Issues with Arduino IDE 2.1 and Teensy 4.1
I cleared out the temp directory and everything works now.
To all of those who helped on these problems, I sincerely appreciate the help...thanks again.
I ran into the same issue. I deleted this folder:
C:\Users\YOUR_USER_NAME\.arduinoIDE
And everything was fine.
Hallo everyone :)
I have Arduino 2.1 installed and the following compiler error: Compilation error: exit status 1
Attached is my Output File and Arduino project file.
Thanks a lot for helb :)
PS: (I've been working on this problem for 3 days and can't find a solution)
  • Output error.zip
  • Jeannie 3.0.zip
Looks like the linker is failing with lots of duplicate symbols.
For example step_table:
You have defined in data_bandlimit_step.c.
But you are also using Audio librar and bringing in that same symbol, in it's data_bandlimit_step.c
Using library Wire at version 1.0 in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SPI
Using library SD at version 2.0.0 in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SD
Using library SdFat at version 2.1.2 in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat
Using library MIDI Library at version 5.0.2 in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\MIDI
Using library Mcp3208 at version 1.4.0 in folder: C:\Users\rolfd\Documents\Arduino\libraries\Mcp3208
Using library Entropy in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Entropy (legacy)
Using library Audio at version 1.3 in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Audio
Using library Adafruit GFX Library at version 1.11.5 in folder: C:\Users\rolfd\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit BusIO at version 1.14.1 in folder: C:\Users\rolfd\Documents\Arduino\libraries\Adafruit_BusIO
Using library CircularBuffer at version 1.3.3 in folder: C:\Users\rolfd\Documents\Arduino\libraries\CircularBuffer
Using library Encoder at version 1.4.3 in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Encoder
Using library Bounce in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Bounce (legacy)
Using library EEPROM at version 2.0 in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\EEPROM
Using library SerialFlash at version 0.5 in folder: C:\Users\rolfd\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SerialFlash
exit status 1
And my quick glance looked like it was the same table...
data_bandlimit_step.c is needed in synth_waveform.cpp
synth_waveform.cpp
/* Audio Library for Teensy 3.X
* Copyright (c) 2018, Paul Stoffregen, paul@pjrc.com
* Development of this audio library was funded by PJRC.COM, LLC by sales of
* Teensy and Audio Adaptor boards.  Please support PJRC's efforts to develop
* open source software by purchasing Teensy or other PJRC products.
* THE SOFTWARE.
ElectroTechnique 2020
Added WAVEFORM_SILENT, syncFlag
#include <Arduino.h>
#include "synth_waveform.h"
#include "arm_math.h"
#include "utility/dspinst.h"
// uncomment for more accurate but more computationally expensive frequency modulation
//#define IMPROVE_EXPONENTIAL_ACCURACY
#define BASE_AMPLITUDE 0x6000  // 0x7fff won't work due to Gibb's phenomenon, so use 3/4 of full range.
void AudioSynthWaveformTS::update(void)
	audio_block_t *block;
	int16_t *bp, *end;
	int32_t val1, val2;
	int16_t val3;
	int16_t magnitude15;
	uint32_t i, ph, index, index2, scale;
