7F,0XFF,0XFF,0XFF,0XFF,0X80,
0X38,0X07,0X80,0X60,0XC1,0XE1,0XC6,0XCC,0X00,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X00,
0X7F,0XFF,0XFF,0XFF,0XFF,0X00,0X1C,0X01,0XF0,0X10,0X30,0XF0,0XE1,0XE0,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFC,0X00,0X7F,0XFF,0XFF,0XFF,0XFE,0X02,0X0E,0X00,0X7E,0X0C,
0X1C,0X38,0X78,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X00,0X7F,0XFF,0XFF,0XFF,
0XFC,0X03,0X87,0X80,0X07,0X83,0X07,0X1E,0X08,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0X00,0X7F,0XFF,0XFF,0XFF,0XFE,0X63,0XC1,0XC0,0X01,0XE1,0XC1,0X87,0XF0,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X80,0X7F,0XFF,0XFF,0XFF,0XEE,0X31,0XC0,0X60,
0X00,0X70,0X60,0XE1,0XF1,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0XFF,0XFF,
0XFF,0XFF,0XC3,0X38,0XE0,0X38,0X00,0X1C,0X38,0X7C,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFC,0XFF,0XFF,0XFF,0XFF,0XC0,0X1C,0X70,0X0E,0X00,0X06,0X0E,0X1E,
0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X0E,
0X18,0X07,0X80,0X01,0XC3,0X00,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XE0,0X87,0X06,0X01,0XE0,0X00,0XF0,0X0F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0XE3,0X81,0X00,0XF8,0X00,
0X38,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XC0,0XE0,0XE0,0X00,0X7E,0X00,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X80,0X70,0X30,0X00,0X1F,0X80,0X07,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X06,0X38,0X0E,0X00,
0X0F,0XC0,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFC,0X86,0X1E,0X03,0XC0,0X03,0XF0,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0XC3,0X03,0X01,0XF0,0X00,0X7C,0X7F,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0XE3,0X81,
0X80,0X7C,0X00,0X00,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFC,0X70,0XC0,0XE0,0X1F,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X38,0X60,0X78,0X03,0XFC,0X0F,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,
0X9C,0X30,0X1F,0X00,0X7F,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0XCE,0X1C,0X07,0XF0,0X00,0X7F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X61,0X0F,0X00,0X7F,
0XC0,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFC,0X70,0XC3,0XC0,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X1C,0X60,0X7F,0XE0,0X07,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X02,0X38,
0X00,0X00,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XF0,0XF1,0X06,0X1F,0XC4,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X9C,0X63,0X80,0X0F,0X9F,0XFF,
0X02,0X39,0XF8,0X1F,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X19,0X30,0X7F,0XF8,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X0D,0XB0,0X00,0X00,
0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XF8,0X0F,0X83,0XE0,0X00,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X7F,0X8F,0X8F,0X00,0X07,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE3,0XFF,0X01,
0XFC,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XE6,0X1F,0X80,0X00,0X00,0X33,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC1,0X0F,0X80,0X00,0X01,0XE1,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,
0X18,0X00,0X00,0X0F,0X00,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X30,0X00,0X00,0X78,0X40,0X7F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X63,0X80,0X1F,0XC0,
0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0X0F,0XC2,0X87,0X8F,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X1F,0XE3,0X98,0X3C,0X02,0X1F,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBF,0XF3,
0X9C,0X78,0X60,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XF1,0X8C,0XF0,0XC0,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF1,0X84,0XE1,0X98,0X0F,
0XFF,0XF9,0X04,0XC1,0X10,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X04,0XC3,0X30,0X07,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X80,0X42,
0X30,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XE0,0X66,0X30,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X04,0X30,0X01,0XFF,0XFF,
0XFC,0X04,0X70,0X00,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X04,0XF0,0X00,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X86,0X30,0X00,
0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XC2,0X30,0X00,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X00,0X00,0X7F,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,
0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X00,0X00,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X00,0X00,0X7F,0XFF,
0XFF,0XFE,0X00,0X00,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X00,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X80,0X03,
0XFF,0XFF,0XFF,0XFF,0XC0,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X1F,0XFF,0XFF,0XFF,0XFF,
const unsigned char gImage_2[5808] PROGMEM = { /* 0X81,0X01,0X28,0X01,0X98,0X00, */
0XFF,0XFF,0XF0,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XE0,0XFF,0XFF,0XFF,0XFF,0XF0,0X00,0X00,0X00,0X00,0X00,0X01,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X01,0X9F,
0XFF,0XFF,0XFF,0XE0,0X1F,0X9F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X0F,0XFF,0X90,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0XFF,
