mixing midi devices and hid devices in usbhost mode...
lokki
hi, I am trying to connect several midi-devices and a mouse (hid) to the same hub and interact with all of them via USBHost on a teensy 4.1
If I upload just the mouse code, the mouse works. If I upload just the midi code the midi devices work. If I try to combine both, only the midi stuff works. I can see the mouse is recognised in the second sketch as well, but I get no values from it. Any hints on how to combine MIDI and HID in one sketch?
for reference here is the mouse-sketch: (pretty much from the examples, except for the midi sending part for x and y values)
// Simple test of USB Host Mouse/Keyboard
// This example is in the public domain
#include "USBHost_t36.h"
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
KeyboardController keyboard1(myusb);
KeyboardController keyboard2(myusb);
USBHIDParser hid1(myusb);
USBHIDParser hid2(myusb);
USBHIDParser hid3(myusb);
USBHIDParser hid4(myusb);
USBHIDParser hid5(myusb);
MouseController mouse1(myusb);
JoystickController joystick1(myusb);
//BluetoothController bluet(myusb, true, "0000");   // Version does pairing to device
BluetoothController bluet(myusb);   // version assumes it already was paired
int user_axis[64];
uint32_t buttons_prev = 0;
RawHIDController rawhid1(myusb);
RawHIDController rawhid2(myusb, 0xffc90004);
USBDriver *drivers[] = {&hub1, &hub2,&joystick1, &bluet, &hid1, &hid2, &hid3, &hid4, &hid5};
#define CNT_DEVICES (sizeof(drivers)/sizeof(drivers[0]))
const char * driver_names[CNT_DEVICES] = {"Hub1","Hub2", "JOY1D", "Bluet", "HID1" , "HID2", "HID3", "HID4", "HID5"};
bool driver_active[CNT_DEVICES] = {false, false, false, false};
// Lets also look at HID Input devices
USBHIDInput *hiddrivers[] = {&mouse1, &keyboard1, &keyboard2, &joystick1, &rawhid1, &rawhid2};
#define CNT_HIDDEVICES (sizeof(hiddrivers)/sizeof(hiddrivers[0]))
const char * hid_driver_names[CNT_DEVICES] = {"Mouse1", "KB1", "KB2", "Joystick1", "RawHid1", "RawHid2"};
bool hid_driver_active[CNT_DEVICES] = {false, false};
bool show_changed_only = false;
uint8_t joystick_left_trigger_value = 0;
uint8_t joystick_right_trigger_value = 0;
uint64_t joystick_full_notify_mask = (uint64_t) - 1;
int old_y = 0;
int old_x = 0;
 // while (!Serial) ; // wait for Arduino Serial Monitor
  Serial.println("\n\nUSB Host Testing");
  Serial.println(sizeof(USBHub), DEC);
  myusb.begin();
  // The below forceBootProtocol will force which ever
  // next keyboard that attaches to this device to be in boot protocol
  // Only try this if you run into keyboard with issues.  If this is a combined
  // device like wireless mouse and keyboard this can cause mouse problems.
  //keyboard1.forceBootProtocol();
  rawhid1.attachReceive(OnReceiveHidData);
  rawhid2.attachReceive(OnReceiveHidData);
  myusb.Task();
  if (Serial.available()) {
    int ch = Serial.read(); // get the first char.