	const uint32_t inc = phase_increment;
	uint32_t phaseX;
	if(syncFlag == 1) {
		phase_accumulator = 0;
		phaseX = 0;
		syncFlag = 0;
		LFO1randomFlag = false;
		LFO2randomFlag = false;
	ph = phase_accumulator + phase_offset;
	phaseX = phase_accumulator;
	if (magnitude == 0) {
		phase_accumulator += inc * AUDIO_BLOCK_SAMPLES;
		return;
	block = allocate();
	if (!block) {
		return;
	bp = block->data;
	switch(tone_type) {
		// PWM SINE
		case PWM_WAVEFORM_SINE:
		for (i=0; i < AUDIO_BLOCK_SAMPLES; i++) {
			index = ph >> 24;
			val1 = AudioWaveformSine[index];
			val2 = AudioWaveformSine[index+1];
			scale = (ph >> 8) & 0xFFFF;
			val2 *= scale;
			val1 *= 0x10000 - scale;
			*bp++ = multiply_32x32_rshift32(val1 + val2, magnitude);
			ph += inc;
		case PWM_WAVEFORM_TRIANGLE:
			uint32_t phtop = ph >> 30;
			if (phtop == 1 || phtop == 2) {
				*bp++ = ((0xFFFF - (ph >> 15)) * magnitude) >> 16;
				*bp++ = (((int32_t)ph >> 15) * magnitude) >> 16;
			ph += inc;
		// PWM SAWTOOTH (LFO offset 0.0f)
		case PWM_WAVEFORM_SAWTOOTH:		// normal sawtooth and inv sawtooth
			*bp++ = signed_multiply_32x16t(magnitude, ph >> 1);
			ph += inc;
		// PWM SQUARE (LFO offset 1.0)
		case PWM_WAVEFORM_SQUARE:
		magnitude15 = signed_saturate_rshift(magnitude, 16, 1);
			//if (ph & 0x80000000) {
				*bp++ = -magnitude15;
				*bp++ = magnitude15;
			ph += inc;
		case WAVEFORM_ARBITRARY1:
		if (!arbdata) {
			release(block);
			return;
		// len = 256
			index = ph >> 24;
			index2 = index + 1;
			if (LFO1mode == 0) {
				if (index2 >= 256) index2 = 0;  // loop
			else {
				if (index2 >= 256) index2 = 255; // one shot
			val1 = *(arbdata + index);
			val2 = *(arbdata + index2);
			val2 *= scale;
			uint32_t ph_old = ph;
			uint32_t phaseX_old = phaseX;
			if (LFO1phase == 0) {	// Shape normal
				ph += inc;
				phaseX += inc;
			else {
				ph -= inc;
				phaseX -= inc;		// Shape inverse
			if (lfo1oneShoot == true && phaseX < inc) {
				ph = ph_old;
				phaseX = phaseX_old;
		case WAVEFORM_ARBITRARY2:
		if (!arbdata) {
			release(block);
			return;
		// len = 256
			index = ph >> 24;
			index2 = index + 1;
			if (LFO2mode == 0) {
			else {
				if (index2 >= 255) index2 = 255; // one shot
			val2 *= scale;
			if (LFO2phase == 0) {	// Shape normal
				ph += inc;
				phaseX += inc;
			else {
				ph -= inc;
			if (lfo2oneShoot == true && phaseX < inc) {
				ph = ph_old;
		case WAVEFORM_ARBITRARY3:
		if (!arbdata) {
			release(block);
			return;
		// len = 256
			index = ph >> 24;
			index2 = index + 1;
			if (LFO3mode == 0) {
			else {
			val2 *= scale;
			//*bp++ = multiply_32x32_rshift32(val1 + val2, magnitude);
			val3 = multiply_32x32_rshift32(val1 + val2, magnitude);
			*bp++ = val3;
			Lfo3Modoutput = val3 >> 8;
			if (LFO3phase == 0) {	// Shape normal
				ph += inc;
				phaseX += inc;
			else {
				ph -= inc;
			if (lfo3oneShoot == true && phaseX < inc) {
				ph = ph_old;
		case WAVEFORM_SAMPLE_HOLD1:
			uint32_t newph = ph + inc;
			if (lfo1oneShoot == true && LFO1randomFlag == false) {	// one shot
				sample = random(magnitude) - (magnitude >> 1);
				sample2 = sample;
				LFO1randomFlag = true;
			else if (newph < ph && lfo1oneShoot == false) {
			else if (lfo1oneShoot == true && LFO1randomFlag == true) {
				sample = sample2;
			*bp++ = sample;
			ph = newph;
		case WAVEFORM_SAMPLE_HOLD2:
