May i contact to "Bleep Labs."???
It is necessary in my code to load the samples into RAM.I removed the vocoder code and tried loading the RAM & play sample, the same files loaded very quickly in just 1 second and start play. Simple code without vocoder is as follow:
C++:
#include <Audio.h>               // WAV playing will
#include "effect_phaseVocoder.h"
AudioEffectPhaseVocoder vocoder;
 AudioOutputI2S       audioOut;
 AudioControlSGTL5000 codec;
AudioConnection patchLeft (vocoder, 0, audioOut, 0);
AudioConnection patchRight(vocoder, 0, audioOut, 1);
// RAM CODE
#define NUM_WAVS 16 // avoid silly mistakes
 const char *SMP_WAV[NUM_WAVS] = { "A01.WAV", "A02.WAV", "A03.WAV", "A04.WAV", "05.WAV", "06.WAV", "07.WAV", "08.WAV", "09.WAV", "10.WAV", "11.WAV", "12.WAV", "13.WAV", "14.WAV", "15.WAV", "16.WAV" };
File x_File;
int16_t *SMP_addr[NUM_WAVS];
uint32_t sizes[NUM_WAVS];
    AudioMemory(40);
    Serial.begin(57600);
     codec.enable();
     codec.volume(0.5f);
    if (!SD.begin(BUILTIN_SDCARD)) {
        Serial.println("SD init failed");
        return;
     Serial.println("Card ok");
     RAM_LOAD ();        Serial.println("RAM loaded........................");
     vocoder.stop();
      vocoder.setSample(SMP_addr[0], sizes[0]/2);
        vocoder.setLoop(true);
     //   applyStretch(stretch);
        vocoder.play();
            void RAM_LOAD ()  {
  int SMP_FILE_NUM=0;
  for (int i = 0; i < NUM_WAVS; i++) {
                              x_File = SD.open(SMP_WAV[i], FILE_READ);
                             if (x_File)
      sizes[i] = x_File.size();
      SMP_addr[i] = (int16_t*) extmem_malloc(sizes[i]);
      if (nullptr == SMP_addr[i])
        Serial.printf("Failed to allocate %d in EXTMEM for %s\n", sizes[i], SMP_WAV[i]);
      else     {
        if (sizes[i] != x_File.read(SMP_addr[i], sizes[i]))
          Serial.printf("Failed to read in %s - wrong length\n", SMP_WAV[i]);
          extmem_free(SMP_addr[i]); // free memory
          SMP_addr[i] = nullptr;    // mark as "not loaded"
          Serial.printf("Read %s into memory at %08X; %d bytes\n", SMP_WAV[i], SMP_addr[i], sizes[i]);
      x_File.close();
      Serial.printf("Failed to open %s\n", SMP_WAV[i]);
I'll try to slowly mix the more vocoder code into this sketch.
in vocoder.setSample(SMP_addr[3], sizes[3] / 2); i used sizes[3] / 2) only for complete duration of my drum loop.If I don't do this, then in loop mode, half the sequence plays with the SMP_addr[3] and the other half plays with some other sample. when i use vocoder.setSample(SMP_addr[3], sizes[3] / 2); Selected samples play well with complete duration.
After mixing more control code I will report what I got......
Thank you.............
If we want to load a new sample with New size into the same stretcher, do we need to clear the stretcher memory first? If yes.... What function should be called????
If no more than 4 stretches are run at a time .Considering the psram capacity, how many stretcher objects can we create using the mixer?
If you want to load a new sample just use vocoder.setSample(newBuffer, newNumSamples);
Sorry I don't know what you mean
I mean, no more than four stretchers will be call to vocoder.play(); through the mixer simultaneously. I can only work with four or so at the same time.The remaining stretchers will remain stopped until further inputs are issued. something like this
Thank you Paul.. You made phase vocoder library. Using it I found some imperfections.
Should I start new thread with name "Phase vocoder" Or ask here in this thread??? I will continue after your reply..
Thank you Paul, I appreciate your work in Teensy Development.
Here I want to tell you the flaws I am seeing in its performance.Like this is your own example code:
C++:
// timestretch_example.ino
// Phase vocoder time-stretching — Teensy 4.x + Audio Shield (SGTL5000)
// Controls (Serial):
//   SPACE  start / restart playback
//   s      stop playback
//   p      faster  (decrease stretch)
//   q      slower  (increase stretch)
//   1-3    load and play 01.WAV / 02.WAV / 03.WAV
//   t      transient threshold: 4  (sensitive — more phase resets)
//   y      transient threshold: 8  (default)
//   u      transient threshold: 16 (subtle — fewer phase resets)
//   d      toggle profiling report
//   h      print help
// Optional: pot wiper → A0 (outer legs to 3.3 V and GND)
//   Pot maps to stretch STRETCH_MIN … STRETCH_MAX
// Audio graph
// AudioOutputUSB          audioOut;
// Config
static const int   POT_PIN      = A0;
static const float STRETCH_MIN  = 0.5f;   // 0.5 = half duration (2× faster)
static const float STRETCH_MAX  = 1.5f;   // 1.5 = 1.5× duration (slower)
static const int   POT_READ_MS  = 50;
static const float CONTROL_STEP = 0.01f;
static const bool  USE_POT      = false;
float stretch   = 1.0f;
float pitchSt   = 0.0f;   // pitch shift in semitones
bool  profiling = false;
// Sample buffer
// DMAMEM places in OCRAM (512 KB) instead of DTCM.
