Constantin
Hi guys and gals,
I found a bug in the Dallas Temperature library example and I wonder if anyone here has a suggestion how to fix it. If you have the Dallas Temperature Library, load the Multibus_simple example.
If you try to compile, the compiler throws the following errors:
Is this a simple matter of going through the One-Wire library, note the changed functions, and then update the Dallas Temperature library?
I hope I'm using the latest version of every library. Had the same issue with Arduino 1.8.6 on a different machine.
Happy 4th everyone, Constantin
Multibus_simple:7: error: no matching function for call to 'OneWire::OneWire()'
OneWire ds18x20[oneWirePinsCount];
In file included from D:\Arduino\libraries\DallasTemperature\examples\Multibus_simple\Multibus_simple.ino:1:0:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\OneWire/OneWire.h:269:5: note: candidate: OneWire::OneWire(uint8_t)
OneWire( uint8_t pin);
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\OneWire/OneWire.h:269:5: note: candidate expects 1 argument, 0 provided
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\OneWire/OneWire.h:254:7: note: candidate: constexpr OneWire::OneWire(const OneWire&)
class OneWire
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\OneWire/OneWire.h:254:7: note: candidate expects 1 argument, 0 provided
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\OneWire/OneWire.h:254:7: note: candidate: constexpr OneWire::OneWire(OneWire&&)
Multibus_simple: In function 'void setup()':
Multibus_simple:22: error: 'class OneWire' has no member named 'setPin'
ds18x20[i].setPin(oneWirePins[i]);
Using library OneWire at version 2.3.2 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\OneWire
Using library DallasTemperature at version 3.7.6 in folder: D:\Arduino\libraries\DallasTemperature