    while (Serial.read() != -1) ;
    if ((ch == 'b') || (ch == 'B')) {
      Serial.println("Only notify on Basic Axis changes");
      joystick1.axisChangeNotifyMask(0x3ff);
    } else if ((ch == 'f') || (ch == 'F')) {
      Serial.println("Only notify on Full Axis changes");
      joystick1.axisChangeNotifyMask(joystick_full_notify_mask);
      if (show_changed_only) {
        Serial.println("\n*** Show All fields mode ***");
        show_changed_only = true;
        Serial.println("\n*** Show only changed fields mode ***");
  for (uint8_t i = 0; i < CNT_DEVICES; i++) {
    if (*drivers[i] != driver_active[i]) {
      if (driver_active[i]) {
        Serial.printf("*** Device %s - disconnected ***\n", driver_names[i]);
        driver_active[i] = false;
        Serial.printf("*** Device %s %x:%x - connected ***\n", driver_names[i], drivers[i]->idVendor(), drivers[i]->idProduct());
        driver_active[i] = true;
        const uint8_t *psz = drivers[i]->manufacturer();
        if (psz && *psz) Serial.printf("  manufacturer: %s\n", psz);
        psz = drivers[i]->product();
        if (psz && *psz) Serial.printf("  product: %s\n", psz);
        psz = drivers[i]->serialNumber();
        if (psz && *psz) Serial.printf("  Serial: %s\n", psz);
  for (uint8_t i = 0; i < CNT_HIDDEVICES; i++) {
    if (*hiddrivers[i] != hid_driver_active[i]) {
      if (hid_driver_active[i]) {
        Serial.printf("*** HID Device %s - disconnected ***\n", hid_driver_names[i]);
        hid_driver_active[i] = false;
        Serial.printf("*** HID Device %s %x:%x - connected ***\n", hid_driver_names[i], hiddrivers[i]->idVendor(), hiddrivers[i]->idProduct());
        hid_driver_active[i] = true;
        const uint8_t *psz = hiddrivers[i]->manufacturer();
        psz = hiddrivers[i]->product();
        psz = hiddrivers[i]->serialNumber();
        // Note: with some keyboards there is an issue that they don't output in boot protocol mode
        // and may not work.  The above code can try to force the keyboard into boot mode, but there
        // are issues with doing this blindly with combo devices like wireless keyboard/mouse, which
        // may cause the mouse to not work.  Note: the above id is in the builtin list of
        // vendor IDs that are already forced
        #if 0  // In list in older, newer code should support the N Key rollover directly
        if (hiddrivers[i] == &keyboard1) {
          if (keyboard1.idVendor() == 0x04D9) {
            Serial.println("Gigabyte vendor: force boot protocol");
            // Gigabyte keyboard
  if (mouse1.available()) {
   /* Serial.print("Mouse: buttons = ");
    Serial.print(mouse1.getButtons());
    Serial.print(",  mouseX = ");
    Serial.print(mouse1.getMouseX());
    Serial.print(",  mouseY = ");
    Serial.print(mouse1.getMouseY());
    Serial.print(",  wheel = ");
    Serial.print(mouse1.getWheel());
    Serial.print(",  wheelH = ");
    Serial.print(mouse1.getWheelH());
    mouse1.mouseDataClear(); */
    int y = mouse1.getMouseY()>>8;
    int x = mouse1.getMouseX()>>8;
    if (y != old_y) {
    usbMIDI.sendControlChange(1,y,1);
    old_y = y;
      if (x != old_x) {
usbMIDI.sendControlChange(2,x,1);
    old_x = x;
  // See if we have some RAW data
  if (rawhid1) {
    Serial.println("we have rawhid");
    int ch;
    uint8_t buffer[64];
    uint8_t count_chars = 0;
    memset(buffer, 0, sizeof(buffer));
      while (((ch = Serial.read()) != -1) && (count_chars < sizeof(buffer))) {
        buffer[count_chars++] = ch;
      rawhid1.sendPacket(buffer);
void OnHIDExtrasRelease(uint32_t top, uint16_t key)
  Serial.print("HID (");
  Serial.print(top, HEX);
  Serial.print(") key release:");
  Serial.println(key, HEX);
bool OnReceiveHidData(uint32_t usage, const uint8_t *data, uint32_t len) {
  // Called for maybe both HIDS for rawhid basic test.  One is for the Teensy
  // to output to Serial. while still having Raw Hid...
  if (usage == 0xffc90004) {
    // Lets trim off trailing null characters.
    while ((len > 0) && (data[len - 1] == 0)) {
      len--;
    if (len) {
      Serial.print("RawHid Serial: ");
      Serial.write(data, len);
    Serial.print("RawHID data: ");
    Serial.println(usage, HEX);
    while (len) {
      uint8_t cb = (len > 16) ? 16 : len;
      const uint8_t *p = data;
      uint8_t i;
      for (i = 0; i < cb; i++) {
        Serial.printf("%02x ", *p++);
      Serial.print(": ");
        Serial.write(((*data >= ' ') && (*data <= '~')) ? *data : '.');
        data++;
      len -= cb;
  return true;
and the midi code with an attempt to massage in the mouse part: (note that the mouse reports as being connected in the serial monitor...I just don't get any values)
//cpu speed 600 mhz and fast instead of fastest increases stability?