			if (lfo2oneShoot == true && LFO2randomFlag == false) {	// one shot
				sample2 = sample;
				LFO2randomFlag = true;
			else if (newph < ph && lfo2oneShoot == false) {
			else if (lfo2oneShoot == true && LFO2randomFlag == true) {
				sample = sample2;
			*bp++ = sample;
			ph = newph;
		case WAVEFORM_SAMPLE_HOLD3:
			if (lfo3oneShoot == true && LFO3randomFlag == false) {	// one shot
				sample2 = sample;
				LFO3randomFlag = true;
			else if (newph < ph && lfo3oneShoot == false) {
			else if (lfo3oneShoot == true && LFO3randomFlag == true) {
				sample = sample2;
			*bp++ = sample;
			ph = newph;
	phase_accumulator = ph - phase_offset;
	if (tone_offset) {
		bp = block->data;
		end = bp + AUDIO_BLOCK_SAMPLES;
		do {
			val1 = *bp;
			*bp++ = signed_saturate_rshift(val1 + tone_offset, 16, 0);
		} while (bp < end);
	transmit(block, 0);
	release(block);
void AudioSynthWaveformModulatedTS::update(void)
	audio_block_t *block, *moddata, *shapedata;
	int16_t *bp, *end;
	int32_t val1, val2;
	uint32_t i, ph, index, index2, scale, priorphase;
	uint32_t phase_spread;
	uint32_t saw_phase_increment;
	uint32_t increments[3];
	uint32_t ph_1;
	uint32_t ph_2;
	uint32_t ph_3;
	uint32_t ph_4;
	int16_t Ssaw_value;
	moddata = receiveReadOnly(0);
	shapedata = receiveReadOnly(1);
	if(syncFlag==1){
		syncFlag = 0;
	// Pre-compute the phase angle for every output sample of this update
	ph = phase_accumulator;
	priorphase = phasedata[AUDIO_BLOCK_SAMPLES-1];
	if (moddata && modulation_type == 0) {
		// Frequency Modulation
		bp = moddata->data;
			int32_t n = (*bp++) * modulation_factor; // n is # of octaves to mod
			int32_t ipart = n >> 27; // 4 integer bits
			n &= 0x7FFFFFF;          // 27 fractional bits
			#ifdef IMPROVE_EXPONENTIAL_ACCURACY
			// exp2 polynomial suggested by Stefan Stenzel on "music-dsp"
			// mail list, Wed, 3 Sep 2014 10:08:55 +0200
			int32_t x = n << 3;
			n = multiply_accumulate_32x32_rshift32_rounded(536870912, x, 1494202713);
			int32_t sq = multiply_32x32_rshift32_rounded(x, x);
			n = multiply_accumulate_32x32_rshift32_rounded(n, sq, 1934101615);
			n = n + (multiply_32x32_rshift32_rounded(sq,
			multiply_32x32_rshift32_rounded(x, 1358044250)) << 1);
			n = n << 1;
			#else
			// exp2 algorithm by Laurent de Soras
			// https://www.musicdsp.org/en/latest/Other/106-fast-exp2-approximation.html
			n = (n + 134217728) << 3;
			n = multiply_32x32_rshift32_rounded(n, n);
			n = multiply_32x32_rshift32_rounded(n, 715827883) << 3;
			n = n + 715827882;
			uint32_t scale = n >> (14 - ipart);
			uint64_t phstep = (uint64_t)inc * scale;
			uint32_t phstep_msw = phstep >> 32;
			if (phstep_msw < 0x7FFE) {
				ph += phstep >> 16;
				ph += 0x7FFE0000;
			phasedata[i] = ph;
		release(moddata);
		} else if (moddata) {
		// Phase Modulation
		bp = moddata->data;
			// more than +/- 180 deg shift by 32 bit overflow of "n"
			uint32_t n = (uint16_t)(*bp++) * modulation_factor;
			phasedata[i] = ph + n;
			ph += inc;
		release(moddata);
		// No Modulation Input
			phasedata[i] = ph;
			ph += inc;
	phase_accumulator = ph;
	//Amplitude is always 1 on TSynth when oscillator is sounding
	//magnitude must be set to zero, otherwise digital noise comes through
	if(tone_type == WAVEFORM_SILENT){
		magnitude  = 0;
		}else{
		magnitude = 65536.0;
	// If the amplitude is zero, no output, but phase still increments properly
