// https://forum.pjrc.com/threads/33443-How-to-display-free-ram
void getFreeITCM();// { // end of CODE ITCM, skip full 32 bits
pinMode( LED_BUILTIN, OUTPUT );
digitalWrite( LED_BUILTIN, HIGH );
while (!Serial);
digitalWrite( LED_BUILTIN, LOW );
if ( CrashReport ) Serial.print ( CrashReport );
memInfo();
getFreeITCM();
#define printf Serial.printf
#if ARDUINO_TEENSY41
extern "C" uint8_t external_psram_size;
void memInfo () {
constexpr auto RAM_BASE = 0x2020'0000;
constexpr auto RAM_SIZE = 512 << 10;
constexpr auto FLASH_BASE = 0x6000'0000;
#if ARDUINO_TEENSY40
constexpr auto FLASH_SIZE = 2 << 20;
#elif ARDUINO_TEENSY41
constexpr auto FLASH_SIZE = 8 << 20;
// note: these values are defined by the linker, they are not valid memory
// locations in all cases - by defining them as arrays, the C++ compiler
// will use the address of these definitions - it's a big hack, but there's
// really no clean way to get at linker-defined symbols from the .ld file
extern char _stext[], _etext[], _sbss[], _ebss[], _sdata[], _edata[],
_estack[], _heap_start[], _heap_end[], _itcm_block_count[], *__brkval;
auto sp = (char*) __builtin_frame_address(0);
printf("_stext %08x\n", _stext);
printf("_etext %08x +%db\n", _etext, _etext - _stext);
printf("_sdata %08x\n", _sdata);
printf("_edata %08x +%db\n", _edata, _edata - _sdata);
printf("_sbss %08x\n", _sbss);
printf("_ebss %08x +%db\n", _ebss, _ebss - _sbss);
printf("curr stack %08x +%db\n", sp, sp - _ebss);
printf("_estack %08x +%db\n", _estack, _estack - sp);
printf("_heap_start %08x\n", _heap_start);
printf("__brkval %08x +%db\n", __brkval, __brkval - _heap_start);
printf("_heap_end %08x +%db\n", _heap_end, _heap_end - __brkval);
extern char _extram_start[], _extram_end[], *__brkval;
printf("_extram_start %08x\n", _extram_start);
printf("_extram_end %08x +%db\n", _extram_end,
_extram_end - _extram_start);
printf("\n");
printf("<ITCM> %08x .. %08x\n",
_stext, _stext + ((int) _itcm_block_count << 15) - 1);
printf("<DTCM> %08x .. %08x\n",
_sdata, _estack - 1);
printf("<RAM> %08x .. %08x\n",
RAM_BASE, RAM_BASE + RAM_SIZE - 1);
printf("<FLASH> %08x .. %08x\n",
FLASH_BASE, FLASH_BASE + FLASH_SIZE - 1);
if (external_psram_size > 0)
printf("<PSRAM> %08x .. %08x\n",
_extram_start, _extram_start + (external_psram_size << 20) - 1);
printf("\n");
auto stack = sp - _ebss;
printf("avail STACK %8d b %5d kb\n", stack, stack >> 10);
auto heap = _heap_end - __brkval;
printf("avail HEAP %8d b %5d kb\n", heap, heap >> 10);
auto psram = _extram_start + (external_psram_size << 20) - _extram_end;
printf("avail PSRAM %8d b %5d kb\n", psram, psram >> 10);
uint32_t *ptrFreeITCM; // Set to Usable ITCM free RAM
uint32_t sizeofFreeITCM; // sizeof free RAM in uint32_t units.
uint32_t SizeLeft_etext;
extern char _stext[], _etext[];
FLASHMEM void getFreeITCM() { // end of CODE ITCM, skip full 32 bits
Serial.println("\n\n++++++++++++++++++++++");
SizeLeft_etext = (32 * 1024) - (((uint32_t)&_etext - (uint32_t)&_stext) % (32 * 1024));
sizeofFreeITCM = SizeLeft_etext - 4;
sizeofFreeITCM /= sizeof(ptrFreeITCM[0]);
ptrFreeITCM = (uint32_t *) ( (uint32_t)&_stext + (uint32_t)&_etext + 4 );
printf( "Size of Free ITCM in Bytes = %u\n", sizeofFreeITCM * sizeof(ptrFreeITCM[0]) );
printf( "Start of Free ITCM = %u [%X] \n", ptrFreeITCM, ptrFreeITCM);
printf( "End of Free ITCM = %u [%X] \n", ptrFreeITCM + sizeofFreeITCM, ptrFreeITCM + sizeofFreeITCM);
for ( uint32_t ii = 0; ii < sizeofFreeITCM; ii++) ptrFreeITCM[ii] = 1;
uint32_t jj = 0;
for ( uint32_t ii = 0; ii < sizeofFreeITCM; ii++) jj += ptrFreeITCM[ii];
printf( "ITCM DWORD cnt = %u [#bytes=%u] \n", jj, jj*4);