#include <MIDI.h>        // access to serial (5 pin DIN) MIDI
#include <USBHost_t36.h> // access to USB MIDI devices (plugged into 2nd USB port)
//#include "WacomController.h"
//includes for OLEDs
//#include <i2c_driver_wire.h> //Library for I2C interface
#include <U8x8lib.h>
#ifdef U8X8_HAVE_HW_SPI
extern void leds_update();
extern void led_color(unsigned int num, unsigned int rgb);
extern void led_color(unsigned int num, unsigned char red, unsigned char green, unsigned char blue);
extern void led_channel(unsigned int num, unsigned int val);
#define OFF    0x000000
#define RED    0xFF0000
#define GREEN  0x00FF00
#define BLUE   0x0000FF
#define YELLOW 0xFFFF00
#define PINK   0xFF1088
#define ORANGE 0xE05800
#define WHITE  0xFFFFFF
U8X8_SH1106_128X64_NONAME_HW_I2C u8x8(/* reset=*/ U8X8_PIN_NONE, /* clock=*/ 19, /* data=*/ 18);
#define DEBUG
// Create the Serial MIDI ports
MIDI_CREATE_INSTANCE(HardwareSerial, Serial8, MIDI1);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial3, MIDI2);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial4, MIDI3);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial5, MIDI4);
//midi::MidiInterface &SerialMidiList[6] = {MIDI1, MIDI2, MIDI3, MIDI4, MIDI5, MIDI6};
//usb synth devices
int pulse2 = -1;
int keysaxo = -1;
int minitaur = -1;
int axodub = -1;
//int blofeld = -1;
//usb midibass controller
int midibass = -1;
//dmx color routing for cheap thomann light, reordering midi aftertouch to matching colors ...
//3= blue 2= green 1= red 4= white
int color_order[4] {3,2,1,4};
//handle on screen boot messages...
elapsedMillis boottime;
int state = 0;
// Create the ports for USB devices plugged into Teensy's 2nd USB port (via hubs)
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
USBHub hub4(myusb);
USBHub hub5(myusb);
USBHub hub6(myusb);
USBHub hub7(myusb);
USBHub hub8(myusb);
MIDIDevice_BigBuffer midi01(myusb);
MIDIDevice_BigBuffer midi02(myusb);
MIDIDevice_BigBuffer midi03(myusb);
MIDIDevice_BigBuffer midi04(myusb);
MIDIDevice_BigBuffer midi05(myusb);
MIDIDevice_BigBuffer midi06(myusb);
MIDIDevice_BigBuffer midi07(myusb);
MIDIDevice_BigBuffer midi08(myusb);
MIDIDevice_BigBuffer * midilist[8] = {
  &midi01, &midi02, &midi03, &midi04, &midi05, &midi06, &midi07, &midi08
USBDriver *drivers[] = {&hub1, &hub2,&hub3, &hub4,&hub5, &hub6, &hub7, &hub8, &hid1, &hid2};
const char * driver_names[CNT_DEVICES] = {"Hub1","Hub2", "Hub3", "Hub4", "Hub5" , "Hub6", "Hub7", "Hub8", "&HID1", "&HID2"};
USBHIDInput *hiddrivers[] = {&mouse1};