		if (shapedata) release(shapedata);
		return;
	block = allocate();
	if (!block) {
		return;
	bp = block->data;
	// Now generate the output samples using the pre-computed phase angles
	switch(tone_type) {
		case WAVEFORM_SINE:
			ph = phasedata[i];
			index = ph >> 24;
			val2 *= scale;
		case WAVEFORM_ARBITRARY:
		if (!arbdata) {
			release(block);
			return;
		// len = 256
			ph = phasedata[i];
			index = ph >> 24;
			index2 = index + 1;
			val2 *= scale;
		case WAVEFORM_PULSE:
		if (shapedata) {
				uint32_t width = ((shapedata->data[i] + 0x8000) & 0xFFFF) << 16;
				if (phasedata[i] < width) {
		} // else fall through to orginary square without shape modulation
		case WAVEFORM_SQUARE:
			if (phasedata[i] & 0x80000000) {
		case WAVEFORM_BANDLIMIT_PULSE:
		if (shapedata)
				int32_t val = band_limit_waveform.generate_pulse (phasedata[i], width, i) ;
				*bp++ = (int16_t) ((val * magnitude) >> 16) ;
		case WAVEFORM_BANDLIMIT_SQUARE:
		for (i = 0 ; i < AUDIO_BLOCK_SAMPLES ; i++)
			int32_t val = band_limit_waveform.generate_square (phasedata[i], i) ;
			*bp++ = (int16_t) ((val * magnitude) >> 16);
		// Quadsaw
		case WAVEFORM_SAWTOOTH:
		phase_spread = (phase_increment >> 14) * SupersawSpreadA;
		++phase_spread;
		saw_phase_increment = (phase_increment & 0x0000F9F3);
		for (uint8_t i = 0; i < 3; ++i) {
			saw_phase_increment += phase_spread;
			increments[i] = saw_phase_increment;
			data_qs_phase[0] += increments[0];
			data_qs_phase[1] += increments[1];
			data_qs_phase[2] += increments[2];
			ph_1 = phasedata[i];
			ph_2 = (ph_1 + data_qs_phase[0]);
			ph_3 = (ph_2 + data_qs_phase[1]);
			ph_4 = (ph_1 + data_qs_phase[2]);
			Ssaw_value = signed_multiply_32x16t(magnitude * Supersaw_gain1A, ph_1);
			Ssaw_value += signed_multiply_32x16t(magnitude * Supersaw_gain2A, ph_2);
			Ssaw_value += signed_multiply_32x16t(magnitude * Supersaw_gain2A, ph_3);
			Ssaw_value += signed_multiply_32x16t(magnitude * Supersaw_gain2A, ph_4);
			*bp++ = Ssaw_value;
		// Quadsaw 2
		case WAVEFORM_SAWTOOTH2:
		phase_spread = (phase_increment >> 14) * SupersawSpreadB;
		++phase_spread;
		saw_phase_increment = (phase_increment & 0x0000FFFF);
			data_qs_phase_2[0] += increments[0];
			data_qs_phase_2[1] += increments[1];
			data_qs_phase_2[2] += increments[2];
			ph_2 = (ph_1 + data_qs_phase_2[0]);
			ph_3 = (ph_2 + data_qs_phase_2[1]);
			ph_4 = (ph_3 + data_qs_phase_2[2]);
			Ssaw_value = signed_multiply_32x16t(magnitude * Supersaw_gain1B, ph_1);
			Ssaw_value += signed_multiply_32x16t(magnitude * Supersaw_gain2B, ph_2);
			Ssaw_value += signed_multiply_32x16t(magnitude * Supersaw_gain2B, ph_3);
			Ssaw_value += signed_multiply_32x16t(magnitude * Supersaw_gain2B, ph_4);
			*bp++ = Ssaw_value;
		case WAVEFORM_SAWTOOTH_REVERSE:
			*bp++ = signed_multiply_32x16t(0xFFFFFFFFu - magnitude, phasedata[i]);
		case WAVEFORM_BANDLIMIT_SAWTOOTH:
		case WAVEFORM_BANDLIMIT_SAWTOOTH_REVERSE:
			int16_t val = band_limit_waveform.generate_sawtooth (phasedata[i], i) ;
			val = (int16_t) ((val * magnitude) >> 16) ;
			*bp++ = tone_type == WAVEFORM_BANDLIMIT_SAWTOOTH_REVERSE ? (int16_t) -val : (int16_t) +val ;
		case WAVEFORM_TRIANGLE_VARIABLE:
		if (shapedata) {
				uint32_t width = (shapedata->data[i] + 0x8000) & 0xFFFF;
				uint32_t rise = 0xFFFFFFFF / width;
				uint32_t fall = 0xFFFFFFFF / (0xFFFF - width);
