A library download from
https://github.com/m5stack/M5Unit-Synth/tree/main
and tried code example built in
got error .......here
seemed it is not for Teensy Board.
My Sam2695 module working well from teensy As Midi keyboard. for functions[noteOn,noteOff, progChange, CC#]etc.
but i want to use sound modify functions given in library see below
Does here Any other Solution?????
Thank you
C++:
#include "M5UnitSynth.h"
M5UnitSynth synth;
Serial.println("Unit Synth Piano");
synth.begin(&Serial2, UNIT_SYNTH_BAUD, 0, 1); // Rx.Tx
synth.setInstrument(0, 0, GrandPiano_1); // synth piano 1
synth.setNoteOn(0, NOTE_C4, 127);
synth.setNoteOn(0, NOTE_D4, 127);
synth.setNoteOn(0, NOTE_E4, 127);
synth.setNoteOn(0, NOTE_F4, 127);
synth.setNoteOn(0, NOTE_G4, 127);
synth.setNoteOn(0, NOTE_A4, 127);
synth.setNoteOn(0, NOTE_B4, 127);
synth.setNoteOn(0, NOTE_C5, 127);
C++:
Arduino: 1.8.19 (Windows 7), TD: 1.60-beta5, Board: "Teensy LC, Serial + MIDI, 48 MHz, Smallest Code, US English"
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\acer\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serialmidi,speed=48,opt=osstd,keys=en-us -ide-version=10819 -build-path C:\Users\acer\AppData\Local\Temp\arduino_build_625674 -warnings=none -build-cache C:\Users\acer\AppData\Local\Temp\arduino_cache_856999 -verbose C:\Users\acer\Documents\Arduino\TEENSY_LC_MIDI_KEY\TEENSY_LC_MIDI_KEY.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\acer\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serialmidi,speed=48,opt=osstd,keys=en-us -ide-version=10819 -build-path C:\Users\acer\AppData\Local\Temp\arduino_build_625674 -warnings=none -build-cache C:\Users\acer\AppData\Local\Temp\arduino_cache_856999 -verbose C:\Users\acer\Documents\Arduino\TEENSY_LC_MIDI_KEY\TEENSY_LC_MIDI_KEY.ino
Using board 'teensyLC' from platform in folder: C:\Program Files\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\\Program Files\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++17 -Wno-error=narrowing -fno-rtti -Wno-psabi -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=160 -DARDUINO=10819 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_MIDI_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674\\sketch\\TEENSY_LC_MIDI_KEY.ino.cpp" -o nul
Alternatives for M5UnitSynth.h: [M5Unit-Synth-main@1.0.1]
ResolveLibrary(M5UnitSynth.h)
-> candidates: [M5Unit-Synth-main@1.0.1]
"C:\\Program Files\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++17 -Wno-error=narrowing -fno-rtti -Wno-psabi -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=160 -DARDUINO=10819 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_MIDI_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\M5Unit-Synth-main\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674\\sketch\\TEENSY_LC_MIDI_KEY.ino.cpp" -o nul
"C:\\Program Files\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++17 -Wno-error=narrowing -fno-rtti -Wno-psabi -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=160 -DARDUINO=10819 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_MIDI_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\M5Unit-Synth-main\\src" "C:\\Users\\acer\\Documents\\Arduino\\libraries\\M5Unit-Synth-main\\src\\M5UnitSynth.cpp" -o nul
WARNING: library M5Unit-Synth-main claims to run on esp32 architecture(s) and may be incompatible with your current board which runs on avr architecture(s).
"C:\\Program Files\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++17 -Wno-error=narrowing -fno-rtti -Wno-psabi -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=160 -DARDUINO=10819 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_MIDI_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\M5Unit-Synth-main\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674\\sketch\\TEENSY_LC_MIDI_KEY.ino.cpp" -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674" "C:\\Program Files\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++17 -Wno-error=narrowing -fno-rtti -Wno-psabi -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=160 -DARDUINO=10819 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_MIDI_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674/pch/Arduino.h" -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674/pch/Arduino.h.gch"
"C:\\Program Files\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++17 -Wno-error=narrowing -fno-rtti -Wno-psabi -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=160 -DARDUINO=10819 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_MIDI_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674/pch" "-IC:\\Program Files\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\M5Unit-Synth-main\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674\\sketch\\TEENSY_LC_MIDI_KEY.ino.cpp" -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674\\sketch\\TEENSY_LC_MIDI_KEY.ino.cpp.o"
Compiling libraries...
