Issue with Stepper Motor with Builtin Decoder
mjs513
Senior Member+
Been having fun learning about stepper motors but running into an issue when using the built-in encoder in the steppermotor. Will explain in great detail but first some basic info.
StepperMotor:
STEPPERONLINE Nema 17 Closed Loop Stepper Motor 23oz.in w/ Magnetic Encoder: https://www.omc-stepperonline.com/n...etic-encoder-1000ppr-4000cpr-17hs08-1004-me1k. The specs are in the attached PDF. But basically its a 200ppr stepper rated at 1amp per datasheet with a 4000 count encoder.
Motor and Encoder Connection
Motor​
A+​
A-​
B+​
B-​
Wire​
Red​
Black​
Yellow​
Blue​
Encoder​
VCC​
EGND​
EA+​
EA-​
EB+​
EB-​
EZ+​
EZ-​
Wire​
Red​
Black​
BRN​
ORG​
Blue​
Green​
Yellow​
White​
The motor is connected to a Teensy 4.0 using a Pololu DRV8825 (splurge and buy the real one - had issues with the knock off). The encoder is connected to a T4.1 so I can read the encoder as the motor is running.
Stepper wiring:
GNDs connected to GND on T4.
M0 - 5
M1 - 6
M2 - 7
Reset/Sleep - 3.3v
STEP - 14
Dir - 15
A1/A2/B1/B2 connected to motor through a interface board Picture below
Vref on the DRV8825 is set to 0.4v which is about 0.8 amp versus the 1.0amp rated current.
Encoder connections:
A+ - pin 2
B+ - pin 3
Z+ - pin 5
power - 5v
gnd - gnd
goes through a pololu level shifter to the T4.1 :)
Driver library:
None. Rolled my own as a learning exercise. See attached sketch for stepper motor
Encoder sketch - using the simple_encoder example sketch.
ISSUE:
When the motor is running the encoder is showing counts that go up and down as opposed to a continuous increase as would normally be expected. The graphs below that in gory detail at least for the first bunch of pulses:
Microstep = 1/2 1/4
The interesting thing though at the end of a revolution the total counts is 4000 which is what it should be.
Decided to put a LA on the encoder pins to see whats happening and you can see where phase B goes out of synch:
No clue what the issue could be. But as a test with the motor disconnected and turning the shaft manually not seeing it to that extent only once or twice which could have been me.
I do have a Sparkfun Prodriver coming with is what the interface board was designed for (no clue where I put the original).
  • 17HS08-1004-ME1K_Full_Datasheet (1).pdf
  • teensyEncStepper_test-250509a.zip
Sounds like a project!
Yep - one of those things that has been on my to do list - better understanding of steppers and interfacing with the Quadencoder library. Always see questions about steppers.
Last time I did stuff with motors and encoders... I cheated and used a RoboClaw.
Something like: https://www.basicmicro.com/roboclaw-2x30a-motor-controller_p_9.html
But that was for Brushed motors...
I have seen that before when I was looking at motor controllers for my robotics projects.
Have played with the Sparkfun Prodriver: https://www.sparkfun.com/sparkfun-prodriver-stepper-motor-driver-tc78h670ftg.html and the Adafruit Motor/Stepper/Servo Shield: https://www.adafruit.com/product/1438. Never tried the DRV8825's or the A9488's so was curious (which always gets me in trouble).
At some point was thinking about writing some sort of post on what I did and how things work but thats for another day. Found a several interesting tidbits and lessons along the way.
ISSUE:
I deduce you have no mechanical damping so the motor is actually bouncing back and forth on each step - use 1/16 microstepping or so and you will probably solve this. Bouncing around won't cause mis-counting with quadrature, that's the reason quadrature is used.
Alternatively you might have some backlash between the motor and the encoder, but this is unlikely with an integrated unit.
Hi Mark
Tried it just laying on desk and holding it tightly in hand (since just testing 1 Rev).. Do have a couple of brackets on order to mount on a flat board.
Was thinking about that but as you said its an integrated unit. Kind of the reason why I bought a stepper with a integrated encoder. But at any rate tried it at 1/16 and still there:
and you still see it even at 1/32
Try 500, I suspect its all smoothed out at higher speeds due to inertia. More microstepping ought to reduce this kind of vibration - perhaps also try and 1rpm. Steppers behave worse at middle speeds where the natural resonance of the rotor matches step rates - there's even a term for it, "mid-band resonace"
Ok tried at 1RPM and Microstep = 4 notl seeing the issue, running at 500rpm not seeing it except at the end of turn which seeing an interesting affect:
Microseteps = 16.
With a microstep of 8 not seeing it either at speed 500.
Actually just realised something. In my sketch have to set MS before speed. So with a MS=8 and S=100: Not seeing issue of originally identified but with M<4 yes. Even with
Microsteps set to: 4
PPR: 200, MPR: 4, RPM: 100
TPR: 800, PPS: 1333.333252, PW(us): 750
not seeing issue but still seeing the oscilations at 4000 ( at end of movement)
Interesting effects.
Never came across this in any of the readings on steppers so far. Wish all this was in one place
thanks for resolving the one issue.
PS now that its working correctly stepper is getting hotter :)
Have to experiment a bit more now that I have a starting point
Steppers at full rated current get very hot. Its normal to drop the drive current to about 50% when stationary so the heat goes down by a factor of 4ish. The stationary torque is a lot higher than dynamic torque so this usually isn't a problem.