const char * hid_driver_names[CNT_DEVICES] = {"Mouse1"};
bool hid_driver_active[CNT_DEVICES] = {false};
USBHIDParser hid6(myusb);
USBHIDParser hid7(myusb);
WacomController digi1(myusb);
//wacom stuff
int axis_prev[16] = { -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1 };
//wacom midi stuff
int x_val;
int y_val;
int old_x_val;
int old_y_val;
USBDriver *drivers[] = { &hub1, &hub2, &hub3, &hub4, &hid1, &hid2, &hid3, &hid4, &hid5, &hid6, &hid7 };
#define CNT_DEVICES (sizeof(drivers) / sizeof(drivers[0]))
const char *driver_names[CNT_DEVICES] = { "Hub1", "Hub2","Hub3", "Hub4", "HID1", "HID2", "HID3", "HID4", "HID5", "HID6", "HID7" };
bool driver_active[CNT_DEVICES] = { false, false, false, false };
USBHIDInput *hiddrivers[] = { &digi1 };
#define CNT_HIDDEVICES (sizeof(hiddrivers) / sizeof(hiddrivers[0]))
const char *hid_driver_names[CNT_DEVICES] = { "digi1" };
bool hid_driver_active[CNT_DEVICES] = { false };
// A variable to know how long the LED has been turned on
//elapsedMillis ledOnMillis;
//dmx stuff
long counter = 0;
int decay = 64; //starts decay at the halfway point
elapsedMillis timeout;
int old_y = 0;
int old_x = 0;
  Wire.setSDA(18);
  Wire.setSCL(19);
   u8x8.begin();
  u8x8.setPowerSave(0);
  u8x8.setFont(u8x8_font_5x8_f);
  while (!Serial && millis() < 1200) {
   u8x8.drawString(0,4,"Booting...");
   u8x8.clear();
  for (int i=0; i<13; i++) {
  pinMode(i,INPUT_DISABLE);
  for (int i=24; i<34; i++) {
   for (int i=36; i<55; i++) {
  pinMode(22,INPUT_DISABLE);
  pinMode(23,INPUT_DISABLE);
  #ifdef DEBUG
  pinMode(13, OUTPUT); // LED pin
  digitalWrite(13, LOW);
  MIDI1.begin(MIDI_CHANNEL_OMNI);
  MIDI2.begin(MIDI_CHANNEL_OMNI);
  MIDI3.begin(MIDI_CHANNEL_OMNI);
  MIDI4.begin(MIDI_CHANNEL_OMNI);
  // Wait 3.5 seconds before turning on USB Host.  If connected USB devices
  // use too much power, Teensy at least completes USB enumeration, which
  // makes isolating the power issue easier.
  #ifdef DEBUG
  Serial.println("Booting...");
   boottime = 0;
   while (boottime < 1000) {
    if (boottime < 300)  {
      if (!state) u8x8.drawString(0,4,"W");
      state = 1;
   } else if (boottime < 600)  {
      if (state == 1)  u8x8.drawString(0,4,"WA");
      state = 2;
   } else if (boottime < 900) {
      if (state == 2)  u8x8.drawString(0,4,"WAI");
      state = 3;
  // u8x8.drawString(0,0,"Booting");
 // delay(3500);
 //usbMIDI.begin();
 myusb.begin();
 boottime = 0;
  //wait another 10 seconds before enumerating the devices, hopefully by now they have settled.
