General_Hex
Within the past two days I have burned two teensy 4.1s with a third one being burned months ago. The one burned ages ago I know why they burned (because a pin received more than 3V) however the two that were burned within the last two days I am still unsure as to the reason.
I am currently working on a robot project where the teensy is in this circuit on a bread board (sorry I do not have any photos as I do not have access to the robot right now and I do not have a schematic):
the main power source for the entire robot is a 12V battery which directly powers 4 12V DC motors. Then a wire from the 12V line goes to a voltage step down which decreases the voltage to around 4.7V which is then used to power the Teensy.
The teensy's 3V pin is connected to a power line which is used to power:
Connected to the teensy's other pins are:
All ground wires of all components including Teensy are connected to the same ground line.
Motors have built in encoders.
I am tired of these expensive teensy's burning especially for reasons we still do not know, so I want to implement a new circuit to fully protect the teensy. The current plan is this:
My questions are these:
Notes:
- IMU (Gyro Sensor)
- 3 ultrasonic sensors
- IR Sensor (its a Building Blocks robotics IR sensor)
- PWM wire for each of the 4 motors
- Direction wire for each of the 4 motors
- I2C connection for IR sensor
- I2C connection for IMU
- Wire connected to switch connected to 3V line used for code (stopping and starting robot without turning off robot)
- Place one Diode (1A rated) on all motors' ground and power to protect teensy from reverse pulse
- Place Diode (1A rated) on the VIN pin of the teensy to protect from reverse polarisation
- Place 150mA fast burn Fuse on the VIN of the teensy to protect from high current
- Would all these methods work to protect the teensy?
- Is this overkill? if yes then how much would I need to do to ensure the teensy doesn't burn?
- is there anything else I can do to further protect the teensy?
Notes:
- I am a high school student new to electronics and teensys so please try to explain things in simple terms as I might not understand or know
- I can send the exact links of the components or specs of the components if that would help
- We are on a tight schedule as we have a State competition this weekend and if we cannot get something quickly or in store we are unlikely to be able to get it
- if there is any further information that would help please let me know
- the voltage step down already has a diode to protect it from reverse current (2A diode)