// On Teensy 4.1 with PSRAM: replace DMAMEM with EXTMEM for much larger buffers.
EXTMEM int16_t sampleBuffer[44100 * 5];  //  DMAMEM
static uint32_t sampleCount = 0;
static const char *sampleFiles[] = { "A01.WAV", "A02.WAV", "A03.WAV" };
static int currentSample = 0;
// Helpers
static float clampf(float v, float lo, float hi) {
    return v < lo ? lo : v > hi ? hi : v;
static void applyStretch(float newStretch) {
    stretch = clampf(newStretch, STRETCH_MIN, STRETCH_MAX);
    vocoder.setStretch(stretch);
    float durationS = stretch * (sampleCount / (float)AUDIO_SAMPLE_RATE_EXACT);
    Serial.print("x  Speed: "); Serial.print(1.0f / stretch, 2);
    Serial.print("x  Duration: "); Serial.print(durationS, 1); Serial.println("s");
static void printHelp() {
    Serial.println("--- Controls ---");
    Serial.println("  SPACE  start / restart");
    Serial.println("  s      stop");
    Serial.println("  p      faster");
    Serial.println("  q      slower");
    Serial.println("  1-3    load 01.WAV / 02.WAV / 03.WAV");
    Serial.println("  w      pitch up 1 semitone");
    Serial.println("  x      pitch down 1 semitone");
    Serial.println("  z      reset pitch to 0");
    Serial.println("  t      transient threshold: 4  (sensitive)");
    Serial.println("  y      transient threshold: 8  (default)");
    Serial.println("  u      transient threshold: 16 (subtle)");
    Serial.println("  d      toggle profiling");
    Serial.println("  e      print per-section costs");
    Serial.println("  h      this help");
// WAV loader — handles mono and stereo (stereo: left channel only).
// Reads channel count from WAV header offset 22.
static bool loadSampleFromSD(const char *filename) {
    File f = SD.open(filename);
    if (!f) {
        Serial.print("Could not open: "); Serial.println(filename);
        return false;
    f.seek(22);
    int chanLo = f.read();
    int chanHi = f.read();
    if (chanLo < 0 || chanHi < 0) { f.close(); return false; }
    const uint16_t numChannels = (uint16_t)((chanHi << 8) | chanLo);
    f.seek(44);  // skip 44-byte WAV header to raw PCM data
    sampleCount = 0;
    const uint32_t maxSamples = sizeof(sampleBuffer) / sizeof(sampleBuffer[0]);
    while (f.available() && sampleCount < maxSamples) {
        int lo = f.read();
        int hi = f.read();
        if (lo < 0 || hi < 0) break;
        sampleBuffer[sampleCount++] = (int16_t)((hi << 8) | lo);
        if (numChannels == 2) {
            // skip right channel sample
            if (f.read() < 0 || f.read() < 0) break;
    f.close();
    Serial.print("Loaded: "); Serial.print(filename);
    Serial.print("  samples: "); Serial.print(sampleCount);
    Serial.print("  ch: "); Serial.print(numChannels);
    Serial.print("  dur: "); Serial.print(sampleCount / (float)AUDIO_SAMPLE_RATE_EXACT, 1);
    return sampleCount > 0;
static void loadAndPlay(int index) {
    currentSample = index;
    vocoder.stop();
    if (loadSampleFromSD(sampleFiles[index])) {
        vocoder.setSample(sampleBuffer, sampleCount);
        vocoder.play();
// setup
    AudioMemory(40);
    while (!Serial && millis() < 2000) {}
      codec.enable();
      codec.volume(0.5f);
        return;
    vocoder.setTransientThreshold(16.0f);
    loadAndPlay(0);
    printHelp();
// loop
    static uint32_t lastPotRead = 0;
    static uint32_t lastProf    = 0;
    if (Serial.available() > 0) {
        char key = Serial.read();
        if      (key == ' ')                { vocoder.stop(); vocoder.play(); Serial.println("Playing"); }
        else if (key == 's')                { vocoder.stop(); Serial.println("Stopped"); }
        else if (key == 'p')                applyStretch(stretch - CONTROL_STEP);  // faster
        else if (key == 'q')                applyStretch(stretch + CONTROL_STEP);  // slower
        else if (key >= '1' && key <= '3')  loadAndPlay(key - '1');
        else if (key == 'w')                { pitchSt += 1.0f; vocoder.setPitchShift(pitchSt); Serial.print("Pitch: "); Serial.print(pitchSt, 0); Serial.println(" st"); }
        else if (key == 'x')                { pitchSt -= 1.0f; vocoder.setPitchShift(pitchSt); Serial.print("Pitch: "); Serial.print(pitchSt, 0); Serial.println(" st"); }