  while (boottime < 3000) {
     if (state == 3)  u8x8.drawString(0,4,"WAIT");
      state = 4;
      if (state == 4) u8x8.drawString(0,4,"WAITI");
      state = 5;
      if (state == 5) u8x8.drawString(0,4,"WAITIN");
      state = 6;
    } else if (boottime < 1200) {
      if (state == 6) u8x8.drawString(0,4,"WAITING");
      state = 7;
    } else if (boottime < 1500)  {
      if (state == 7) u8x8.drawString(0,4,"WAITING.");
      state = 8;
    } else if (boottime < 1800)  {
       if (state == 8)u8x8.drawString(0,4,"WAITING..");
      state = 9;
    } else if (boottime < 2100)  {
       if (state == 9)u8x8.drawString(0,4,"WAITING...");
      state = 10;
    } else if (boottime < 2400) {
      if (state == 10) u8x8.drawString(0,4,"WAITING....");
      state = 11;
    } else if (boottime < 2700)  {
      if (state == 11) u8x8.drawString(0,4,"WAITING.....");
      state = 12;
    } else if (boottime < 3000){
      if (state == 12) u8x8.drawString(0,4,"WAITING......");
      state = 13;
  u8x8.clear();
  u8x8.drawString(0,0,"  USB DEVICES  ");
  u8x8.drawString(0,1,"---------------");
  u8x8.drawString(0,7,"---------------");
//delay(10000);
Serial.println("");
Serial.println("------------NEW START--------------");
for (int i=0; i<8; i++) {
  if (midilist[i]->manufacturer() != NULL && midilist[i]->serialNumber() != NULL) {
  //  #ifdef DEBUG
     Serial.println("-----------------------------------");
     Serial.print("Serial:");
     Serial.println((char*)midilist[i]->serialNumber());
     Serial.print("ProductID:");
     Serial.println(midilist[i]->idProduct());
   //  #endif
     if (!strcmp(reinterpret_cast<const char *>(midilist[i]->serialNumber()),"003600433435511733353932")) {//Axoloti for qunexus/vocoder serial
     #ifdef DEBUG
      Serial.println("here is axovocoder");
       u8x8.drawString(0,i+2,"AxoVox");
       u8x8.drawString(10,i+2,String(i).c_str());
      keysaxo = i;
     if (midilist[i]->idProduct() == 22) {
      #ifdef DEBUG
      Serial.println("here is Pulse2");
       u8x8.drawString(0,i+2,"Pulse2");
      pulse2 = i;
 /*  if (midilist[i]->idProduct() == 19) {
     #ifdef DEBUG
      Serial.println("here is Blofeld");
     u8x8.drawString(0,i+2,"Blofeld");
    blofeld = i;
    /*   if (!strcmp(reinterpret_cast<const char *>(midilist[i]->serialNumber()),"325B346C3030")) {//typhon dreadbox
     #ifdef DEBUG
      Serial.println("here is typhon dreadbox");
      dreadbox = i;
        if (!strcmp(reinterpret_cast<const char *>(midilist[i]->serialNumber()),"12209010")) {//midibass
       #ifdef DEBUG
      Serial.println("here is MIDIBASS!!");
       u8x8.drawString(0,i+2,"MIDIBASS");
      midibass = i;
  if (!strcmp(reinterpret_cast<const char *>(midilist[i]->serialNumber()),"003500323532470532323631")) {//Axoloti for "serum" sounds
  #ifdef DEBUG
      Serial.println("here is axodub");
       u8x8.drawString(0,i+2,"AxoDub");
      axodub = i;
if (!strcmp(reinterpret_cast<const char *>(midilist[i]->serialNumber()),"MTc537ef")) {//moog minitaur
#ifdef DEBUG
      Serial.println("here is the minitaur");
      u8x8.drawString(0,i+2,"Minitaur");
      minitaur = i;
  delay(300);
Serial.println("------------Finished------------");
if (pulse2 >= 0) midilist[pulse2]->sendProgramChange(0,6);
  // delay(1);
   if (axodub >= 0 ) midilist[axodub]->sendProgramChange(0,1);
   // delay(1);
   if (minitaur >= 0)  midilist[minitaur]->sendProgramChange(1,8);
   //send to dreadbox typhon...