				uint32_t halfwidth = width << 15;
				uint32_t n;
				ph = phasedata[i];
				if (ph < halfwidth) {
					n = (ph >> 16) * rise;
					*bp++ = ((n >> 16) * magnitude) >> 16;
					} else if (ph < 0xFFFFFFFF - halfwidth) {
					n = 0x7FFFFFFF - (((ph - halfwidth) >> 16) * fall);
					*bp++ = (((int32_t)n >> 16) * magnitude) >> 16;
					n = ((ph + halfwidth) >> 16) * rise + 0x80000000;
				ph += inc;
		} // else fall through to orginary triangle without shape modulation
		case WAVEFORM_TRIANGLE:
			ph = phasedata[i];
		case WAVEFORM_SAMPLE_HOLD:
			ph = phasedata[i];
			if (ph < priorphase) { // does not work for phase modulation
			priorphase = ph;
			*bp++ = sample;
	if (tone_offset) {
		bp = block->data;
		do {
			val1 = *bp;
		} while (bp < end);
	transmit(block, 0);
	release(block);
// BandLimitedWaveform
#define SUPPORT_SHIFT 4
#define SUPPORT (1 << SUPPORT_SHIFT)
#define PTRMASK ((2 << SUPPORT_SHIFT) - 1)
#define SCALE 16
#define SCALE_MASK (SCALE-1)
#define N (SCALE * SUPPORT * 2)
#define GUARD_BITS 8
#define GUARD      (1 << GUARD_BITS)
#define HALF_GUARD (1 << (GUARD_BITS-1))
#define DEG180 0x80000000u
#define PHASE_SCALE (0x100000000L / (2 * BASE_AMPLITUDE))
extern "C"
	extern const int16_t step_table [258] ;
int32_t BandLimitedWaveform::lookup (int offset)
	int off = offset >> GUARD_BITS ;
	int frac = offset & (GUARD-1) ;
	int32_t a, b ;
	if (off < N/2)   // handle odd symmetry by reflecting table
		a = step_table [off+1] ;
		b = step_table [off+2] ;
		a = - step_table [N-off] ;
		b = - step_table [N-off-1] ;
	return  BASE_AMPLITUDE + ((frac * b + (GUARD - frac) * a + HALF_GUARD) >> GUARD_BITS) ; // interpolated
// create a new step, apply its past waveform into the cyclic sample buffer
// and add a step_state object into active list so it can be added for the future samples
void BandLimitedWaveform::insert_step (int offset, bool rising, int i)
	while (offset <= (N/2-SCALE)<<GUARD_BITS)
		if (offset >= 0)
		cyclic [i & 15] += rising ? lookup (offset) : -lookup (offset) ;
		offset += SCALE<<GUARD_BITS ;
		i ++ ;
	states[newptr].offset = offset ;
	states[newptr].positive = rising ;
	newptr = (newptr+1) & PTRMASK ;
// generate value for current sample from one active step, checking for the
// dc_offset adjustment at the end of the table.
int32_t BandLimitedWaveform::process_step (int i)
	int off = states[i].offset ;
	bool positive = states[i].positive ;
	int32_t entry = lookup (off) ;
	off += SCALE<<GUARD_BITS ;
	states[i].offset = off ;  // update offset in table for next sample
	if (off >= N<<GUARD_BITS)             // at end of step table we alter dc_offset to extend the step into future
	dc_offset += positive ? 2*BASE_AMPLITUDE : -2*BASE_AMPLITUDE ;
	return positive ? entry : -entry ;
// process all active steps for current sample, basically generating the waveform portion
// due only to steps
// square waves use this directly.
int32_t BandLimitedWaveform::process_active_steps (uint32_t new_phase)
	int32_t sample = dc_offset ;
	int step_count = (newptr - delptr) & PTRMASK ;
	if (step_count > 0)        // for any steps in-flight we sum in table entry and update its state
		int i = newptr ;
		do
			i = (i-1) & PTRMASK ;
			sample += process_step (i) ;
		} while (i != delptr) ;
		if (states[delptr].offset >= N<<GUARD_BITS)  // remove any finished entries from the buffer.