0XFF,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X01,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X07,0XFF,0XF8,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC4,0X7F,0XFF,0XC0,0X3F,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X03,
0XFF,0XFF,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFC,0X03,0XFF,0XFC,0X0F,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X03,0X83,0XF0,0X1F,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X83,0XC0,0X03,0X80,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X27,0XC0,0X00,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X03,
0XFF,0XFF,0XF8,0X40,0X00,0X07,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X00,0X00,0X0F,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X00,
0X00,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XF0,0X00,0X00,0X0F,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X00,0X00,0X07,0XFF,0XFF,
0XF8,0X60,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X00,0X00,0XFF,0XC0,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X0F,0X00,
0XFF,0XFF,0XFF,0XF0,0X1F,0XF8,0X1F,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X1F,0XFC,0X07,0XFF,0XFF,0XFF,
0X3F,0XFF,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X7F,0XFF,0XF0,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X00,
0XFF,0XFF,0XFF,0XFF,0XFF,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X80,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XBF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XE4,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XF8,0X01,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,
0XFF,0XFF,0XE0,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE7,0XFD,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X03,0XFF,0XFF,0XFF,0XE7,0XFD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF3,0XFD,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,
0XE0,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE0,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XF3,0XF9,0XFF,0XFF,
0XFF,0XFF,0XF7,0XFD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF9,0XC7,
0X03,0XFF,0XFF,0XFF,0XF1,0XF1,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE1,0XF9,0XFF,0XFF,0XFF,0XFF,
0XE7,0XF9,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0XF1,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE3,0XE1,0XFF,0XFF,
0XFF,0XFF,0XF0,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X80,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X7F,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFD,0XFF,0XFF,0XFF,0XFF,
0XFF,0XE0,0X78,0X40,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,
0XFF,0XF9,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X21,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF9,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X03,0XC0,
0XFF,0XFF,0XFF,0XE0,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X81,
0XFE,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE3,0XFF,
0XFF,0XFF,0XC7,0XFF,0XFF,0X00,0X10,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XE0,0X7F,0XFF,0XFF,0X83,0XFF,0XFE,0X00,0X01,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XEF,0X07,0XFF,0XFF,0X21,0XFF,
0XF8,0X00,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,
0XFF,0XE0,0XFF,0XFF,0XF8,0XFF,0X80,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X80,0X1F,0XFF,0XF8,0X3F,0X00,0X07,0XFF,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE4,0X03,0XC7,0XFF,
0XF8,0X0C,0X00,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XE0,0X1F,0XE7,0XFF,0XFC,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0XFF,0XE7,0XFF,0XFF,0X00,0X00,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE3,0XFF,
0XE7,0XFF,0XFF,0X80,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XE7,0XFF,0XFF,0XFF,0XFF,0XEF,0XC1,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFB,0XFF,0XFF,0XFF,0XFF,
0XE1,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,
0XFF,0XF9,0XFF,0XFF,0XFF,0XFF,0XE1,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XF0,0X01,0XFF,0XFF,0XFF,0XFF,0X81,0XFF,0XFF,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE0,0X01,0XFF,0XFF,
0XFF,0XF0,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XE2,0X79,0XFF,0XFF,0XFF,0XE0,0X01,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE7,0X3D,0XFF,0XFF,0XFF,0XF0,0X07,0XFF,
0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE7,0X3D,
0XFF,0XFF,0XFF,0XF9,0X9F,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X03,0XFF,0XFF,0XFF,0XE1,0X81,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XF1,0XC1,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFD,0XFF,0XFF,
0XFF,0XF0,0X00,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XF0,0X00,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X00,0X01,
0XFF,0XFF,0XFF,0XFB,0XFF,0XFD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XF8,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XF0,0X03,0XFF,0XFF,
0XFF,0XFF,0XE1,0XF1,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0XFD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0XFD,
0X03,0XFF,0XFF,0XFF,0XF7,0XF9,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE0,0X00,0X07,0XFF,0XFF,0XFF,