  MIDI1.sendProgramChange(0,9);
usbMIDI.sendProgramChange(0,1);
 /*  if (blofeld >= 0) {
    midilist[blofeld]->sendControlChange(0,127,6);
    midilist[blofeld]->sendControlChange(32,127,6);
     midilist[blofeld]->sendProgramChange(0,6);
  leds_update();
   myusb.Task();
    if (y != old_y) {
    old_y = y;
      if (x != old_x) {
    old_x = x;
 /*  if (digi1.available()) {
    int touch_count = digi1.getTouchCount();
    int touch_index;
    uint16_t buttons_bin = digi1.getPenButtons();
    bool pen_button[3];
  //  Serial.printf("Digitizer: ");
    for (int i = 0; i < 3; i++) {
      pen_button[i] = (buttons_bin >> i) & 0x1;
    //  Serial.printf("Pen_Btn%d:%d ",i, pen_button[i]);
    switch (digi1.eventType()) {
      case WacomController::TOUCH:
        Serial.print(" Touch:");
        for (touch_index = 0; touch_index < touch_count; touch_index++) {
          Serial.printf(" (%d, %d)", digi1.getX(touch_index), digi1.getY(touch_index));
      case WacomController::PEN:
        Serial.printf(" Pen: (%d, %d) Pressure: %u Distance: %u", digi1.getX(), digi1.getY(),
            digi1.getPenPressure(), digi1.getPenDistance());
        Serial.printf(" TiltX: %d TiltY: %d",digi1.getPenTiltX(), digi1.getPenTiltY());
        case WacomController::MOUSE:
      //  Serial.printf(" Pen: (%d, %d) Pressure: %u Distance: %u", digi1.getX(), digi1.getY(),
       //     digi1.getPenPressure(), digi1.getPenDistance());
       x_val = digi1.getX()>>8;
       if (x_val != old_x_val) usbMIDI.sendControlChange(4,x_val,1,0);
       old_x_val = x_val;
        y_val = digi1.getY()/160;
       if (y_val != old_y_val) usbMIDI.sendControlChange(5,y_val,1,0);
       old_y_val = y_val;
       //Serial.printf("Buttons: %d",digi1.getMouseButtons());
       // Serial.printf(" TiltX: %d TiltY: %d",digi1.getPenTiltX(), digi1.getPenTiltY());
      case WacomController::FRAME:
        //wheel data 0-71
        Serial.printf(" Whl: %d ", digi1.getFrameWheel());
        //wheel button binary, no touch functionality
        Serial.printf(" WhlBtn: %d ", digi1.getFrameWheelButton());
      if (digi1.getFrameWheelButton()) {
        static uint8_t mode = 0;
        mode = (mode + 1) % 4;
        Serial.printf("Mode: %d",mode);
       digi1.changeLed(mode);
        //buttons are saved within one byte for all the 8 buttons, here is a decoding example
        uint16_t button_touch_bin = digi1.getFrameTouchButtons();
        uint16_t button_press_bin = digi1.getFrameButtons();
        bool button_touched[8];
        bool button_pressed[8];
        for (int i = 0; i < 8; i++) {
          button_touched[i] = (button_touch_bin >> i) & 0x1;
          button_pressed[i] = (button_press_bin >> i) & 0x1;
          Serial.printf("Btn%d: T:%d P:%d ",i,button_touched[i], button_pressed[i]);
      default:
        Serial.printf(",  X = %u, Y = %u", digi1.getX(), digi1.getY());
        Serial.print(",  Pressure: = ");
        Serial.print(digi1.getWheel());
        Serial.print(digi1.getWheelH());
        if (show_changed_only) Serial.print("\t: ");
        for (uint8_t i = 0; i < 16; i++) {
          int axis = digi1.getAxis(i);
            if (axis != axis_prev[i]) Serial.printf(" %d#%d(%x)", i, axis, axis);
          } else
            Serial.printf(" %d%c%d(%x)", i, (axis == axis_prev[i]) ? ':' : '#', axis, axis);
          axis_prev[i] = axis;
    digi1.digitizerDataClear();
  if(usbMIDI.read()) {
      uint8_t type =       usbMIDI.getType();
      uint8_t data1 =       usbMIDI.getData1();
      uint8_t data2 =       usbMIDI.getData2();
      uint8_t channel =     usbMIDI.getChannel();
      uint8_t cable =       usbMIDI.getCable();
    if (midibass >= 0){
    midilist[midibass]->send(type, data1, data2, channel, cable);
   // int dmxChannel = (channel -1)*128 + data1;
   // led_channel(dmxChannel, data2*2);