			delptr = (delptr+1) & PTRMASK ;
			// can be upto two steps per sample now for pulses
			if (newptr != delptr && states[delptr].offset >= N<<GUARD_BITS)
	return sample ;
// for sawtooth need to add in the slope and compensate for all the steps being one way
int32_t BandLimitedWaveform::process_active_steps_saw (uint32_t new_phase)
	int32_t sample = process_active_steps (new_phase) ;
	sample += (int16_t) ((((uint64_t)phase_word * (2*BASE_AMPLITUDE)) >> 32) - BASE_AMPLITUDE) ;  // generate the sloped part of the wave
	if (new_phase < DEG180 && phase_word >= DEG180) // detect wrap around, correct dc offset
	dc_offset += 2*BASE_AMPLITUDE ;
	return sample ;
// for pulse need to adjust the baseline according to the pulse width to cancel the DC component.
int32_t BandLimitedWaveform::process_active_steps_pulse (uint32_t new_phase, uint32_t pulse_width)
	return sample + BASE_AMPLITUDE/2 - pulse_width / (0x80000000u / BASE_AMPLITUDE) ; // correct DC offset for duty cycle
// Check for new steps using the phase update for the current sample for a square wave
void BandLimitedWaveform::new_step_check_square (uint32_t new_phase, int i)
	if (new_phase >= DEG180 && phase_word < DEG180) // detect falling step
		int32_t offset = (int32_t) ((uint64_t) (SCALE<<GUARD_BITS) * (sampled_width - phase_word) / (new_phase - phase_word)) ;
		if (offset == SCALE<<GUARD_BITS)
		offset -- ;
		if (pulse_state) // guard against two falling steps in a row (if pulse width changing for instance)
			insert_step (- offset, false, i) ;
			pulse_state = false ;
	else if (new_phase < DEG180 && phase_word >= DEG180) // detect wrap around, rising step
		int32_t offset = (int32_t) ((uint64_t) (SCALE<<GUARD_BITS) * (- phase_word) / (new_phase - phase_word)) ;
		offset -- ;
		if (!pulse_state) // guard against two rising steps in a row (if pulse width changing for instance)
			insert_step (- offset, true, i) ;
			pulse_state = true ;
// Checking for new steps for pulse waveform has to deal with changing frequency and pulse width and
// not letting a pulse glitch out of existence as these change across a single period of the waveform
// now we detect the rising edge just like for a square wave and use that to sample the pulse width
// parameter, which then has to be checked against the instantaneous frequency every sample.
void BandLimitedWaveform::new_step_check_pulse (uint32_t new_phase, uint32_t pulse_width, int i)
	if (pulse_state && phase_word < sampled_width && (new_phase >= sampled_width || new_phase < phase_word))  // falling edge
		offset -- ;
	if ((!pulse_state) && phase_word >= DEG180 && new_phase < DEG180) // detect wrap around, rising step
		// sample the pulse width value so its not changing under our feet later in cycle due to modulation
		sampled_width = pulse_width ;
		offset -- ;
		if (pulse_state && new_phase >= sampled_width) // detect falling step directly after a rising edge
		//if (new_phase - sampled_width < DEG180) // detect falling step directly after a rising edge
			offset -- ;
// new steps for sawtooth are at 180 degree point, always falling.
void BandLimitedWaveform::new_step_check_saw (uint32_t new_phase, int i)
		int32_t offset = (int32_t) ((uint64_t) (SCALE<<GUARD_BITS) * (DEG180 - phase_word) / (new_phase - phase_word)) ;
		offset -- ;
// the generation function pushd new sample into cyclic buffer, having taken out the oldest entry
// to return.  The output is thus 16 samples behind, which allows the non-casual step function to
// work in real time.