Compiling library "M5Unit-Synth-main"
"C:\\Program Files\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++17 -Wno-error=narrowing -fno-rtti -Wno-psabi -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=160 -DARDUINO=10819 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_MIDI_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674/pch" "-IC:\\Program Files\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\M5Unit-Synth-main\\src" "C:\\Users\\acer\\Documents\\Arduino\\libraries\\M5Unit-Synth-main\\src\\M5UnitSynth.cpp" -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_625674\\libraries\\M5Unit-Synth-main\\M5UnitSynth.cpp.o"
C:\Users\acer\Documents\Arduino\libraries\M5Unit-Synth-main\src\M5UnitSynth.cpp: In member function 'void M5UnitSynth::begin(HardwareSerial*, int, uint8_t, uint8_t)':
C:\Users\acer\Documents\Arduino\libraries\M5Unit-Synth-main\src\M5UnitSynth.cpp:6:19: error: no matching function for call to 'HardwareSerial::begin(int&, int, uint8_t&, uint8_t&)'
6 | _serial->begin(baud, SERIAL_8N1, RX, TX);
In file included from C:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3/WProgram.h:47,
from C:\Users\acer\AppData\Local\Temp\arduino_build_625674/pch/Arduino.h:6,
from C:\Users\acer\Documents\Arduino\libraries\M5Unit-Synth-main\src\M5UnitSynth.h:5,
from C:\Users\acer\Documents\Arduino\libraries\M5Unit-Synth-main\src\M5UnitSynth.cpp:1:
C:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3/HardwareSerial.h:285:22: note: candidate: 'virtual void HardwareSerial::begin(uint32_t)'
285 | virtual void begin(uint32_t baud);
C:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3/HardwareSerial.h:285:22: note: candidate expects 1 argument, 4 provided
C:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3/HardwareSerial.h:286:22: note: candidate: 'virtual void HardwareSerial::begin(uint32_t, uint32_t)'
286 | virtual void begin(uint32_t baud, uint32_t format) {
C:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3/HardwareSerial.h:286:22: note: candidate expects 2 arguments, 4 provided
Using library M5Unit-Synth-main at version 1.0.1 in folder: C:\Users\acer\Documents\Arduino\libraries\M5Unit-Synth-main
Error compiling for board Teensy LC.
C++:
void begin(HardwareSerial *serial = &Serial1, int baud = UNIT_SYNTH_BAUD,
uint8_t RX = 16, uint8_t TX = 17);
void setInstrument(uint8_t bank, uint8_t channel, uint8_t value);
void setNoteOn(uint8_t channel, uint8_t pitch, uint8_t velocity);
void setNoteOff(uint8_t channel, uint8_t pitch, uint8_t velocity);
void setAllNotesOff(uint8_t channel);
void setPitchBend(uint8_t channel, int value);
void setPitchBendRange(uint8_t channel, uint8_t value);
void setMasterVolume(uint8_t level); // 0-127
void setVolume(uint8_t channel, uint8_t level); // 0-127
void setExpression(uint8_t channel, uint8_t expression); // 0-127
void setReverb(uint8_t channel, uint8_t program, uint8_t level,
uint8_t delayfeedback);
void setChorus(uint8_t channel, uint8_t program, uint8_t level,
uint8_t feedback, uint8_t chorusdelay);
void setPan(uint8_t channel, uint8_t value);
void setEqualizer(uint8_t channel, uint8_t lowband, uint8_t medlowband,
uint8_t medhighband, uint8_t highband, uint8_t lowfreq,
uint8_t medlowfreq, uint8_t medhighfreq,
uint8_t highfreq);
void setTuning(uint8_t channel, uint8_t fine,
uint8_t coarse); // 0-127, 64 is default t
void setVibrate(uint8_t channel, uint8_t rate, uint8_t depth,
uint8_t delay);
void setTvf(uint8_t channel, uint8_t cutoff, uint8_t resonance);
void setEnvelope(uint8_t channel, uint8_t attack, uint8_t decay,
uint8_t release);
void setModWheel(uint8_t channel, uint8_t pitch, uint8_t tvtcutoff,
uint8_t amplitude, uint8_t rate, uint8_t pitchdepth,
uint8_t tvfdepth, uint8_t tvadepth);
Thank you