 myusb.Task();
  if (midibass >= 0){
 if (midilist[midibass]->read()) {
      uint8_t type =       midilist[midibass]->getType();
      uint8_t data1 =      midilist[midibass]->getData1();
      uint8_t data2 =      midilist[midibass]->getData2();
      uint8_t channel =    midilist[midibass]->getChannel();
      uint8_t cable =      midilist[midibass]->getCable();
     // const uint8_t *sys = midilist[midibass]->getSysExArray();
      midi::MidiType mtype = (midi::MidiType)type;
      if (type != 0xC0) {
      if (!cable) {
          if (channel == 1) {
            sendToMacMini(type, data1, data2, channel, 0);
           // if (axodub >= 0) midilist[axodub]->send(type, data1, data2, channel);
          if (channel == 6) {
            if (pulse2 >= 0)  midilist[pulse2]->send(type, data1, data2, channel);
          //  if (blofeld >= 0)  midilist[blofeld]->send(type, data1, data2, channel);
          if (channel == 7) {
          if (channel == 8) {
            if (minitaur >= 0)  midilist[minitaur]->send(type, data1, data2, channel);
          if (channel == 9) {
            //if (dreadbox < 11) midilist[dreadbox]->send(type, data1, data2, channel);
            MIDI1.send(mtype, data1, data2, channel);
          if (((channel > 1) && (channel < 6)) || (channel > 9)) {
            sendToMacMini(type, data1, data2, channel, 0); // channel 2-5 and 10-16
       // dmx lightshow based on midi input...
         if (type == 0xD0) {
          //aftertouch to lights... for now...
          int lookup = (channel - 2) % 4;
        int dmxChannel =  color_order[lookup];
      //  Serial.println(dmxChannel);
    led_channel(dmxChannel, data1*2);
          if (type == 0xB0) {
            if ((channel == 8) && (data1 == 1)) led_channel(1,data2*2); //red for the minitaur
      else if (cable == 1) {
      sendToMacMini(type, data1, data2, channel, 1); //send all accordion data to the macmini on port 1
       if ((channel > 12) && (keysaxo >= 0)) {
          midilist[keysaxo]->send(type, data1, data2, channel);
     //   MIDI2.send(mtype, data1, data2, channel);
       //   Serial.println(type);
 } else if (type == 0xC0) {
     midilist[blofeld]->sendProgramChange(data1,6);
   if (pulse2 >= 0) midilist[pulse2]->sendProgramChange(data1,6);
  // delay(1);
   if (axodub >= 0 ) midilist[axodub]->sendProgramChange(data1,1);
   // delay(1);
   if (minitaur >= 0)  midilist[minitaur]->sendProgramChange(data1 + 1,8);
  MIDI1.sendProgramChange(data1,9);
  //send to macmini...
usbMIDI.sendProgramChange(data1,1);
     // activity = true;
void sendToMacMini(byte type, byte data1, byte data2, byte channel, byte cable)
  if (type != midi::SystemExclusive) {
    usbMIDI.send(type, data1, data2, channel, cable);
   // unsigned int SysExLength = data1 + data2 * 256;
   // usbMIDI.sendSysEx(SysExLength, sysexarray, true, cable);
this is the serial print I get from the second sketch (only the portion after the midi stuff):
17:09:15.053 -> ------------Finished------------
17:09:15.053 -> *** Device Hub1 5e3:610 - connected ***
17:09:15.053 ->   manufacturer: GenesysLogic
17:09:15.053 ->   product: USB2.1 Hub
17:09:15.053 -> *** Device Hub2 5e3:610 - connected ***
17:09:15.053 -> *** Device &HID1 16c0:485 - connected ***
17:09:15.053 ->   manufacturer: Teensyduino
17:09:15.053 ->   product: Teensy MIDIx4
17:09:15.053 ->   Serial: 12209010
17:09:15.053 -> *** Device &HID2 1ff7:9 - connected ***
17:09:15.053 ->   manufacturer: IrScreen ca
I didn't take an in-depth look at your complete sketches, but I did notice that your second sketch does not seem to include the following two lines from the first sketch to define the rawHID controllers:
It is also missing the initialization calls to initialize these same controllers:
And, of course, the referenced OnReceiveHidData() function.