0XE0,0X00,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XF3,0XFF,0XC7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XF7,0XFF,0XF7,0XFF,
0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE1,0XC3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE1,0X81,
0X03,0XFF,0XFF,0XFF,0XE7,0X1D,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XEE,0X1D,0XFF,0XFF,0XFF,0XFF,
0XE6,0X39,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XF0,0X71,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0XE1,0XFF,0XFF,
0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XF9,
0X03,0XFF,0XFF,0XF3,0XE0,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF3,0XE0,0X01,0XFF,0XFF,0XFF,0XFF,
0XF3,0XFD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFB,0XFF,0XFF,
0XFF,0XFF,0XFF,0XF9,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X00,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XF0,0X00,0X01,
0X03,0XFF,0XFF,0XF9,0XE3,0XF9,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFB,0XE7,0XFD,0XFF,0XFF,0XFF,0XFF,
0XE7,0XFD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE3,0XF9,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X87,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X01,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XF8,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X0F,0XC0,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X01,0XFF,0XFE,0X0F,0XFF,0XFF,0XFF,0XFF,0X00,0X3C,
0XFF,0XFF,0XFF,0XFE,0X00,0X00,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X00,0X00,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X3F,0XFF,0XFF,0XFF,0XF0,
0X00,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0X3F,0XFF,0XFF,0XFE,0X00,0X00,0X0F,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X01,0XFF,0XFF,0X3F,0XFF,0XFF,0XFC,0X20,0X00,0X0F,0XFF,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0X3F,0XFF,0XFF,
0XFC,0X00,0X00,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0X3F,0XFF,0XFF,0XF8,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFB,
0XFF,0XFF,0XFC,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X03,0XFF,0XFF,0XFF,0XFF,0XF9,0XFF,0XFF,0XFC,0X18,0X1F,0X1F,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XF0,0X00,0X01,0XFF,0XFF,0XFF,0X2C,
0X0F,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XF0,
0X00,0X01,0XFF,0XFF,0XFF,0X87,0X80,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XF9,0XE3,0XF9,0XFF,0XFF,0XFF,0XFF,0XF8,0X7F,0XFF,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFB,0XE7,0XFD,0XFF,0XFF,
0XFF,0XFF,0XE7,0XFD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE3,0XF9,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XF0,0X01,
0XFF,0XFF,0XFF,0XFF,0XF8,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFE,0X0F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X07,0XFF,0XFF,
0XFF,0XFF,0XF0,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,
0XFF,0XFF,0XFF,0XFF,0XEF,0XFD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE7,0XF9,0XFF,0XFF,0XFF,0XFF,
0XF1,0XC1,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFC,0X0F,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X07,
0XFF,0XFF,0XFF,0XFF,0XF0,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE1,0XF9,0XFF,0XFF,0XFF,0XFF,
0XE7,0XFD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE7,0XFD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE7,0XF9,0XFF,0XFF,
0XFF,0XFF,0XE3,0XE1,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X07,
0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0XF7,0XFC,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XF0,0X38,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X19,0XE7,0XFF,
0XFF,0XFF,0XE3,0X99,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE7,0XD9,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0XD9,
0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X03,0XFF,0XFF,0XFF,0XE0,0X08,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XF0,0X00,0X07,0XFF,0XFF,0XFF,
0XF8,0X71,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XF9,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF9,
0XFF,0XFF,0XFF,0XE8,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE0,0XFF,0XFF,0XFF,
0XF8,0X01,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,
0XFF,0XFF,0XEC,0X0F,0XFF,0XFF,0XF0,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC1,0XFF,0XFF,0XF0,0X01,0XFF,0XFF,
0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0X81,
0XFF,0XFF,0XFE,0X79,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X03,0XFF,0XFF,0XFF,0XE4,0X03,0XFF,0XFF,0XFE,0X01,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE0,0X3F,0XFF,0XFF,0XFE,0X03,
0XE0,0X1F,0XFF,0XFF,0XFF,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0X83,0XFF,0XFF,0XFF,0XBB,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE1,0XFF,0XFF,
0XFF,0X31,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,
0XFF,0XFF,0XEE,0X01,0XFF,0XFF,0XFE,0X71,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X0F,0XFF,0XFF,0XFE,0X79,0XFF,0XFF,
0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE0,0X7F,
