nicolas_soundforce
Hi!
I am planning to use the traditionnal non-usb library with the TeensyLC.
https://www.pjrc.com/teensy/td_libs_MIDI.html
I am wondering which parameters of the circuit are changing for the LC ?
It uses the RX&TX pins, so on the LC pin 0 & pin 1 I suppose ?
For the output, should I also get 47ohm resistors like for the Teensy 3 ?
Thanks in advance,
Nicolas.
Thanks in advance,
Nicolas.