Maybe try adding those & see if it makes any positive difference . . .
Mark J Culross
KD5RXT
thanks for your answer. the solution was much more simple...
I had the
statement in my function before doing anything with the values, which resulted in no changing values of course... accidentally I had the DataClear portion commented out in the first sketch, and that is why it worked there. all good now!
and I spoke to soon!
It works fine as long as only 4 midi devices and the mouse are connected, as soon as I connect 5 midi devices and the mouse, it does not work anymore, the mouse does not send any values out... here is again the code (working with 4 connected midi devices, but not 5)
#define DEBUG
//usb synth devices
int pulse2 = -1;
int keysaxo = -1;
int minitaur = -1;
int axodub = -1;
//int blofeld = -1;
int midibass = -1;
int state = 0;
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
USBHub hub4(myusb);
USBHub hub5(myusb);
USBHub hub6(myusb);
USBHub hub7(myusb);
USBHub hub8(myusb);
USBDriver *drivers[] = {&hub1, &hub2,&hub3, &hub4,&hub5, &hub6, &hub7, &hub8};
const char * driver_names[CNT_DEVICES] = {"Hub1","Hub2", "Hub3", "Hub4", "Hub5" , "Hub6", "Hub7", "Hub8"};
//wacom stuff
//wacom midi stuff
int x_val;
int y_val;
int old_x_val;
int old_y_val;
//dmx stuff
long counter = 0;
int old_y = 0;
int old_x = 0;
bool mouse_active = 0;
bool mouse_old = 1;
elapsedMillis timer;
  Wire.setSDA(18);
  Wire.setSCL(19);
   u8x8.begin();
   u8x8.clear();
  #ifdef DEBUG
  #ifdef DEBUG
   boottime = 0;
      state = 1;
      state = 2;
      state = 3;
 // delay(3500);
 //usbMIDI.begin();
 myusb.begin();
 boottime = 0;
      state = 4;
      state = 5;
      state = 6;
      state = 7;
      state = 8;
      state = 9;
      state = 10;
      state = 11;
      state = 12;
      state = 13;
  u8x8.clear();
//delay(10000);
Serial.println("");
  //  #ifdef DEBUG
   //  #endif
     #ifdef DEBUG
      keysaxo = i;
      #ifdef DEBUG
      pulse2 = i;
     #ifdef DEBUG
    blofeld = i;
     #ifdef DEBUG
      dreadbox = i;
       #ifdef DEBUG
      midibass = i;
  #ifdef DEBUG
      axodub = i;
#ifdef DEBUG
      minitaur = i;
  delay(300);
        u8x8.drawString(12,2,"IRF");
        u8x8.drawString(15,2,String(i).c_str());
  // delay(1);
   // delay(1);
  leds_update();
   myusb.Task();
      mouse_active = 1;
      if (mouse_active != mouse_old) {
        usbMIDI.sendControlChange(3,127,1);
      mouse_old = 1;
    timer = 0;
    if (y != old_y) {
    old_y = y;
      if (x != old_x) {
    old_x = x;
  } else if (timer > 20) { //the infrared frame refreshes at around 20ms
    mouse_active = 0;
    usbMIDI.sendControlChange(3,0,1);
    mouse_old = mouse_active;
    if (midibass >= 0){
 myusb.Task();
  if (midibass >= 0){
      if (type != 0xC0) {
      if (!cable) {
          if (channel == 1) {
          if (channel == 6) {
          if (channel == 7) {
          if (channel == 8) {
          if (channel == 9) {
           // if (channel < 7) sendtonymphes
         if (type == 0xD0) {
          if (type == 0xB0) {
            if ((channel == 8) && (data1 == 1)) led_channel(1,data2*2); //red for the minitaur (where aftertouch is remapped to modwheel)
  // delay(1);
   // delay(1);
     // activity = true;
