Minimum number of pins to connect Teensy 3.2 and Audio Board
jannone
Dear All,
I just attempted to connect my Teensy 3.2 with an Audio Board, and got no output from the tutorial files.
Since I am trying to conserve pins, I'm attempting to connect using the minimum number.
I'm not using the SD Socket, so I connected the following pins:
SDA
SCL
+3.3V
LRCLK
TX
RX
GND
BCLK
MCLK
Should these 9 connections be sufficient? If so, I must have some other problem. If not, which additional pins need to be connected for use of the board without the SD Socket.
Thank you!
John
Yes, those 9 are the minimum.
Actually, you can omit the RX connection if you only want to output sound to the headphone jack or line-out pins, or omit the TX connection if you only want sound input from the mic or line-in pins.
Just to be clear, by RX/TX, you meant the I2S RX/TX pins and not the Serial1 UART pins (0/1):
  • I2S TX (22/A8);
  • I2S RX (13).
You probably need the SPI pins:
  • Alternate MOSI (7);
  • MISO (12);
  • Alternate SCLK (14/A0);
  • SD CS (10);
  • and optionally Flash CS (6).
I would suspect it would be a good idea to connect VIN and AGND as well. If you want to attach a potentiometer on the board, you would need to connect pin 15/A1 as well.
The schematic lists 2.2K pull-up resistors on SDA/SCL, so you don't need to put your own in.
