Mini T3 BaseBoard for the Teensy 3
I was talking to my next door neighbor and mention to him that I needed
a smaller version of the development T3 BaseBase for the Teensy 3.
He said "you mean a reverse evolution of the T3 Baseboard?"
A few hours later, the Mini T3 BaseBoard was born. A tiny mini baseboard for the Teensy 3 which
still contains a solid modular connection system.
With this new mini PCB form factor, the Teensy 3 could be launched into the wild
blue yonder using the Teensy 3 as a low cost solution. DIYDrones are U listening?
Mini T3 BaseBoard Features:
20 4 pin modular JST connectors used for the Teensy 3 GPIO.(SeeedStudio Grove compatible)
1 amp +3.3 VDC power regulator with reverse polarity protection for extra bus power.
2 SPI modular connectors with chip selects.
3 I2C modular connectors with power and ground.
10 digital modular connectors with power and ground.
4 analog modular connectors with analog ground.
2 1x14 stacking female headers for breadboard testing OR
2 1x14 sip female headers for breadboard testing.
1 power-on green LED for bus power indication.
2 silver dome Tac switches. One for MPU reset and the other for the program bootloader.
A very flexible power setup configuration with only two jumpers.
All thru hole components for easy user assembly except for 4 surface mount 0805.
Pads for RTC backup. (VBAT and ground)
50% PCB form factor reduction reduced the board cost by ~50%.
Board size = 1.9" x 2.5 " or 4.826 cm x 6.35 cm
The Mini T3 BaseBoard does not have the following features like the bigger development T3 BaseBoard:
No series current limit protection.
No current limit protection for the Teensy 3.
Missing 1 extra SPI and I2C bus modular connectors.
Missing the user test LEDs and spare JST modular connectors.
No PCB mounting holes and extra GPIO for the bottom of Teensy 3 module due to board size constraints.
Development on-going ... waiting for offshore parts.