        else if (key == 'z')                { pitchSt = 0.0f;  vocoder.setPitchShift(pitchSt); Serial.println("Pitch: 0 st"); }
        else if (key == 't')                { vocoder.setTransientThreshold(4.0f);  Serial.println("Transient threshold: 4"); }
        else if (key == 'y')                { vocoder.setTransientThreshold(8.0f);  Serial.println("Transient threshold: 8"); }
        else if (key == 'u')                { vocoder.setTransientThreshold(16.0f); Serial.println("Transient threshold: 16"); }
        else if (key == 'd')                { profiling = !profiling; Serial.println(profiling ? "Profiling: on" : "Profiling: off"); }
        else if (key == 'e')                {
            float tW, tF, tA, tS, tI, tO;
            if (vocoder.getProfilingDetailed(tW, tF, tA, tS, tI, tO)) {
                Serial.println("--- Section costs (mean µs) ---");
                Serial.print("  window fill:     "); Serial.println(tW, 1);
                Serial.print("  forward FFT:     "); Serial.println(tF, 1);
                Serial.print("  phase analysis:  "); Serial.println(tA, 1);
                Serial.print("  phase synthesis: "); Serial.println(tS, 1);
                Serial.print("  inverse FFT:     "); Serial.println(tI, 1);
                Serial.print("  OLA + output:    "); Serial.println(tO, 1);
        else if (key == 'h')                printHelp();
    // Profiling report every 2 seconds
    if (profiling && millis() - lastProf >= 2000) {
        lastProf = millis();
        float    meanUs;
        uint32_t peakUs;
        if (vocoder.getProfiling(meanUs, peakUs)) {
            const float budgetUs = 1e6f / (AUDIO_SAMPLE_RATE_EXACT / (float)AUDIO_BLOCK_SAMPLES);
            Serial.print("update()  mean: "); Serial.print(meanUs, 1);
            Serial.print(" us  peak: ");      Serial.print(peakUs);
            Serial.print(" us  load: ");      Serial.print(meanUs / budgetUs * 100.0f, 1);
            Serial.println("%");
    if (USE_POT && millis() - lastPotRead >= POT_READ_MS) {
        lastPotRead = millis();
        int raw = analogRead(POT_PIN);
        applyStretch(STRETCH_MIN + (raw / 1023.0f) * (STRETCH_MAX - STRETCH_MIN));
While listening to the time stretching of A01.wav using this code, I noticed that increasing or decreasing the stretch ratio from 1.0 has a slightly negative impact on the audio quality.Sometimes, fluctuations in the audio volume of the sample are also heard during time stretching.i have also test vocoder.setTransientThreshold with 4.0 ,8.0, 16.0 but no satisfy. I urge you to try using the attached drum loops"A01.wav" with above code. Be sure to check what you're feeling by listening to the stretch ratio from 0.5 to 1.5 through a good quality audio amp/monitor/headphones by Audio out jack of board.I believe that if you stretch it up/down yourself and listen to it carefully, you will be able to improve better..Your ability is telling, I hope you will update the library's algoritham upto professional quality audio Time Stretching.
good luck.......
  • A01.zip
C++:
//   s      stop playback
//   h      print help
// Audio graph
// Config
// Sample buffer
// Helpers
    if (!f) {
        return false;
    f.seek(22);
    sampleCount = 0;
        int lo = f.read();
        int hi = f.read();
    f.close();
    vocoder.stop();
        vocoder.play();
// setup
    AudioMemory(40);
      codec.enable();
      codec.volume(0.5f);
        return;
    loadAndPlay(0);
    printHelp();
// loop
        float    meanUs;
        uint32_t peakUs;
good luck.......
Having examined the audio library supplied with Teensyduino I cannot find the example you mention above. I do not believe that it is Paul's code.
Thank You ..BriComp.. For Interest here above code is
here
i only Changed AudioOutputUSB audioOut; into AudioOutputI2S audioOut;
you can check it. I'm afraid Paul might ignore my request for post #57 because of the new reply. I once again appeal to Paul sir to please take a look at my post #57. If you have time, you can address it properly. thank you .............