int16_t BandLimitedWaveform::generate_sawtooth (uint32_t new_phase, int i)
	new_step_check_saw (new_phase, i) ;
	int32_t val = process_active_steps_saw (new_phase) ;
	int16_t sample = (int16_t) cyclic [i&15] ;
	cyclic [i&15] = val ;
	phase_word = new_phase ;
	return sample ;
int16_t BandLimitedWaveform::generate_square (uint32_t new_phase, int i)
	new_step_check_square (new_phase, i) ;
	int32_t val = process_active_steps (new_phase) ;
	return sample ;
int16_t BandLimitedWaveform::generate_pulse (uint32_t new_phase, uint32_t pulse_width, int i)
	new_step_check_pulse (new_phase, pulse_width, i) ;
	int32_t val = process_active_steps_pulse (new_phase, pulse_width) ;
	int32_t sample = cyclic [i&15] ;
	return (int16_t) ((sample >> 1) - (sample >> 5)) ; // scale down to avoid overflow on narrow pulses, where the DC shift is big
void BandLimitedWaveform::init_sawtooth (uint32_t freq_word)
	phase_word = 0 ;
	newptr = 0 ;
	delptr = 0 ;
	for (int i = 0 ; i < 2*SUPPORT ; i++)
	phase_word -= freq_word ;
	dc_offset = phase_word < DEG180 ? BASE_AMPLITUDE : -BASE_AMPLITUDE ;
		uint32_t new_phase = phase_word + freq_word ;
		cyclic [i & 15] = (int16_t) process_active_steps_saw (new_phase) ;
void BandLimitedWaveform::init_square (uint32_t freq_word)
	init_pulse (freq_word, DEG180) ;
void BandLimitedWaveform::init_pulse (uint32_t freq_word, uint32_t pulse_width)
	phase_word = 0 ;
	newptr = 0 ;
	delptr = 0 ;
	if (phase_word < pulse_width)
		dc_offset = BASE_AMPLITUDE ;
		dc_offset = -BASE_AMPLITUDE ;
		cyclic [i & 15] = (int16_t) process_active_steps_pulse (new_phase, pulse_width) ;
BandLimitedWaveform::BandLimitedWaveform()
	newptr = 0 ;
	delptr = 0 ;
	phase_word = 0 ;
Which I believe is also a file in Audio.cpp. So again if both have the same functions in them, then you will end up with duplicates.
And if they are different then your synth_waveform.cpp has in it:
extern "C"
Which would be resolved by including the table from the audio library. It feels like your code includes some (or a whole lot) of the Audio library and also includes the Audio library. This will likely cause a these types of linking issues.
Not sure of the best way for you to resolve this. Remove all dependencies from Audio library? Rename more or less everything you are adding to have different names? Sorry I am not an expert on the Audio library so maybe someone else has some better ideas.
Good luck
I just renamed the table. Now the icons in Output are gone. But unfortunately there is still a big problem. The compiler stops without an error message!?
I will now try on old version 1.8.16 of Arduino :confused:
Do you have the Compile and Upload verbose mode turned on? You do that using the File --> Preference menu sequence. That might give you more information on the error(s). Your error file shows duplicate definitions for BandLimitedWaveform() and a bunch for data narrowing. I've not seen the narrowing message with the Arduino IDE, but in other compilers I've used, it's like to trying to shoehorn a 4-byte long into a 2-byte int...two bytes of data gets slopped on the floor. Usually, not good. I think most are the data types being passed to a function don't match the prototype, but it could be a simple data type mismatch. I think it's the former because the compiler seems to do a silent cast on simple assignments.
Hallo..
I solved the compiler problem. A function in my c code was misspelled. I only now noticed this error. The function has no return value, but void was missing before the function name.
Correctly programmed
[COLOR=#333333]FLASHMEM void print_String(uint16_t index, uint8_t xpos, uint8_t ypos) {[/COLOR]
My old code
// print const Text string from flash memory to xpos ypos on screen
FLASHMEM print_String(uint16_t index, uint8_t xpos, uint8_t ypos) {     // uuuuuuuuuuuhhhhhh  I `m so stupid
    char buffer[20];
    strcpy_P(buffer, (char*)pgm_read_dword(&(String_Tab[index])));
    tft.setCursor(xpos, ypos);
    tft.println(buffer);
Thanks for help :)
Glad you got it working. If you are still getting that very large set of warnings, it might be worth resolving them. Many were simple, such as assigning const float* to float*, passing signed to unsigned arguments, etc. Those are very easy to fix, and if you do have an error, will make it easier to see what's wrong.
Indeed, need to enable and scan Verbose build and look for warnings.
The other day did a quick int func(){,,,} and forgot the int func(){...; return intX;} - code built and CRASHED : finally saw the 'warning of NO RETURN' and problem solved. It took an hour to see that during online programmer chat when something else was assumed to be the problem!
