Matadormac
Hello the list.
I have completed my portable meter project and put in a case. Field testing shows that the ILI9341 wired as suggested in the PJRC store page and using a 100 ohm resistor from VCC to LED is bright enough in low light indoor situations but unreadable in higher light situations especially out of doors (even in shade). I would be happy for a display bright enough to readily read in all indoor lighting situations and just possibly in the shade out of doors but this last is currently not a great need.
In posts on this list I see some people have "brightened" their ILI9341 display by using a lower resistance value resistor. bboyes has used a 5 ohms resistor while FrankB has used a 10 ohm resistor from VCC to LED.
The sensors I am using are low power consumption and only on upon demand, battery life is not a great issue at this time.
Are there any reliability issues or other issues I should be aware of before trying these lower value resistors with my project? Oh, yes, Teensy 3.2 is the micro-controller I am using. The ILI9341 display is wired to the Teensy 3.2 3.3V output.
Thoughts and advice?
Best
Best
