Greetings all!
First time here and first teensy project.
So im building a stompbox for my bandmate. It is a four button + expedal.
Iv got almost everything working exept the behavior of the switches.
The switches are spdt-switches, the problem is that it only sends midiCC when the switches are in gnd state(pullup) hence i have to press two times (instead of one) for a mapped button in my daw to change (since its a toggleswitch), the code seems to be for momentary buttons.
Im using the code posted by oddson: mod on "manybuttonsknobs"
i dont really know how to do a wiringdiagram but this is basically how the wiring is done.
So, i humbly ask for help regarding the code to make it momentary (since its toggle switches), also dont really know how to make a wiringdiagram..
Any help is appreciated, take care
// include the ResponsiveAnalogRead library for analog smoothing
#include <ResponsiveAnalogRead.h>
// include the Bounce library for 'de-bouncing' switches -- removing electrical chatter as contacts settle
#include <Bounce.h>
//usbMIDI.h library is added automatically when code is compiled as a MIDI device
// ******CONSTANT VALUES********
// customize code behaviour here!
const int channel = 1; // MIDI channel
const int A_PINS = 1; // number of Analog PINS
const int D_PINS = 4; // number of Digital PINS
const int ON_VALUE = 127; // note-one velocity sent from buttons (should be 65 to 127)
// define the pins you want to use and the CC ID numbers on which to send them..
const int ANALOG_PINS[A_PINS] = {A1};
const int CCID[A_PINS] = {21};
// define the pins and notes for digital events
const int DIGITAL_PINS[D_PINS] = {7,8,9,10};
const int CC[D_PINS] = {60,61,62,63};
const int BOUNCE_TIME = 7; // 5 ms is usually sufficient
const boolean toggled = false;
//******VARIABLES***********
// a data array and a lagged copy to tell when MIDI changes are required
byte data[A_PINS];
byte dataLag[A_PINS]; // when lag and new are not the same then update MIDI CC value
byte CClast[D_PINS];
//************INITIALIZE LIBRARY OBJECTS**************
// not sure if there is a better way... some way run a setup loop on global array??
// use comment tags to comment out unused portions of array definitions
// initialize the ReponsiveAnalogRead objects
ResponsiveAnalogRead analog[]{
{ANALOG_PINS[0],true}/*,
{ANALOG_PINS[1],true},
{ANALOG_PINS[2],true},
{ANALOG_PINS[3],true},
{ANALOG_PINS[4],true},
{ANALOG_PINS[5],true},
{ANALOG_PINS[6],true},
{ANALOG_PINS[7],true},*/
// initialize the bounce objects
Bounce digital[] = {
Bounce(DIGITAL_PINS[0],BOUNCE_TIME),
Bounce(DIGITAL_PINS[1], BOUNCE_TIME),
Bounce(DIGITAL_PINS[2], BOUNCE_TIME),
Bounce(DIGITAL_PINS[3], BOUNCE_TIME)/*,
Bounce(DIGITAL_PINS[4], BOUNCE_TIME),
Bounce(DIGITAL_PINS[5], BOUNCE_TIME)/*,
Bounce(DIGITAL_PINS[6], BOUNCE_TIME),
Bounce(DIGITAL_PINS[7], BOUNCE_TIME),*/
//************SETUP**************
// loop to configure input pins and internal pullup resisters for digital section
for (int i=0;i<D_PINS;i++){
pinMode(DIGITAL_PINS[i], INPUT_PULLUP);
//************LOOP**************
getAnalogData();
getDigitalData();
while (usbMIDI.read()) {
// controllers must call .read() to keep the queue clear even if they are not responding to MIDI
//************ANALOG SECTION**************
void getAnalogData(){
for (int i=0;i<A_PINS;i++){
// update the ResponsiveAnalogRead object every loop
analog[i].update();
// if the repsonsive value has change, print out 'changed'
if(analog[i].hasChanged()) {
data[i] = analog[i].getValue()>>3;
if (data[i] != dataLag[i]){
dataLag[i] = data[i];
usbMIDI.sendControlChange(CCID[i], data[i], channel);
//************DIGITAL SECTION**************
void getDigitalData(){
digital[i].update();
if (digital[i].fallingEdge()) {
if (CClast[i]){
usbMIDI.sendControlChange(CC[i], 0, channel);
CClast[i] = 0;
}else{
usbMIDI.sendControlChange(CC[i], ON_VALUE, channel);
CClast[i] = ON_VALUE;
// rising ignored for toggles
