Let's talk of possible new accessory boards
Screens. It's really nice being able to get an ESP32 already wired to a screen, it saves so much spaghetti wiring in my projects and reduces radiated noise. I really like the design method of having the CPU behind the screen and using that as the project hub but when using Teensy my hand wired assemblies quickly become something resembling those balls of multicoloured rubber bands one used to see.
Teensies can run small LCDs way better than ESP32 but less convenient for a lazy lizard which is why I haven't been using many Teensies recently.
Imagine a range of LCDs, small to large, capacitive multitouch if you want it, Teensy solders right on the back with headers or castellations and there's rows of pins nearby with the IO accessible. Now I can just connect power and the specific project peripheral or driver to that assembly and my project is just about done.
So - like the ILI9341 but the backing board, instead of a single row of pins at the edge it has a Teensy stackable header somewhere in the middle with rows of IO breakout pins either side with thought for power distribution, some bulk capacitance and whatever other goodies. Nothing too fancy, low cost. But then have them big and small, touch and not, capacitive, resistive, ips, that kind of thing.
Anyone interested in an adaptor board to achieve this (pic shown below).
It would be a board to accept a Teensy 4.0 and an ESP32C3 Super Mini with the relevant pins routed together.
The 5V pins would be commoned, this would mean that the pair could be powered by the ESP32 C socket.
Serial ports would be connected together, probably to Teensy RX2/TX2.
Also SPI ports could be linked.
Let me know what you think.
@BriComp: If that combo would provide an easy, out-of-the-box, Wi-Fi capability to the T4, I'd definitely be interested !! I've had very good luck using serial between two T4's, so I'd personally lean towards the serial interconnection, but would be willing to investigate the other possibilities.
Mark J Culross
KD5RXT
One of the "use cases" I'm really hoping to address is the people wanting to build huge MIDI controllers with tons of analog pots, rotary encoders, switches. Or similar for audio synth projects where a large number of knobs or buttons control various audio settings rather than sending MIDI to a PC.
Or if you are crazy like me, you could run out of pins for displays... lol
or some pics of later ui's
I think this would be great, and I'm all for screens as I love great looking UIs and project
In the past I created a carrier board with a capacitive touch ILI9488 driven via 8/16 bit 8080 over FlexIO3 with a T4.1 mounted on the back
I also created with @Dogbone06 a product that uses an ILI9488 with a Teensy MicroMod driven via 8 bit 8080 on FlexIO2 with DMA.
And recently, some custom boards with SDRAM driving larger resolution panels via eLCDIF with @Dogbone06 as well.
But,
If we take the current Teensy models, we're limited in best case to 8bit 8080 with DMA or 16bit 8080 with some limited async capabilities.
The T4.0 can do SPI connectivity at best case
The T4.1 can do SPI and 8/16bit 8080 with no DMA for better performance
The Teensy MicroMod can do SPI and 8 bit 8080 with DMA for good performance and relativly small displays.
Ideally, I would have liked to see a next gen T4.x with SDRAM and LCD pins broken out to driver lager displays at higher frame rates.
I am currently building such a device with a DBv5, a 7" IPS display and a custom board to hold it all together.
So with all that being said, I think most people are capable enough to take any off the shelf SPI/8080 LCD module, design a carrier board and mount a Teensy to it.
I don't see many variants for smaller displays being produced by SF, as the size is small and this limits the peripherals you can mount on the board.
On a side note, they do have an LCD carrier board for the MicroMod - https://www.sparkfun.com/sparkfun-micromod-input-and-display-carrier-board.html
Adafruit has some microprocessors (Qualia) that have support for RGB-666 displays using a 40 pin flat cable. Of course having a direct HDMI port might be useful as well assuming you can get more memory on the Teensy.
They seemed interested in the WiFi+Bluetooth using Murata modules. They also expressed a general interest in anything we want, but want to focus on just a couple rather than try to do too many all at once.
But the overall impression was they've been focusing pretty much entirely on Teensy 4.0 & Teensy 4.1 without (so far) much thought much about accessories. That's partly by design. Robin and I knew they would probably face at least supply chain issues and many also production challenges, so we intentionally made extra batches of all the accessory products in late 2024. Initially they weren't so excited about the relatively large inventory on the accessories (audio shield, octows2811, pt8211 and other kits). Now they're pretty happy to have been able to focus all their effort only on Teensy since mid-March. So far I believe only the Ethernet kit has run out of stock, and they've had some questions about it. However, over the next few months they're going to have to think about most of the other existing accessories they haven't needed to make yet.
I can tell you right now WiFi and PoE are my main thoughts, mostly on a technical level. But I'm a little apprehensive about whether PoE will have substantial sales.
If they are going to take on production of Octo boards can we at least get a Rev2 version that de conflicts pins from Audio Board and to update with mappable DMA on 4.0/4.1? Seems silly to produce more of the same when it was a T3 design originally.
Regards Woody
Thanks for the update Paul was kind of curious on what their thoughts would be on the addition boards.
EDIT: As you said they are going to have their hands full on supply chain issues. At least thats one issue you and Robin don't have to worry about.
I appreciate the mentions, but to make it easier for people to find my website (and help my search results), I do want to point out that it is ProtoSupplies.com. All one word.
For those unfamiliar, I customize Teensy 4.1 with many different memory and pin configurations available on the website. I also do custom configurations as well for individuals and companies. The plan is to add 16MB PSRAM to the mix in the near'ish future.