Steppers behave funky, even with some load. I have seen this on my electronic lead screw on my lathe. I'm using 4 microsteps/step. The even microsteps are different in size than the odd. That's just how the stepper driver is. I can't do anything about it. I had a 1um resolution digital read out on my Z axis, and I could clearly see that the step sizes translated to displacement had resonances in them at certain speeds, or just were uneven. That's how the real world is, for motors and sensors, they are imperfect. In my case the step sizes are 2.5um on average, but the evens are more like 1.5, and the odds 3.5. Oh, and motor full steps aren't all perfect 1.8 degrees either. But 200 full steps, or 800 microsteps does come out to be exactly one revolution.
Thanks for the confirmation. I learned this the hard way :)
Me too.;)
Mid-band resonance sounded like there was gravel in my gearbox, it really sounded terrible, like things were irreparably broken. In my case, I pushed mid-band resonance to a higher frequency by increasing the inertial load on the motor. (Added an aluminum disk to the motor pulley, to increase the moment of inertia.). No more resonance.
going to have to try something like that - have to add it to my to do list :)
I added a 4" diameter disk, about 1/2" thick, coaxial with the bore of the timing pulley. Was good enough to drive the resonance from about 1200 RPM to over 2200 RPM, which was good enough for my application. (Max spindle speed on my lathe is 2200 RPM.) Downside, is it takes a little longer to stop. But no resonance from 0-2200 RPM now.
Morning all.
Decided to actually put together a PCB instead of all those wires shown in previous post, actually has connector for I2c and display - havent test yet
Makes life a lot easier. Next post has some interesting observations on skips in counts. Will post that separate
Been doing some more experiments with stepper/encoder along with quad encoder lib.
Right now in the sketch I have:
C++:
void runMove()
  int stepsPerRevolution = PPR * MPR;
  int total_revs = revolutions * stepsPerRevolution;
  Serial.println("Moving");
  for(int x = 0; x < total_revs; x++) {
    _time = micros();
    digitalWrite(stepPin, HIGH);
    delayMicroseconds(pulseWidth);
    digitalWrite(stepPin, LOW);
    getPosition();
and get postition:
C++:
void getPosition(){
    /* Read the position values. */
  mCurPosValue = myEnc1.read();
  if(mCurPosValue != old_position){
    Serial.printf("%d, %d, %d\n", micros() - _time, mCurPosValue, myEnc1.indexCounter);
  old_position = mCurPosValue;
where I get position within the move. When I run at:
PPR: 200, MPR: 8, RPM: 200
TPR: 1600, PPS: 5333.333008, PW(us): 187
you see some pretty dramatic skips at the beginning of the mover and skips of anywhere from 2-3 later on the move (usually testing at 1 revolution).
This is when it starts
later in rev not as dramatic
Now changing that to microsteps of 16 or 32 those skips go away :)
And secondly if I use the second Teensy to measure the counts it always counts correctly.
Thought this would be interesting - not sure why the skips - maybe just out of sync.
Anyone have any thoughts?
I'm just as puzzled as you are. I'm doing something similar and seeing bizarre stuff. My driver is set up to do 4 microsteps/step. The NEMA17 stepper is 200 full steps per revolution. I have connected a 1024 PPR rotary encoder to the stepper, via a 2GT timing belt. When I do 1600 steps forward and 1600 steps backwards, I detect 8200 counts, not 8192 counts as I expect. (2*4096)
It doesn't seem to matter if one uses your HW encoder library, or Luni's EncoderTool. Both yield the same number of counts. Can't tell if I have a rotary encoder issue, or stepper problem... I have replaced rotary encoders (same brand though) and get similar results.
I have seen similar irregular behavior (like you) as the stepper starts, might be cogging or simply trying to overcome the moment of inertia of the motor. After a while it smooths out.
My guess is the encoder is correct, and somehow it’s doing one more full step in each direction than you want.
I have no idea at this point. One full step would correspond to 4096 counts/rev / ( 200 steps/rev) = 20.48 counts/step. One micro-step is 1/4 of that, or 5.12 counts.
I observe ~6 counts, which perhaps coincidentally(?) is about 1/4 step (1 micro-step) 5.12 counts rounded up to 6. Maybe I will try just full steps and see what happens. My Electronic Lead Screw (ELS) is using 1/4 steps. I'd like to use 1/8th steps, but unfortunately the math doesn't work in my favor. (Higher step rates, unfavorable Bresenham values, etc.). There's possible workarounds, but they involve more money...
You said 8200 versus the expected 8192, which is exactly 8 = 2 full steps. Try doing 1599 steps in each direction and see if you get 8192. I’ve been using QuadEncoder for years, and TTBOMK it has always been perfect, never over or under.
Could you temporarily add some gearing to scale up the number of counts from the encoder to get a multiplied measurement for comparison (8:1 gearing to get 8x the counts) ??
Mark J Culross
KD5RXT
Try different magnitudes of motion and see if the error is fixed or scales with the size of the move.
Good idea.
The whole premise of using a stepper is that it is a discrete device, and angular errors don't accumulate. It may be true on an aggregate level, but it seems that on an arbitrary start point I'm not getting to the count I expect when turning two turns forward and two turns reverse. These results seem to break my assumptions about the use of a stepper. I'm sure there are some conditions when the premise is valid, but I have uncovered an instance when it is invalid. It could be the motor, the belt tension, the fixture, the encoder, or software.
Basically I need to validate my encoder is what it says it is. That's a tough metrology problem.
