Good morning all,
I have a project to build a flywheel using a 10K potentiometer only on the X axis. I am new to arduino and the language but managed to get the potentiometer to work with some code I have recovered.
The problem I get in is that I never manage to keep the car upright, it always moves left to right without ever being able to drive straight even when moving very slowly. I don't know what to do to get there and my programming level is too low. Yet when I do my tests with joy.cpl, I manage to place in the center without it wavering.
Do you have any idea so that I can keep my steering wheel straight when I straighten the steering wheel please? an other idea ?
Thank you in advance for your precious help !
Regards,
Regards,
#include <Bounce.h>
// hat angles
#define center -1
#define up 0
#define up_right 45
#define right 90
#define down_right 135
#define down 180
#define down_left 225
#define left 270
#define up_left 315
// TeensyLC pin assignments
#define up_pin 0
#define down_pin 1
#define left_pin 2
#define right_pin 3
#define a_pin 4
#define b_pin 5
#define x_pin 6
#define y_pin 7
#define L1_pin 8
#define R1_pin 10
#define an_L_x_pin A0 // 14 digital
#define L3_pin 16
#define start_pin 20
#define select_pin 21
#define joy_min 0
#define joy_max 1023
// Test joysticks and record lowest and highest observed values here
#define L_x_min_observed 600
#define L_x_max_observed 350
// Record "resting values" min and max
#define L_x_min_rest 488
#define L_x_max_rest 470
#define joyX_center 512
#define joyY_center 511
// D-pad -> hat state
int oldHatAngle = center;
int newHatAngle = center;
// D-Pad
Bounce btn_Up = Bounce(up_pin, 10);
Bounce btn_Down = Bounce(down_pin, 10);
Bounce btn_Left = Bounce(left_pin, 10);
Bounce btn_Right = Bounce(right_pin, 10);
// Action Buttons
Bounce btn_A = Bounce(a_pin, 10);
Bounce btn_B = Bounce(b_pin, 10);
Bounce btn_X = Bounce(x_pin, 10);
Bounce btn_Y = Bounce(y_pin, 10);
// Shoulder Buttons
Bounce btn_L1 = Bounce(L1_pin, 10);
Bounce btn_R1 = Bounce(R1_pin, 10);
// Select/Start Buttons
Bounce btn_Select = Bounce(select_pin, 10);
Bounce btn_Start = Bounce(start_pin, 10);
// Analog Stick Buttons
// uncomment these variables to test the min and max values, also uncomment the code that uses them down below
//int minPin = 1023;
//int maxPin = 0;
pinMode(up_pin, INPUT_PULLUP);
pinMode(down_pin, INPUT_PULLUP);
pinMode(left_pin, INPUT_PULLUP);
pinMode(right_pin, INPUT_PULLUP);
pinMode(a_pin, INPUT_PULLUP);
pinMode(b_pin, INPUT_PULLUP);
pinMode(x_pin, INPUT_PULLUP);
pinMode(y_pin, INPUT_PULLUP);
pinMode(L1_pin, INPUT_PULLUP);
pinMode(R1_pin, INPUT_PULLUP);
pinMode(select_pin, INPUT_PULLUP);
pinMode(start_pin, INPUT_PULLUP);
pinMode(an_L_x_pin, INPUT);
Joystick.hat(oldHatAngle);
// Update all the buttons
btn_Up.update();
btn_Down.update();
btn_Left.update();
btn_Right.update();
btn_A.update();
btn_B.update();
btn_Y.update();
btn_X.update();
btn_L1.update();
btn_R1.update();
btn_Select.update();
btn_Start.update();
newHatAngle = oldHatAngle;
// Check each button for "falling" edge (= low (pressed - button connects pin to ground))
if(btn_Up.fallingEdge()) {
switch (newHatAngle) {
case left : newHatAngle = up_left; break;
case right : newHatAngle = up_right; break;
default : newHatAngle = up; break;
if(btn_Down.fallingEdge()) {
case left : newHatAngle = down_left; break;
case right : newHatAngle = down_right; break;
default : newHatAngle = down; break;
if(btn_Left.fallingEdge()) {
case up : newHatAngle = up_left; break;
case down : newHatAngle = down_left; break;
default : newHatAngle = left; break;
if(btn_Right.fallingEdge()) {
case up : newHatAngle = up_right; break;
case down : newHatAngle = down_right; break;
default : newHatAngle = right; break;
if (btn_A.fallingEdge()) Joystick.button(1, 1);
if (btn_B.fallingEdge()) Joystick.button(2, 1);
if (btn_Y.fallingEdge()) Joystick.button(3, 1);
if (btn_X.fallingEdge()) Joystick.button(4, 1);
if (btn_L1.fallingEdge()) Joystick.button(5, 1);
if (btn_R1.fallingEdge()) Joystick.button(6, 1);
if (btn_Select.fallingEdge()) Joystick.button(9, 1);
if (btn_Start.fallingEdge()) Joystick.button(10, 1);
// Check each button for "rising" edge (= high (not pressed - voltage from pullup resistor))
if(btn_Up.risingEdge()) {
case up_left : newHatAngle = left; break;
case up_right : newHatAngle = right; break;
case up : newHatAngle = center; break;
if(btn_Down.risingEdge()) {
case down_left : newHatAngle = left; break;
case down_right : newHatAngle = right; break;
case down : newHatAngle = center; break;
if(btn_Left.risingEdge()) {
case up_left : newHatAngle = up; break;
case down_left : newHatAngle = down; break;
case left : newHatAngle = center; break;
if(btn_Right.risingEdge()) {
case up_right : newHatAngle = up; break;
case down_right : newHatAngle = down; break;
case right : newHatAngle = center; break;
if (btn_A.risingEdge()) Joystick.button(1, 0);
if (btn_B.risingEdge()) Joystick.button(2, 0);
if (btn_Y.risingEdge()) Joystick.button(3, 0);
if (btn_X.risingEdge()) Joystick.button(4, 0);
if (btn_L1.risingEdge()) Joystick.button(5, 0);
if (btn_R1.risingEdge()) Joystick.button(6, 0);
if (btn_Select.risingEdge()) Joystick.button(9, 0);
if (btn_Start.risingEdge()) Joystick.button(10, 0);
if (oldHatAngle != newHatAngle) {
Joystick.hat(newHatAngle);
oldHatAngle = newHatAngle;
// Get raw joystick input values
int lx = analogRead(an_L_x_pin);
// Check for less than or greater than zero, to keep the axis centered
if (lx < L_x_min_rest) {
Joystick.X(constrain(map(lx, L_x_min_observed, L_x_min_rest, joy_min, joyX_center), joy_min, joy_max));
else if (lx > L_x_max_rest) {
Joystick.X(constrain(map(lx, L_x_max_rest, L_x_max_observed, joyX_center, joy_max), joy_min, joy_max));
else {
Joystick.X(joyX_center);
// uncomment this code to test the min and max values, also uncomment the variables it needs up above.
// Change the analogRead(an_L_x_pin) to the axis you would like to check. Use the "Serial monitor"
// button to view the outputs. If testing the resting values, don't move the joystick and instead take
// the min and max values when it is resting.
// All in all, the min and max values, and min and max resting values, will need to be tested for every axis and recorded in the macros above.
// int pin = analogRead(an_L_x_pin);
// bool show = false;
// if (pin < minPin) {
// minPin = pin;
// show = true;
// if (pin > maxPin) {
// maxPin = pin;
// show = true;
// if(show) {
// String minString = String(minPin);
// String maxString = String(maxPin);
// Serial.println(minString + ":" + maxString);
// show = false;