I also have a few different Teensy 4.1 baseboards that may be useful for some applications. These tend to be complete platforms that include displays and various peripheral circuits and also have some available adapter cards like solderless breadboards. They are generic platforms and not targeted toward a specific application. This one happens to include an ESP32-C3 for WiFi with serial link to the Teensy 4.1.
To answer this specific question, probably no new OctoWS2811 board for a long time. A large quantity of the existing version was made and those boards sell very slowly. They probably won't run out for at least another year or two.
Indeed, worth knowing ProtoSupplies.com is there and where to look. I was going to post that board as the poster child of things a Teensy board could offer as far as accessory items one might want to include - this board demos them all with the only few unused pins taken to that left edge.
I got a preview board then updated with these items - not sure what is missing, or which might fit together for a simple accessory board.
KEY FEATURES OF MINI PLATFORM FOR TEENSY 4.1:
  • Small 5.4″ x 3.0″ board size
  • Teensy 4.1 included with optional QSPI PSRAM and Flash memory upgrades
  • ESP32-C3 co-processor for WiFi and Bluetooth connectivity and I2C display connector
  • 3.5” IPS 480×320 ST7796 LCD with capacitive touchscreen
  • SGTL5000 Audio Subsystem
  • 16MB NOR Flash memory on baseboard
  • 3 User buttons and RGB LED
  • CAN bus transceiver on CAN3
  • RS485 transceiver on Serial8
  • Host USB connector
  • Ethernet connector
  • High-speed MicroSD card slot on Teensy 4.1 with 32GB MicroSD card and SD to MicroSD Adapter
  • 20-pin IDC GPIO connector brings out serial ports, I2C, SPI, CAN, Analog inputs and digital I/O
  • CR2032 battery holder
  • DC-DC converter front-end for wide input voltage range of 6-16VDC
  • 3.3V on-board regulator to off-load and protect the Teensy 3.3V regulator
  • Input power setup supports DC power and USB power to Teensy 4.1 and ESP32-S be applied at the same time
  • Optional Solderless Breadboard Adapter can plug into IDC GPIO connector for prototyping
Appreciate the update. I’d better learn how to use KiCad 😝
A little behind on posts but glad you posted the link. Keep wanting to get a couple of your boards - on wish list.
Please let us know when you start offering the 16mb PSRAM. Probably will order a couple of boards. Eyes not good any more so anything to make it easier.
Thanks
Mike
ADS8885 perhaps, 18bit, differential input, 400kSPS, settle to 18 bit in 1.2us (basically no latency), SNR 100dB, THD -115dB, 3.3V powered but admits upto 5V reference...
BTW ADS1115 is only 860SPS, not 860kSPS !
Oops. Anyway the ADS8885 is a nice family, ADS8887 at 100KSPS to ADS881 at 1MSPS, good noise specs and they can daisy chain. I've designed with them.
Looking through the discussion, I noticed Paul's wishlist included multi-channel audio.
My recent stackable 8x8 audio board (designed in response to the end of life of the CS42448) is open source for hardware and software. It uses the TLV320 AIC3104 CODECs (which have slightly better specs than the AIC3204).
github: control library
github: 8x8 Audio board
forum discussion
h4yn0nnym0u5e has tested it all the way to 64 output channels, with a bit of hardware fudging.
Hopefully that will satisfy most user's needs!
I'd be happy for an official variant to be built, so that I don't have to sell the boards on Tindie!
@PaulStoffregen
Maybe with experienced accrued with the Teensy 4.0 and 4.1, it is might be worthwhile to revisit what interfaces are most useful and think about a minor rev, 4.2 perhaps.
For example, in my own experience, access to a complete set of pins for at least one flexpwm might be very enabling and open more design possibilities.
Perhaps there is a similarly broadly useful interface to the memory addess space?
And for other designers/users there may be other interfaces that they wish they had easier access.
In other words, the Teensy, being basically a carrier for an MCU, it seems to me that it is all about the interfaces and creating opportunity.
Here's the list I was thinking of yesterday.
  • analog mux + pot-with-cable
  • high performance ADC chip (not audio focused)
  • higher quality audio
  • many channel audio
  • MIDI in / out
  • power over ethernet
  • battery power / management
  • single pair ethernet or ethercat
  • wifi
Now 27 replies later, so much more to think about.
Please keep commenting... about accessory boards. This isn't the place to talk of new or modified Teensy models. Please try to stay focused on accessory boards that would work for Teensy 4.0 and/or Teensy 4.1. We can and will talk of ideas for Teensy later this year, but right now the topic is accessory boards (which have been woefully lacking all these years).
Should add high performance DAC (also, not audio focused).
High performance (probably at least 16 bits up to 20 bits, and 1MSPS) means you also need some analog circuitry on the board.
For range it should probably be 0V to 4V. So add an LDO, voltage ref and one of those small negative voltage ICs.
To really get performance close to 16 bits (or 20 bits) requires a pretty detailed design effort. But we can certainly do that.
On the other hand, there are cheap 16 bit boards. They seem to be just a bare ADC, they are slow (under 1KSPS) and actual performance could be 8 to 10 bits with the noise. But they sell for $6.
Are there enough customers for a board that really does give 16 bit performance, at 1MSPS? And would they buy it if it costs say.. $60?
I have a few designs that go futher, +/-4V range, very high impedance, 16 bits at 1MSPS. It is posted to github, and it is fantastically useful for a lab. But I am not aware of it getting a lot of traffic. I know that there are many people who use cheap usb modules and dont really appreciate the difference.
I would like to see a POE compatible Ethernet kit/fully assembled, with room for mounting a POE DC-DC module, a couple of QWIIC i2c connectors, along a couple of 1x5 headers for i2c ( including a INT pin)
