MFC won't receive Midi-Channel sysex msg (0x17) or AXEFX2 does not send it.
bossredman
I have a home-made MFC (midi Foot Controller).
It uses a Teensy 3.6 MPC.
It performs most tasks adequately (ie: change Preset/Scene, read Reset name, toggle individual effects on/off etc).
However - I'm trying to get it to detect if the AXEFX 2 is switched on - before it starts running the main Loop of the code.
I thought I could do this by sending the 'get Midi Channel' sysex mgs & then reading the returned channel.
I use a while loop to loop sending the msg until the Channel is read.
long MdCh = 1;
while (got_MIDI_CH != true)
tft.setFontScale(1);                tft.setCursor(100, 350);
tft.print("Trying to read Midi Channel: ");               tft.print(MdCh);
tft.setCursor(100, 390);
tft.print("Sysex: ");               tft.print(sysex_label);
byte Get_MIDI_CH[8] ={0xF0, 0x00, 0x01, 0x74, 0x03, 0x17, 0x11, 0xF7};
MIDI.sendSysEx(8,Get_MIDI_CH, true);
MIDI.read();
MdCh++;
Here's the sysex read code snippet
else if (SysExArray[5] == 0x17)
sysex_label = "Midi Channel";
sysex_value = SysExArray[6];
sysex_value2 = String(sysex_value);
got_MIDI_CH = true;
But - if the AXEFX is ON, but I then switch on the MFC, the AXEFX never sends or the MFC never reads the Channel (or both).
However, if the MFC is ON, but then I switch on AXEFX - it does.
Any ideas pls?
Was wondering if anyone knows of anything that would prevent the Midi Channel msg being sent or even blocked?
ie: does something else need to be enabled first or if something else is running this prohibits the channel msg???
Unplug MFC > AXE-FX Midi.
Boot up AxeFx then MFC then re-plug Midi, theoretically ruling out the MFC sending spurious stuff during startup confusing AxeFx's read handler.
Not explored AxeFx here but have seen this scenario mess up other gear.
