Hello! I'm using a Teensy 4.1 and I'm going to add MIDI in/out (both DIN and TRS). I'm copying the schematic from MIDI Library page.
Couple of things:
1. The schematic shows pin 8 of the 6N138 being attached to Teensy's VIN and it's labeled as 5V. Just as a learning opportunity: that's because the 6N138 operates better at 5v?
2. And VIN is labeled as 5V because that's what USB provides?
3. And MIDI itself works for both 3.3V or 5V?
4. Are the two 3.3V pins on the Teensy 4.1 the same?
5. Is it less performant to use decoupled TX/RX pairs? Like I'm planning on using RX5, TX3, RX4, TX8 (just for the sake of using pins closer to the physical socket); will I take a hit compared to using something like RX2, TX2, RX3, TX3.
Does this schematic generally look right?
- DIN_MIDI_IN: pin 21 (RX5)
- TRS_MIDI_IN: pin 16 (RX4)
- DIN_MIDI_OUT: pin 14 (TX3)
- TRS_MIDI_OUT: pin 35 (TX8)
- +3.3V: 3.3V
- +5V: Vin
- GND: GND
Couple of things:
- +3.3V: 3.3V
- +5V: Vin
- GND: GND
