paoloboatto
I'm using the LittleFS library on a Teensy 4.1 and it works pretty well. I have made tests using a PSRAM soldered on the Teensy's bottom pads. I noticed that even when the PSRM chip is not soldered the function begin returns true. It can be easily tested ith the example LittleFS_PSRAM_Simple_Datalogger.ino
It would be very useful to be able to know if the PSRAM chip is mounted or not.
Is it a known bug? Is there a workaround?