0XFF,0XFF,0XFE,0X01,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X03,0XFF,0XFF,0XFF,0XE3,0XFF,0XFF,0XFF,0XFE,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XEF,0XFF,0XFF,0XFF,0XFF,0X07,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFD,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE7,0XFF,0XFF,0XFF,0XFF,0XF9,0XFF,0XFF,0XFF,0XC0,
0XFF,0XF9,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,
0XFF,0XFF,0XEC,0X0F,0XFF,0XFF,0XFF,0XF9,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC1,0XFF,0XFF,0XFF,0XF9,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X81,
0XFF,0XFF,0XF8,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XE4,0X03,0XFF,0XFF,0XF0,0X01,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE0,0X3F,0XFF,0XFF,0XF0,0X03,
0XFF,0XFF,0X83,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,
0XE0,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X00,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0X83,0XFF,0XFF,0XFC,0X7D,0XFF,0XF8,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XE1,0XFF,0XFF,
0XF8,0X39,0XFF,0XF0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,
0XFF,0XFF,0XEE,0X01,0XFF,0XFF,0XF0,0X19,0XF8,0X60,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE0,0X0F,0XFF,0XFF,0XF3,0X09,0XF0,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE0,0X7F,
0XFF,0XFF,0XF0,0X81,0XF0,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XE3,0XFF,0XFF,0XFF,0XF0,0XC1,0XF0,0X00,0X00,0X7F,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XEF,0XFF,0XFF,0XFF,0XF9,0XE3,
0XF0,0X00,0X00,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X18,0X01,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE7,0XFF,0XFF,0XFF,0XFF,0X9B,0XFC,0X1C,0X01,0XC0,
0XFF,0X11,0XFF,0XFE,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XEC,0X0F,0XFF,0XFF,0XFE,0X11,0XFF,0XFE,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC1,0XFF,0XFF,0XFE,0X19,0XFF,0XFF,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0X81,
0XFF,0XFF,0XFE,0X01,0XFF,0XFE,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XE4,0X03,0XFF,0XFF,0XFE,0X03,0XFF,0XFF,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE0,0X3F,0XFF,0XFF,0XFF,0X07,
0XFF,0XFF,0X80,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,
0XE0,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X88,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XE7,0X83,0XFF,0XFF,0XFF,0X00,0X7F,0XFF,0XDE,0X00,
0XFE,0X00,0X3F,0XFF,0XC7,0X8F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XEE,0X01,0XFF,0XFF,0XFE,0X00,0X3F,0XFF,0XE7,0X8F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X0F,0XFF,0XFF,0XFE,0X79,0X3F,0XFF,
0XFF,0X8F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X7F,
0XFF,0XFF,0XFE,0X01,0X3F,0XFF,0XFF,0XCF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XE3,0XFF,0XFF,0XFF,0XFE,0X02,0X7F,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XEF,0XFF,0XFF,0XFF,0XFF,0X06,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X81,0XFF,0XFF,0XFF,0XC0,
0XFF,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X01,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X09,0XFF,0XFF,
0XFF,0XFF,0XFE,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X03,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X67,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X81,0XFF,0XFF,0XFF,0XDF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X7F,0XFF,0XFF,
0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X01,0XFF,0XFF,0XFF,0XC0,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X03,
0XFF,0XFF,0XFF,0XFF,0XFE,0X7F,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X01,0XFF,0XFF,0XFF,0XFF,
0XFE,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XF8,0X01,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X03,
You can find the GoodDisplay example code here.
https://www.good-display.com/produc...electronic-paper-display,-GDEW027W3--235.html
e-paper hardware questions (slightly off topic)
This is not exactly on topic, but this thread seems to have collected some members with e-paper experience that I'd like to draw on.
I have an Adafruit e-paper display that I have been driving from a Teensy 3.2. The Adafruit site first recommends that the display be updated no more frequently than every 3 minutes, but then offhandedly suggests that maybe cutting that rate down to once a day (!) might be better.
The unit I have has been updated every 5 minutes for about 14 hours a day for 5 or 6 months. Now it is losing its contrast, to the point where it is patchily illegible. For what it's worth, the red-on-white contrast seems to be surviving better than the black-on-white contrast.
My suspicion is that the update rate doesn't matter, and that this Adafruit model should not be expected to tolerate more than 10^4 or so updates, regardless of the inter-update interval. Of course, my unit's problem could be instance-specific -- maybe I just got a lemon.
What have been other members' experiences with the service life of these little displays?
I would be interested to know this as well. What are your operating conditions like? I've heard you're not supposed to update in direct sunlight.
My unit had been running on a table that got occasional direct sunlight, but the display was -- does this make a difference? -- always faced away from the sun.
