Magnethead494
On the racecar, dad was running the valvelash tonight, and noticed the numbers on the dial board changing. The numbers can only change via the bounce command....
I can't think of a reason for it to happen unless the teensy chip is staying powered up, but the 5V line is otherwise falling under 2.5 volts and registering a digital low?
battery is 18 volts, goes through an STMicro 12 volt regulator (KA378R12) to a 7805 5 volt reg to the teensy. The LED's (12 volt) turn off when the starter is bumped, which causes me to think teensy is somehow staying up yet registering a logic low...
It's random between the 3 switches/6 bounce commands.
