I've been working on improved media keys support which can work with Windows. It's ready for initial testing. Hopefully there's still interest in this feature?
Code for Teensy LC & 3.x is on github now.
https://github.com/PaulStoffregen/cores
If you'd like to try this, download the cores repository and replace your hardware/teensy/avr/cores folder with its contents. On a Mac, control-click Arduino, then "Show Package Contents", and replace Contents/Java/hardware/teensy/avr/cores with the files from github.
I'm planning to back-port this to Teensy 2.0, after some testing. As you can see on the github commit log, this changed quite a lot of the USB keyboard code. I could really use some help with testing, especially on various Windows systems, and *especially* with the many non-US layouts. So far, I've done only initial testing on Windows 10, and only with "US English" keyboard layout.
The new media key support is intended to be used with Keyboard.press() and Keyboard.release(). Here's an example:
/* Buttons to USB Keyboard Example - Special Media Player Keys
You must select Keyboard from the "Tools > USB Type" menu
#include <Bounce.h>
// Create Bounce objects for each button. The Bounce object
// automatically deals with contact chatter or "bounce", and
// it makes detecting changes very simple.
Bounce button0 = Bounce(0, 10);
Bounce button1 = Bounce(1, 10); // 10 ms debounce time is appropriate
Bounce button2 = Bounce(2, 10); // for most mechanical pushbuttons
// TODO: fix pin 3 button on my testing board....
Bounce button3 = Bounce(4, 10);
Bounce button4 = Bounce(5, 10); // if a button is too "sensitive"
Bounce button5 = Bounce(6, 10); // you can increase this time.
// Configure the pins for input mode with pullup resistors.
// The pushbuttons connect from each pin to ground. When
// the button is pressed, the pin reads LOW because the button
// shorts it to ground. When released, the pin reads HIGH
// because the pullup resistor connects to +5 volts inside
// the chip.
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
// Update all the buttons. There should not be any long
// delays in loop(), so this runs repetitively at a rate
// faster than the buttons could be pressed and released.
button0.update();
button1.update();
button2.update();
button3.update();
button4.update();
button5.update();
// Check each button for "falling" edge.
// falling = high (not pressed - voltage from pullup resistor)
// to low (pressed - button connects pin to ground)
if (button0.fallingEdge()) {
Keyboard.press(KEY_MEDIA_PREV_TRACK);
Keyboard.release(KEY_MEDIA_PREV_TRACK);
if (button1.fallingEdge()) {
Keyboard.press(KEY_MEDIA_PLAY_PAUSE);
Keyboard.release(KEY_MEDIA_PLAY_PAUSE);
if (button2.fallingEdge()) {
Keyboard.press(KEY_MEDIA_NEXT_TRACK);
Keyboard.release(KEY_MEDIA_NEXT_TRACK);
if (button3.fallingEdge()) {
Keyboard.press(KEY_MEDIA_VOLUME_DEC);
Keyboard.release(KEY_MEDIA_VOLUME_DEC);
if (button4.fallingEdge()) {
Keyboard.press(KEY_MEDIA_VOLUME_INC);
Keyboard.release(KEY_MEDIA_VOLUME_INC);
if (button5.fallingEdge()) {
Keyboard.press(KEY_SYSTEM_POWER_DOWN);
Keyboard.release(KEY_SYSTEM_POWER_DOWN);
//Keyboard.press(KEY_MEDIA_EJECT);
//delay(300); // Mac OS-X will not recognize a very short eject press
//Keyboard.release(KEY_MEDIA_EJECT);
So far, these are the keys defined in
keylayouts.h:
KEY_MEDIA_PLAY
KEY_MEDIA_PAUSE
KEY_MEDIA_RECORD
KEY_MEDIA_FAST_FORWARD
KEY_MEDIA_REWIND
KEY_MEDIA_STOP
KEY_MEDIA_EJECT
KEY_MEDIA_RANDOM_PLAY
KEY_MEDIA_PLAY_SKIP
KEY_MEDIA_MUTE
KEY_SYSTEM_SLEEP
KEY_SYSTEM_WAKE_UP
Unlike the old code, which was limited to only 8 keys (which only worked on Mac & Linux), this new way is intended to be able to support all the media (aka HID Consumer Usage Page) key definitions, and all the system control keys too.
The Keyboard.press() and Keyboard.release() functions are meant to accept ASCII, and Unicode up to 0xC1FF (of course, each layout implements only a small fraction of the huge Unicode space), and non-ascii characters, and the many KEY_XYZ constants which map directly to HID usage numbers. Much of this code got reworked... and it seems to be functioning, but I haven't yet tested on non-US layouts. I could really use help testing from anyone using Teensy as a non-US keyboard.
If you find anything not working, please be sure to post a complete program and specify which layout and OS you're using, so I can try to reproduce and fix the problem.
